Author Topic: Ralink wireless card does not work [SOLVED]  (Read 82705 times)
Re: Ralink wireless card does not work [SOLVED]
« Reply #165 on: October 19, 2013, 10:06:23 pm »
You can't currently compile rt3290sta in kernels after 3.2
What is the output from:
sudo lshw -C network
iwconfig
rfkill list
sudo iwlist scanning
Offline vinea
« Reply #166 on: April 28, 2015, 08:12:56 am »
I also did the first page steps and though nothing seems to go wrong I don't have a stable wireless internet connection. I'm with Ubuntu 14.04 and I'm using an hp Probook 430 2G. What driver should I use?
« Reply #167 on: April 28, 2015, 10:50:13 am »
Can you post the output from the 4 commands in my last response above.
Offline vinea
« Reply #168 on: April 28, 2015, 03:47:42 pm »
Hi again,
This is what I get from the sudo lshw -C network :
  *-network
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       physical id: 0
       bus info: pci@0000:08:00.0
       logical name: eth0
       version: 10
       serial: 38:63:bb:cc:c7:a1
       capacity: 1Gbit/s
       width: 64 bits
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-3_0.0.1 04/23/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:63 ioport:4000(size=256) memory:c0504000-c0504fff memory:c0500000-c0503fff
  *-network
       product: RTL8723BE PCIe Wireless Network Adapter
       physical id: 0
       bus info: pci@0000:09:00.0
       logical name: wlan0
       version: 00
       serial: 10:08:b1:fa:20:23
       width: 64 bits
       configuration: broadcast=yes driver=rtl8723be driverversion=3.16.0-34-generic firmware=N/A ip=192.168.1.113 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
       resources: irq:19 ioport:3000(size=256) memory:c0400000-c0403fff
from the iwconfig:
wlan0     IEEE 802.11bgn  ESSID:"TeliaGateway00-1F-9F-98-DC-A1"
          Mode:Managed  Frequency:2.462 GHz  Access Point: 00:1F:9F:98:DC:A1
          Bit Rate=18 Mb/s   Tx-Power=20 dBm
          Retry short limit:7   RTS thr=2347 B   Fragment thr:off
          Power Management:off
          Link Quality=66/70  Signal level=-44 dBm
          Tx excessive retries:0  Invalid misc:668   Missed beacon:0
from rfkill list:
	Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
and from sudo iwlist scanning:
                    IE: Unknown: 010882848B968C129824
                    IE: Unknown: 03010B
                    IE: Unknown: 0706444520010D14
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                    IE: Unknown: 3204B048606C
                    IE: Unknown: 2D1AEF111BFFFFFF0000000000000000000000000000000000000000
                    IE: Unknown: 331AEF111BFFFFFF0000000000000000000000000000000000000000
                    IE: Unknown: 3D160B080400000000000000000000000000000000000000
                    IE: Unknown: 34160B080400000000000000000000000000000000000000
                    IE: Unknown: 7F0101
                    IE: Unknown: DD180050F2020101820003A4000027A4000042435E0062322F00
                    IE: Unknown: DD7C0050F204104A00011010440001021057000101103B0001031047001000000000000010000000B8A3865A101010210006442D4C696E6B1023000D442D4C696E6B20526F75746572102400074449522D383537104200046E6F6E651054000800060050F2040001101100074449522D383537100800020080103C000103
          Cell 19 - Address: 16:9A:DD:86:A2:99
                    Channel:11
                    Quality=36/70  Signal level=-74 dBm
                    Encryption key:on
                    ESSID:"bo lindbergs G\xC3\xA4stn\xC3\xA4tverk"
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Mode:Master
                    Extra:tsf=00002d0bed250160
                    Extra: Last beacon: 172ms ago
                    IE: Unknown: 001A626F206C696E6462657267732047C3A473746EC3A4747665726B
                    IE: Unknown: 03010B
                    IE: Unknown: 050400030000
                    IE: Unknown: 0706534520010D1E
                    IE: Unknown: 2A0100
                    IE: Unknown: 32043048606C
                        Group Cipher : CCMP
                    IE: Unknown: 2D1AAC4117FFFFFF0000000000000000000000000000000000000000
                    IE: Unknown: 3302742C
                    IE: Unknown: 3D160B001100000000000000000000000000000000000000
                    IE: Unknown: 46050200010000
                    IE: Unknown: DD180050F2020101020003A4000027A4000042435E0062322F00
                    IE: Unknown: DD0700039301720208
