Author Topic: Mounting hard-drives from external sources. [Solved]  (Read 3641 times)
Re: Mounting hard-drives from external sources.
« Reply #45 on: April 16, 2012, 05:15:15 pm »
First, it's NOT the "-" in the path as I wondered earlier ???
I'm now somewhat baffled as to why that doesn't work ..
I just created
/mnt/NAS-20GB/share
/mnt/NAS-200GB/share
on my 11.10 box .. made them both (777) writeable by everyone.
put:-
# NAS-20GB added by BkS
[Wallpapers]
comment = Wallpapers Folder
path = /mnt/NAS-20GB/share
writeable = yes
guest ok = yes
guest only = yes
create mode = 0777
directory mode = 0777
share mode = 0777
# NAS-200GB added by BkS
[Share]
comment = Public Folder
path = /mnt/NAS-200GB/share
writeable = yes
guest ok = yes
guest only = yes
create mode = 0777
share mode = 0777
in my smb.conf
REBOOTED the server.
REBOOTED the PeppermintOS netbook
Now if (on the netbook) I open pcmanfm and enter smb://172.16.0.2/
I can see (and write to) "Share" and "Wallpapers"
so it SHOULD be working on your system. ???
did you reboot BOTH the server and laptop ?
have you tried accessing the shares on another PC .. to rule out your Peppermint PC as the culprit ?
« Last Edit: April 16, 2012, 05:32:18 pm by Mark Greaves (PCNetSpec) »
« Reply #46 on: April 16, 2012, 05:39:34 pm »
Quick question ,,
When I ask for the contents of fstab, smb.conf, etc, ... you ARE getting them from the server aren't you, and not just cobbling then together from what's  been posted earlier ?
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #47 on: April 16, 2012, 05:56:27 pm »
Yes I rebooted both. I've tried on my brothers Ubuntu box and my mums partners Win7 box. Both of them can't access the directories either.
Yeah I'm getting them from terminal.
« Reply #48 on: April 16, 2012, 06:10:38 pm »
OK .. lets go through this one step at a time.
I know I've asked for them before, but post the contents of:-
sudo nano /etc/samba/smb.conf
sudo nano /etc/fstab
and the output from:
mount
ls -l /mnt/NAS-20GB
ls-l /mnt/NAS-200GB
sudo fdisk -l
can you also try this:
mkdir /mnt/NAS-200GB/share/testdir
I just want to know if this works.
Meanwhile .. I'll test if the fstab entries make a difference by formatting a USB stick as ext3 and mounting it from fstab as /mnt/NAS-200GB  then creating a dir on it called share .. in the same way as you are, and see what happens.
« Last Edit: April 16, 2012, 06:20:49 pm by Mark Greaves (PCNetSpec) »
Offline SeZo
« Reply #49 on: April 16, 2012, 06:20:35 pm »
@BkS
Try this:
sudo chmod -R 777 /mnt/NAS-20GB
sudo chmod -R 777 /mnt/NAS-200GB
Reboot NAS and see if that makes any difference
« Reply #50 on: April 16, 2012, 06:37:30 pm »
Yup .. listen to SeZo .. I just made the same setup with a USB stick, and the directory was unreadable, till I -
sudo chmod 777 /mnt/NAS-200GB
then it WAS readable.
Still dunno why it needs  that though ???
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #51 on: April 16, 2012, 06:41:34 pm »
(click to show/hide)
mount
ls -l /mnt/NAS-20GB
ls-l /mnt/NAS-200GB
sudo fdisk -l
Yes I can make that directory:
bks@bally-server:~$ ls /mnt/NAS-200GB/share/
testdir
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #52 on: April 16, 2012, 06:52:11 pm »
SeZo, you deserve a medal. :D
It works now!
« Reply #53 on: April 16, 2012, 06:54:13 pm »
I'm still wondering WHY that worked though ?
I considered it earlier, but could see no reason for it ???
Offline SeZo
« Reply #54 on: April 16, 2012, 07:04:45 pm »
Medals???
Didn't know they are giving those out here.
Lucky guess I suppose. Mark has done all the work, thank him.
I am guessing that when you CHMOD a file or folder, some servers require you also CHMOD
the folder holding it to the same level of permissions for it to work. ???
« Reply #55 on: April 16, 2012, 07:12:38 pm »
Well it certainly "looks" that way .. just a bit baffled by it though.
I'm guessing it's a Samba quirk, because I've never had to do that when mounting across the network with cifs or even smbfs (or obviously locally).
Weird  :o
Quote from: SeZo
Medals???
The forum has got an "Awards" feature, with piccies of medals .. we've just not implemented it .. to tell the truth, I've not looked into how t works.
These are the awards ;)
Quote from: SeZo
SeZo, you may as well accept the thanks, not only did you come up with the answer, but he doesn't thank me any more [snivel] .. one of us may as well get thanked ;)
Just pulling your leg BkS :)
« Last Edit: April 16, 2012, 08:20:48 pm by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #56 on: April 16, 2012, 07:40:48 pm »
LOL, "Asshole of the month". That's brilliant.
« Reply #57 on: April 16, 2012, 07:47:17 pm »
Yeh .. I've wanted to use that one before.
Remember this:
http://linuxforums.org.uk/index.php?topic=2552.msg61331#msg61331
and the topic that prompted that ?
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #58 on: April 16, 2012, 07:51:19 pm »
Oh how he/she deserved that award. You were going of your head lol. I still have the PM's XD
« Reply #59 on: April 16, 2012, 07:55:47 pm »
