Author Topic: Internet Connection Sharing - Support Question  (Read 5349 times)
Offline BkS
  • BkS Media Founder
    • BkS Media
Re: Internet Connection Sharing - Support Question
« Reply #90 on: April 12, 2012, 06:22:17 pm »
Well it's the 32-bit ISO on the disc, so kinda confused.
If that's where the missing RAM is going then that's alright. Just hope it hasn't grown legs and walked. Lol.
« Reply #91 on: April 12, 2012, 08:02:51 pm »
Have you tried removing that extra memory stick ? .. which doesn't seem right to me, I can't see the mobo allocating 1GB+ to the GFX card on an older system
Offline SeZo
« Reply #92 on: April 12, 2012, 09:52:35 pm »
Have you tried the boot options?
For ATI you could add to boot options:
radeon.modeset=0
As for the missing ram it appears that the motherboard D102GGC2 can only support up to 2 GiB
*-memory
          description: System Memory
          physical id: 14
          slot: System board or motherboard
          capacity: 2GiB
The video appears to be on board Integrated ATI Radeon Xpress 200 with
up to 128 MB of shared video memory
« Reply #93 on: April 12, 2012, 10:17:09 pm »
SeZo's right .. the MoBo only supports 2GB RAM (well spotted BTW)
See the spec sheet:
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
So ditch the other stick.
and as he says, try adding radeon.modeset=0 as a kernel boot parameter.
« Last Edit: April 12, 2012, 10:44:21 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #94 on: April 13, 2012, 01:33:15 pm »
Kernel boot parameter didn't work. Think I'll just put 11.10 server on it instead and then upgrade once it's offically released. :(
In other news: I think when my electricity cut-out this morning it's damaged the MoBo. It won't boot up into the hard-drives, but even worse and pretty worryingly, it won't boot up into the BIOS. :/
Just hangs at the Mobo bootloader screen.
So I've pulled out the PSU and changed the cables. Put in another PSU and still the same problem. Also took out the extra stick. Nothing.
Gonna leave it off for a while and try again later.
This has been nothing but trouble. :(
« Reply #95 on: April 13, 2012, 01:49:31 pm »
If you disconnect EVERYTHING from the MoBo .. hard drives/floppy drives/Optical dirves/sound card/modem/etc. .. and leave just what's necessary to access the BIOS .. gfx card/mobo/keyboard .. can you access the BIOS now ?
If not .. with everything that's unnecessary still disconnected, try a BIOS reset.
« Last Edit: April 13, 2012, 01:51:13 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #96 on: April 14, 2012, 03:17:42 am »
Ok I think I've found what's up. It looks as if that because the hardware the NAS runs on, Ubuntu 12.04 looks as if it doesn't support it anymore. So I think I'll probably be best downloading the Lucid Server LTS as it will probably work.
The 12.04 Beta 2 disc is fine, I checked it with my lappy and my brothers and both said "Disc is valid".
Mobo seems fine as well, just doesn't like the disc at times.
« Reply #97 on: April 14, 2012, 09:16:49 am »
Could it possibly be the CD/DVD drive in the NAS box .. but yeh you try 10.04 and an upgrade.
Can you answer me a question .. is "quiet splash" still part of the server edition kernel boot line ?
And if so, have you removed it to try get a cue as to what's going on ?
Is there an alternate install disk for the server edition ?
« Last Edit: April 14, 2012, 09:20:16 am by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #98 on: April 14, 2012, 09:52:28 am »
Ubuntu Lucid Lynx Server i.e. 10.04 Server installed perfectly fine. :o
Although I have one problem. The network. :(
I accidentally selected manually configure later, and now I can't get updates from the repos.
I've tried setting it manually following the guide on the Ubuntu Wiki -
https://help.ubuntu.com/10.04/serverguide/C/network-configuration.html
i'm on a local-loopback according to ifconfig
I also noticed that lshw shows that the network is disabled, but whenever I try to enable it manually using sudo ifup eth0 I get the output:
Ignoring unknown interface eth0=eth0
Hardware list;
sudo lshw -C network
*-network  DISABLED
description: Ethernet Interface
product: RTL-8139/8139C/8139C*
vendor: Realtek Semiconductor CO., Ltd.
physical id: 2
bus info: pci0000 : 02 : 02 : 0
logical name: eth0
version: 10
serial: 00:16:76:00:13:b5
width: 32 bits
clock: 33 MHz
capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt autonegotiatio n
configuration: autonegotiatio n=on broadcast=yes driver=8139too driverversion=0.9.20 duplex=full latency=64 maxlatency=64 link=yes mingnt=32 multicast=yes port=MII speed=100MB/s
resources: irq:21 ioport:1000(size256) memory:a00000000-a00000ff
No quite-splash isn't in the parameter anymore, instead it's just -- quite
« Reply #99 on: April 14, 2012, 09:59:47 am »
What are the contents of:
sudo nano /etc/network/interfaces
sudo nano /etc/resolv.conf
What static IP do you want to give it, and what is your routers IP ?
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #100 on: April 14, 2012, 10:14:51 am »
auto lo
iface lo inet loopback
Nothing in /etc/resolv.conf
I'd like the NAS to be 192.168.0.8 and the routers local IP is 192.168.0.1
« Reply #101 on: April 14, 2012, 11:11:12 am »
Make /etc/network/interfaces read:-
auto lo
# Added by BkS
auto eth0
iface eth0 inet static
address 192.168.0.8
netmask 255.255.255.0
gateway 192.168.0.1
And make /etc/resolv.conf read:-
# Added by BkS
nameserver 192.168.0.1
Now try running:
sudo ifup eth0
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #102 on: April 14, 2012, 11:31:27 am »
Sweet, network is working now. How do I install webmin via CLI and setup.
Oh and for some reason my lappy isn't being seen by the brothers lappy running Oneiric or the  NAS.   :o
Workgroup is called WORKGROUP so kinda confused. I have folders share... maybe I just need to restart samba on my lappy.
« Reply #103 on: April 14, 2012, 11:42:23 am »
Install Webmin from the command line ..
mkdir ~/webmin
cd ~/webmin
wget http://sourceforge.net/projects/webadmin/files/webmin/1.580/webmin_1.580_all.deb
sudo dpkg -i webmin_1.580_all.deb
Offline SeZo
« Reply #104 on: April 14, 2012, 12:52:59 pm »
Or you could try:
sudo apt-get install webmin
It should be in the repos. (it is for Lucid)
