Author Topic: [SOLVED] HPLIP - No System Tray  (Read 73422 times)
Offline pooky2483
« on: August 03, 2012, 05:32:46 pm »
I just installed Ubuntu 12.04 and after sorting out some other problems, I now have this problem;
No system tray for HPLIP.
running Gnome, rebooted quite a few times, so this problem is new.
« Last Edit: August 04, 2012, 12:35:52 pm by pooky2483 »
Kubuntu 14.04LTS 64bit|KDE 4.14.13|QT 4.8.6|Linux 4.2.0-42-generic|M5A78L-M USB3|BIOS 2101|AMD PhenomII X4 965 3400+|P8H77-I Motherboard NIC|32.0GB PC3-10600 1333Mhz CL9 ( 9-9-9-24 ) DDR3
Re: HPLIP - No System Tray
« Reply #1 on: August 03, 2012, 08:18:21 pm »
Gnome shell, or Gnome classic ?
Can you reboot and check you're still getting this error.
« Last Edit: August 03, 2012, 08:26:32 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #2 on: August 03, 2012, 08:53:35 pm »
It's Gnome Classic, theres no normal Gnome installed, theres Gnome Classic (No Effects) too
I just logged out and back in and got the same error as above screenshot
« Reply #3 on: August 03, 2012, 09:09:26 pm »
What happens if you NOW run:
hp-systray
Does it start ? .. if so, you need to edit the command for the hp-systray item in startup applications from:-
hp-systray
to
sh -c "sleep 15; exec hp-systray"
It seems like hp-systray is attempting to start before the system tray is loaded .. changing that command will introduce a 15 second delay in starting hp-systray, giving the system tray time to come up first.
If you're not sure how to change the hp-systray startup applications command line .. ask.
« Last Edit: August 03, 2012, 09:13:54 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #4 on: August 03, 2012, 09:17:14 pm »
I got this and it did start, theres the icon in the top corner.
pooky2483@pooky2483-ubuntu12:~$ hp-systray
HP Linux Imaging and Printing System (ver. 3.12.2)
System Tray Status Service ver. 2.0
Copyright (c) 2001-9 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/__init__.py:127: RuntimeWarning: PyOS_InputHook is not available for interactive use of PyGTK
  set_interactive(1)
« Reply #5 on: August 03, 2012, 09:23:14 pm »
Above is what you need to do then.
Offline pooky2483
« Reply #6 on: August 04, 2012, 02:58:24 am »
Don't get you???
« Reply #7 on: August 04, 2012, 11:10:11 am »
Did you change the command in the hp-systray startup application entry (as described above) .. or not ?
if so, did it work upon a reboot ?
in other words .. is this now solved ?
Offline pooky2483
« Reply #8 on: August 04, 2012, 12:35:30 pm »