                    IE: Unknown: DD0E0017F20700010106109ADD86A299
          Cell 20 - Address: 16:9A:DD:88:C7:B5
                    Channel:11
                    Quality=44/70  Signal level=-66 dBm
                    Encryption key:on
                    ESSID:"yvonneihmels G\xC3\xA4stn\xC3\xA4tverk"
                    Mode:Master
                    Extra:tsf=000016786cab7972
                    Extra: Last beacon: 8ms ago
                    IE: Unknown: 001A79766F6E6E6569686D656C732047C3A473746EC3A4747665726B
                    IE: Unknown: 03010B
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
                    IE: Unknown: 33027424
                    IE: Unknown: DD0E0017F20700010106109ADD88C7B5
          Cell 21 - Address: 58:6D:8F:F1:A1:0B
                    Channel:11
                    Quality=40/70  Signal level=-70 dBm
                    Encryption key:on
                    ESSID:"WordWorks"
                    Mode:Master
                    Extra:tsf=000001460ec213c3
                    Extra: Last beacon: 920ms ago
                    IE: Unknown: 0009576F7264576F726B73
                    IE: Unknown: 03010B
                    IE: Unknown: 0406000200000000
                    IE: Unknown: 050400010000
                    IE: Unknown: 2A0100
                        Group Cipher : TKIP
                    IE: Unknown: 2D1AFE1117FFFFFF0000000000000000000000000000000000000000
                    IE: Unknown: 3D160B070500000000000000000000000000000000000000
                    IE: Unknown: 4A0E14000A00B400C800140005001900
                    IE: Unknown: 7F0101
                    IE: Unknown: DD1E00904C33FE1117FFFFFF0000000000000000000000000000000000000000
                    IE: Unknown: DD1A00904C340B070500000000000000000000000000000000000000
                    IE: Unknown: DD06005043030000
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (1) : TKIP
                    IE: Unknown: DD1D0050F204104A0001101044000102103C0001011049000600372A000120
          Cell 22 - Address: 68:A8:6D:5C:9A:81
                    Channel:11
                    Quality=42/70  Signal level=-68 dBm
                    Encryption key:on
                    ESSID:"AIRPORTX"
                    Mode:Master
                    Extra:tsf=0000000e2981b177
                    Extra: Last beacon: 132ms ago
                    IE: Unknown: 0008414952504F525458
                    IE: Unknown: 03010B
                    IE: Unknown: 050401030000
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
                    IE: Unknown: 2D1A2C4017FFFF000000000000000000000000000000000000000000
                    IE: Unknown: DD180050F2020101010003A4000027A4000042435E0062322F00
                    IE: Unknown: DD07000393016B0B20
                    IE: Unknown: DD0E0017F2070001010668A86D5C9A81
                    IE: Unknown: DD0B0017F20100010100000007
          Cell 23 - Address: 00:1F:F3:C1:46:60
                    Channel:12
                    Frequency:2.467 GHz (Channel 12)
                    Quality=30/70  Signal level=-80 dBm
                    Encryption key:on
                    ESSID:"Thems-5G"
                    Mode:Master
                    Extra:tsf=00000076c1e14180
                    Extra: Last beacon: 388ms ago
                    IE: Unknown: 00085468656D732D3547
                    IE: Unknown: 03010C
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
                    IE: Unknown: 2D1A0C501BFFFF000000000000000000000000000000000000000000
                    IE: Unknown: 33025103
                    IE: Unknown: 3D160C001700000000000000000000000000000000000000
                    IE: Unknown: DD180050F20201010B0003A4000027A4000042435E0062322F00
                    IE: Unknown: DD0700039301690320
                    IE: Unknown: DD0E0017F20700010106001FF3C14660
                    IE: Unknown: DD0B0017F20100010101000003
          Cell 24 - Address: 50:46:5D:91:DB:00
                    Channel:4
                    Frequency:2.427 GHz (Channel 4)
                    Encryption key:on
                    ESSID:"kermit"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
                              18 Mb/s; 36 Mb/s; 54 Mb/s
                    Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s
                    Mode:Master
                    Extra:tsf=0000085256f720b1
