Author Topic: [SOLVED] New HD  (Read 1996 times)
Re: New HD
« Reply #30 on: April 15, 2012, 07:05:03 pm »
The /media/Drive3 directory doesn't exist... fstab can't mount a drive/partition to a directory (mount point) that doesn't exist :)
Run:
sudo mkdir /media/Drive3
then reboot.
Offline pooky2483
  • Struggling Windows convert
Re: New HD
« Reply #31 on: April 15, 2012, 07:07:24 pm »
The /media/Drive3 directory doesn't exist... fstab can't mount a drive to a directory (mount point) that doesn't exist :)
Run:
then reboot.
Thanks for that Mark, I knew there was <something> I was missing but just couldn’t think what it was, I knew it was something to do with making the system 'see' the HD.
Ubuntu 12.04 64bit|M3A76-CM|BIOS 2002|AMD Athlon64 X2 5200+|Realtek RTL8168C(P)|8111C(P) PCI-E Gigabit Ethernet NIC|NVIDIA 128MB GeForce6200 Turbocache|3.0GB Single-Channel DDR2 @ 387MHz (5-5-5-18)|PEAK 138508AGPK DVB-T Digital TV Hybrid PCI Card|T~bird|Firefox|MATE
Offline pooky2483
Re: [SOLVED] New HD
« Reply #32 on: April 15, 2012, 07:58:56 pm »
Re your question on why I did what I did...
http://linuxforums.org.uk/index.php?topic=10030.0
... You told me to lol ;D
Re: [SOLVED] New HD
« Reply #33 on: April 15, 2012, 08:01:07 pm »
What question ?
Offline pooky2483
Re: [SOLVED] New HD
« Reply #34 on: April 15, 2012, 08:39:26 pm »
Re: [SOLVED] New HD
« Reply #35 on: April 15, 2012, 08:51:21 pm »
Read the topic again .. I was asking BkS why he was suggesting you reformat .. not you ::)
Offline pooky2483
Re: [SOLVED] New HD
« Reply #36 on: April 15, 2012, 09:34:48 pm »
Well, if you read the thread I posted, that's my answer anyways
Re: [SOLVED] New HD
« Reply #37 on: April 15, 2012, 09:47:00 pm »
Does that ma .. oh sod it .. I give up  ???
Offline pooky2483
Re: [SOLVED] New HD
« Reply #38 on: April 15, 2012, 11:18:53 pm »
Well, anyway, that's what I wanted to do...
