Author Topic: Mounting hard-drives from external sources. [Solved]  (Read 3642 times)
Offline BkS
  • BkS Media Founder
    • BkS Media
« on: April 15, 2012, 01:34:34 pm »
I'm currently trying to permanently mount my NAS's 3 hard-drives to a single directory. It won't matter if the drives have different names as they'll just be for storing files anyway. I need to create symlinks, but I don't know how to do that.
Output from commands:
mount
(click to show/hide)
sudo nano /etc/fstab
sudo fdisk -l
« Last Edit: January 28, 2013, 04:09:25 pm by BkS »
Re: Mounting hard-drives from external sources.
« Reply #1 on: April 15, 2012, 01:46:14 pm »
Bearing in mind one of the drives is only 20GB .. what do you want the mountpoints, and therefore the visible folders on the NAS to be called ?
Sommat like
Docs = 20GB
Main_Share = 200GB
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #2 on: April 15, 2012, 02:08:31 pm »
Wallpapers = 20GB
Main Share = 200GB
« Reply #3 on: April 15, 2012, 02:27:30 pm »
OK, lets create the mountpoints, and the NAS-Shares directory -
mkdir ~/NAS-Shares
sudo mkdir /mnt/NAS-20GB
sudo mkdir /mnt/NAS-200GB
OK, now for the symlinks (I'll use the suggested names above, so adjust if you wish) -
ln -s /mnt/NAS-20GB ~/NAS-Shares/Wallpapers
ln -s /mnt/NAS-200GB ~/NAS-Shares/Main_Share
Now lets make sure the ~/NAS-Shares directory ISN'T writeable ..
chmod 555 ~/NAS-Shares
Now backup your /etc/fstab (just in case)
sudo cp -v /etc/fstab /etc/fstab.backup
Open fstab for editing:
and add the two lines at the bottom so it reads:-
# Use 'blkid -o value -s UUID' to print the universally unique identifier
# for a device; this may be used with UUID= as a more robust way to name
# devices that works even if disks are added and removed. See fstab(5).
proc            /proc           proc    nodev,noexec,nosuid 0       0
# / was on /dev/sda1 during installation
UUID=ff0a5255-09f5-4b23-a2d2-8db9cebc726d /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda5 during installation
UUID=652469de-ef92-47ea-8e42-25deb43687fe none            swap    sw              0       0
/dev/sdb1 /mnt/NAS-200GB       ext3       rw,errors=remount-ro       0       0
/dev/sdc1 /mnt/NAS-20GB       ext3       rw,errors=remount-ro       0       0
SAVE fstab ..
Now run:
sudo mount -a
and post any output.
If nothing is returned .. post the output from:
mount
Is there anything currently on those drives ?
IF YES .. can you confirm you can see the contents with:
ls ~/NAS-Shares/Wallpapers
ls ~/NAS-Shares/Main_Share
« Last Edit: April 15, 2012, 02:36:27 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #4 on: April 15, 2012, 03:00:28 pm »
mount
/dev/sda1 on / type ext4 (rw,errors=remount-ro)
none on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /dev type devtmpfs (rw,mode=0755)
none on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
none on /dev/shm type tmpfs (rw,nosuid,nodev)
none on /var/run type tmpfs (rw,nosuid,mode=0755)
none on /var/lock type tmpfs (rw,noexec,nosuid,nodev)
none on /lib/init/rw type tmpfs (rw,nosuid,mode=0755)
none on /var/lib/ureadahead/debugfs type debugfs (rw,relatime)
/dev/sdb1 on /media/Storage type ext3 (rw,nosuid,nodev,uhelper=udisks)
/dev/sdc1 on /media/Storage 2 type ext3 (rw,nosuid,nodev,uhelper=udisks)
/dev/sdb1 on /mnt/NAS-200GB type ext3 (rw,errors=remount-ro)
/dev/sdc1 on /mnt/NAS-20GB type ext3 (rw,errors=remount-ro)
Nope.
« Reply #5 on: April 15, 2012, 03:07:19 pm »
I'm a bit baffled as to why they are being mounted twice .. unless you're manually mounting them.
Can you reboot the server .. then send the output from:
mount
and DID you format them as ext3 or ext4 ?
« Last Edit: April 15, 2012, 03:09:13 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #6 on: April 15, 2012, 03:24:00 pm »
mount
i formatted them as EXT3.
« Reply #7 on: April 15, 2012, 03:34:37 pm »
OK .. is samba installed ?
What are the contents of:
nano /etc/samba/smb.conf
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #8 on: April 15, 2012, 04:00:26 pm »
Yes, samba is installed and working correctly, although Samba on my lappy doesn't. It won't find any other devices on the network. :o
« Reply #9 on: April 15, 2012, 04:05:10 pm »
And what are the contents of /etc/samba/smb.conf on the server ?
We'll worry about your laptop later
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #10 on: April 15, 2012, 04:43:50 pm »
Contents of smb.conf for the NAS:
« Reply #11 on: April 15, 2012, 05:05:40 pm »
Add a new section at the bottom that reads:-
# NAS shares - added by BkS
[NAS Shares]
   path = /home/bks/NAS-Shares
;   available = yes
;   browseable = yes
   guest ok = yes
   writeable = yes
Save the file.
Restart samba:
sudo service smbd restart
Now go to your laptop .. open the pcmanfm file manager .. in the address bar, enter:
smb://192.168.0.8
and hit enter.
What is visible ?
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #12 on: April 15, 2012, 05:16:54 pm »
I got errors.
Failed to retrieve share list from server
The specified location is not mounted
« Reply #13 on: April 15, 2012, 05:20:40 pm »
When did you get that ?
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #14 on: April 15, 2012, 05:21:39 pm »
When I put smb://192.168.0.8 into the address bar in pcmanfm
