Author Topic: Mounting hard-drives from external sources. [Solved]  (Read 3660 times)
Re: Mounting hard-drives from external sources.
« Reply #30 on: April 15, 2012, 10:10:26 pm »
Besides which, my missus says I'm good at over complicating things .. so why change what I'm "good at" ;)
« Last Edit: April 15, 2012, 10:35:54 pm by Mark Greaves (PCNetSpec) »
« Reply #31 on: April 15, 2012, 10:37:07 pm »
She also says I like to be "right" all the time .. so I'll shut up now, just to prove her wrong .. erm, now I'm confused  :o
Offline SeZo
« Reply #32 on: April 15, 2012, 10:42:46 pm »
You are not alone. I get that from my missus too.
As a minor point, should BkS follow your instructions then what would stop other users creating folders in the NAS (writable) folder: :)
[NAS]
 path = /home/share/NAS
 writeable = yes
 guest ok = yes
 guest only = yes
 create mode = 0777
 directory mode = 0777
 share mode = 0777
« Reply #33 on: April 15, 2012, 10:48:57 pm »
Hmm .. good point.
See, I'm not always right .. so she must be wrong .. does that make me right again .. doh! ???
« Last Edit: April 15, 2012, 10:51:29 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #34 on: April 15, 2012, 10:52:41 pm »
I can see "Share" & "Wallpapers" in smb://192.168.0.8/share
However I get denied permission to create any files. In either directory.
« Reply #35 on: April 15, 2012, 11:13:34 pm »
Let's start again and do it SeZo's way .. as he pointed out there is a glaring hole (that allows users to write to your main system hard drive) in my solution  :-[
what are the contents of:
nano /etc/fstab
and the output from:
ls -a /mnt
ls -a /home/share
and the contents of:
nano /etc/samba/smb.conf
and we'll get it right this time :)
His way will also allow you to put stuff on those drives that ISN'T shared if you ever wanted to.
« Last Edit: April 15, 2012, 11:23:15 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #36 on: April 15, 2012, 11:20:51 pm »
*sighs*... ok.
# Use 'blkid -o value -s UUID' to print the universally unique identifier
# for a device; this may be used with UUID= as a more robust way to name
# devices that works even if disks are added and removed. See fstab(5).
proc            /proc           proc    nodev,noexec,nosuid 0       0
# / was on /dev/sda1 during installation
UUID=ff0a5255-09f5-4b23-a2d2-8db9cebc726d /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda5 during installation
UUID=652469de-ef92-47ea-8e42-25deb43687fe none            swap    sw              0       0
/dev/sdb1 /mnt/share/NAS/Main_Drive       ext3       rw,errors=remount-ro       0       0
/dev/sdc1 /mnt/Wallpapers       ext3       rw,errors=remount-ro       0       0
bks@bally-server:~$ ls -a /mnt
.  ..  NAS-200GB  NAS-20GB
bks@bally-server:~$ ls -a /home/share
.  ..  it-works.txt  NAS
smb.conf contents:
(click to show/hide)
« Reply #37 on: April 16, 2012, 12:23:41 am »
Firstly .. I know why you couldn't write to those shares .. the last 2 lines in your fstab were totally wrong .. those directories don't exist, so the partitions wouldn't have been getting mounted at all  :o
OK .. editing fstab ..
sudo nano /etc/fstab
edit the last 2 lines, so it reads:-
/dev/sdb1 /mnt/NAS-200GB       ext3       rw,errors=remount-ro       0       0
/dev/sdc1 /mnt/NAS-20GB       ext3       rw,errors=remount-ro       0       0
SAVE fstab
reload fstab
sudo mount -a
create the 2 "share" directories .. and make them writeable by everyone:
sudo mkdir /mnt/NAS-20GB/share
sudo mkdir /mnt/NAS-200GB/share
sudo chmod 777 /mnt/NAS-20GB/share
sudo chmod 777 /mnt/NAS-200GB/share
Editing smb.conf -
REMOVE (or comment out) the section I've highlighted in RED
and add the 2 new sections I've highlighted in GREEN at the bottom.
sudo nano /etc/samba/smb.conf
SAVE the file.
REBOOT the server.
On the laptop ..
When the server has rebooted .. (on the laptop) log off, and on again.
Now try:-
smb://192.168.0.8/
What can you see ?
If as expected you can see the Share and Wallpapers directories, can you write to them ?
Only do this once everything is working (or you can just leave them .. up to you) ..
cleaning up the old attempts -
sudo rm -r /home/bks/NAS-Shares
sudo rm -r /home/share/NAS
If you'd rather use UUID's than /dev/sdXY in fstab .. let me know, and send the output from:
blkid
You can still do all the above first .. then change to UUID's later, once it's all working.