                    IE: Unknown: 00066B65726D6974
                    IE: Unknown: 010882848B961224486C
                    IE: Unknown: 030104
                    IE: Unknown: 2A0106
                    IE: Unknown: 32040C183060
                    IE: Unknown: 2D1AEE1117FFFF0000010000000000000000000000000C0000000000
                    IE: Unknown: 3D1604000500000000000000000000000000000000000000
                    IE: Unknown: 3E0100
                        Group Cipher : CCMP
                    IE: Unknown: 0B05010061127A
                    IE: Unknown: 7F0101
                    IE: Unknown: DD07000C4307000000
                    IE: Unknown: 0706474220010D10
                    IE: Unknown: DD8F0050F204104A0001101044000102103B000103104700102880288028801880A88050465D91DB00102100154153555354654B20436F6D707574657220496E632E1023000A57505320526F757465721024000752542D4E3635551042000830303030303030301054000800060050F20400011011000F415355532057505320526F7574657210080002210C103C000101
          Cell 25 - Address: 00:18:E7:DF:E9:A4
                    Channel:4
                    Encryption key:on
                    ESSID:"hp-2011"
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
                    Mode:Master
                    Extra:tsf=00000007975f2180
                    Extra: Last beacon: 2464ms ago
                    IE: Unknown: 000768702D32303131
                    IE: Unknown: 010482848B96
                    IE: Unknown: 030104
                    IE: Unknown: 2A0100
                    IE: Unknown: 32080C1218243048606C
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : TKIP CCMP
                    IE: WPA Version 1
                        Group Cipher : TKIP
                    IE: Unknown: DD070050F202000100
                    IE: Unknown: 2D1A4C101BFFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D160400190000000F000000000000000000000000000000
                    IE: Unknown: DD1E00904C336C101BFFFF000000000000000000000000000000000000000000
                    IE: Unknown: DD1A00904C340400010000000F000000000000000000000000000000
                    IE: Unknown: DD0E0050F204104A0001101044000102
          Cell 26 - Address: 34:21:09:0E:7E:FC
                    Channel:11
                    Encryption key:on
                    ESSID:"lew1"
                    Mode:Master
                    Extra:tsf=000001a69b472feb
                    Extra: Last beacon: 1384ms ago
                    IE: Unknown: 00046C657731
                    IE: Unknown: 03010B
                    IE: Unknown: 0706474200010D14
                    IE: Unknown: 33082001020304050607
                    IE: Unknown: 33082105060708090A0B
                    IE: Unknown: DD270050F204104A000110104400010210470010BC329E001DD811B286013421090E7EFC103C000101
                    IE: Unknown: 0504010300F0
                    IE: Unknown: 2A0104
                    IE: Unknown: 3D160B000500000000000000000000000000000000000000
                        Group Cipher : CCMP
                       Preauthentication Supported
                    IE: Unknown: DD180050F2020101064003A4000027A4000042435E0062322F00
                    IE: Unknown: 0B0502006D127A
                    IE: Unknown: DD07000C4304000000
          Cell 27 - Address: 34:08:04:D9:34:44
                    Channel:6
                    Quality=32/70  Signal level=-78 dBm
                    Encryption key:on
                    ESSID:"inetkontakt"
                    Mode:Master
                    Extra:tsf=0000004e4046815b
                    Extra: Last beacon: 2452ms ago
                    IE: Unknown: 000B696E65746B6F6E74616B74
                    IE: Unknown: 030106
                    IE: Unknown: DD050050F20500
                    IE: Unknown: 2A0100
                    IE: Unknown: 3D1606000100000000000000000000000000000000000000
                    IE: Unknown: 7F0101
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Group Cipher : TKIP
                    IE: Unknown: 0B0500005D127A
                    IE: Unknown: DD1E00904C33EE1117FFFF0000010000000000000000000000000C0000000000
                    IE: Unknown: DD1A00904C3406000100000000000000000000000000000000000000
          Cell 28 - Address: D8:50:E6:CB:C4:D8
                    Channel:6
                    Quality=50/70  Signal level=-60 dBm
                    Encryption key:on