@SeZo
Before you shout at me for changing the mount points back .. I KNOW it wasn't 100% necessary .. I'm just putting them back in /mnt where they belong ;)
« Last Edit: April 16, 2012, 01:33:02 am by Mark Greaves (PCNetSpec) »
Offline SeZo
« Reply #38 on: April 16, 2012, 09:10:24 am »
I would not dream of shouting at you. :D
On the other hand, it might be worth (to start with) to un-comment the ' security = share' in smb.conf
to allow access by others on the Lan without the need for user/password
####### Authentication #######
# "security = user" is always a good idea. This will require a Unix account
# in this server for every user accessing the server. See
# /usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/ServerType.html
# in the samba-doc package for details.
#   security = share
security = share
Also there is a mismatch in the directories:
/mnt/NAS-20GB/shared
/mnt/NAS-200GB/shared
in the smb.conf
« Last Edit: April 16, 2012, 10:15:58 am by SeZo »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #39 on: April 16, 2012, 11:42:18 am »
I can see the directories, although I cannot enter them. I get the same errors as before. and yes I fixed his error.
« Last Edit: April 16, 2012, 11:48:27 am by BkS »
« Reply #40 on: April 16, 2012, 12:45:22 pm »
Gonna need the contents of fstab and smb.conf again.
plus the output from
ls -l /mnt
ls -l /mnt/NAS-20GB
ls -l /mnt/NAS-200GB
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #41 on: April 16, 2012, 02:16:12 pm »
fstab:
smb.conf
bks@bally-server:~$ ls -l /mnt
total 8
drwx------ 4 bks bks 4096 2012-04-16 11:21 NAS-200GB
drwx------ 4 bks bks 4096 2012-04-16 11:21 NAS-20GB
bks@bally-server:~$ ls -l /mnt/NAS-20GB
total 20
drwx------ 2 root root 16384 2012-04-14 13:05 lost+found
drwxrwxrwx 2 root root  4096 2012-04-16 11:21 share
bks@bally-server:~$ ls -l /mnt/NAS-200GB
total 20
drwx------ 2 root root 16384 2012-04-14 13:08 lost+found
« Reply #42 on: April 16, 2012, 02:37:21 pm »
OK, let's try this:-
and change
# NAS-20GB added by BkS
[Wallpapers]
comment = Wallpapers Folder
path = /mnt/NAS-20GB/share
available = yes
browseable = yes
public = yes
writable = yes
create mask = 0777
directory mask = 0777
# NAS-200GB added by BkS
[Share]
comment = Public Folder
path = /mnt/NAS-200GB/share
available = yes
browseable = yes
public = yes
writable = yes
create mask = 0777
to
[Wallpapers]
writeable = yes
guest ok = yes
guest only = yes
create mode = 0777
share mode = 0777
[Share]
writeable = yes
guest ok = yes
guest only = yes
create mode = 0777
share mode = 0777
SAVE smb.conf
reboot both machines .. and try again.
If that doesn't work .. leave it like that .. and send the output from
ls -l /home
mount
« Last Edit: April 16, 2012, 03:15:11 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #43 on: April 16, 2012, 03:33:56 pm »
Can't access them again. Same errors.
Failed to mount Windows share
The specified location is not mounted
bks@bally-server:~$ ls -l /home
total 8
drwxr-xr-x 27 bks  bks  4096 2012-04-15 17:57 bks
drwxrwxrwx  3 root root 4096 2012-04-15 22:45 share
bks@bally-server:~$ mount
/dev/sda1 on / type ext4 (rw,errors=remount-ro)
none on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /dev type devtmpfs (rw,mode=0755)
none on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
none on /dev/shm type tmpfs (rw,nosuid,nodev)
none on /var/run type tmpfs (rw,nosuid,mode=0755)
none on /var/lock type tmpfs (rw,noexec,nosuid,nodev)
none on /lib/init/rw type tmpfs (rw,nosuid,mode=0755)
/dev/sdb1 on /mnt/NAS-200GB type ext3 (rw,errors=remount-ro)
/dev/sdc1 on /mnt/NAS-20GB type ext3 (rw,errors=remount-ro)
« Last Edit: April 16, 2012, 03:36:02 pm by BkS »
« Reply #44 on: April 16, 2012, 04:07:14 pm »
Hmm .. that *should* be working ??? .. everything is set up exactly the way the original /home/share which worked ???
Gimme a while to test whether it's sambs not liking the "-" in the file names NAS-20GB and NAS-200GB
I know it didn't like them when I tested sommat like smb:// 172.16.0.2/test-directory (kept getting replaced with smb://172.16.0.2/test%25directory .. or similar)
maybe it doesn't like then in the "path =" line either.
I'll get back to you shortly.
« Last Edit: April 16, 2012, 04:09:33 pm by Mark Greaves (PCNetSpec) »