                    ESSID:"acme.net"
                              24 Mb/s; 36 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=0000002d8475d535
                    IE: Unknown: 000861636D652E6E6574
                    IE: Unknown: 030106
                    IE: Unknown: 2A0100
                    IE: Unknown: 2F0100
                        Group Cipher : CCMP
                    IE: Unknown: 32040C121860
                    IE: Unknown: 2D1ABD1917FFFFFF0000000000000000000000000000000000000000
                    IE: Unknown: 3D1606081500000000000000000000000000000000000000
                    IE: Unknown: 7F080100000000000040
                    IE: Unknown: DD090010180201001C0000
                    IE: Unknown: DD180050F2020101840003A4000027A4000042435E0062322F00
          Cell 29 - Address: 20:E5:2A:00:D8:71
                    Channel:6
                    Encryption key:on
                    ESSID:"NETGEAR62"
                    Mode:Master
                    Extra:tsf=0000000000000000
                    IE: Unknown: 00094E4554474541523632
                    IE: Unknown: 030106
                    IE: Unknown: 2A0100
                    IE: Unknown: 2F0100
                        Group Cipher : CCMP
                    IE: Unknown: 2D1AFC181BFFFF000000000000000000000000000000000000000000
                    IE: Unknown: DD840050F204104A00011010440001021041000100103B000103104700104933272F01A17C01E70C41A1AF9B19921021000D4E4554474541522C20496E632E1023000A574E44523337303076331024000A574E44523337303076331042000230311054000800060050F20400011011000A574E4452333730307633100800020084103C000103
                    IE: Unknown: DD090010180202F02C0000
          Cell 30 - Address: 00:24:01:90:D6:3C
                    Channel:6
                    Quality=48/70  Signal level=-62 dBm
                    Encryption key:on
                    ESSID:"tere"
                    Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s; 18 Mb/s
                    Mode:Master
                    Extra:tsf=000000588194a1bd
                    IE: Unknown: 000474657265
                    IE: Unknown: 030106
                    IE: Unknown: 32080C1218602430486C
                    IE: Unknown: CC0700CC020000018A
                    IE: Unknown: CC0700CC0300000100
                    IE: WPA Version 1
                        Group Cipher : TKIP
          Cell 31 - Address: 70:73:CB:BC:F0:51
                    Channel:8
                    Frequency:2.447 GHz (Channel 8)
                    Encryption key:on
                    ESSID:"Larss Wi-Fi-n\xC3\xA4tverk"
                    Mode:Master
                    Extra:tsf=000006ce014ae444
                    IE: Unknown: 00144C617273732057692D46692D6EC3A4747665726B
                    IE: Unknown: 030108
                    IE: Unknown: 2A0100
                        Group Cipher : CCMP
                    IE: Unknown: 2D1AAD511BFFFFFF0000000000000000000000000000000000000000
                    IE: Unknown: 3D1608000000000000000000000000000000000000000000
                    IE: Unknown: DD0700039301740320
                    IE: Unknown: DD070017F203020180
                    IE: Unknown: DD0E0017F207000101067073CBBCF051
          Cell 32 - Address: 80:37:73:D7:E9:AA
                    Channel:10
                    Frequency:2.457 GHz (Channel 10)
                    Encryption key:on
                    ESSID:"NETGEAR82"
                    Mode:Master
                    Extra:tsf=0000064b19e3719b
                    Extra: Last beacon: 108ms ago
                    IE: Unknown: 00094E4554474541523832
                    IE: Unknown: 010882840B162430486C
                    IE: Unknown: 03010A
                    IE: Unknown: 050400020000
                    IE: Unknown: 2A0100
                    IE: Unknown: 2F0100
                        Group Cipher : CCMP
                    IE: Unknown: 2D1AFC181FFFFF000000000000000000000000000000000000000000
                    IE: Unknown: 3D160A001300000000000000000000000000000000000000
                    IE: Unknown: 7F0101
                    IE: Unknown: DD310050F204104A0001101044000102104700101034173EF6687DC61B10A46249696B61103C0001031049000600372A000120
                    IE: Unknown: DD090010180200F0040000
« Reply #169 on: April 28, 2015, 10:29:58 pm »
OK, try this...
Run:
sudo gedit /etc/modprobe.d/rtl8723be.conf
when a BLANK file opens, add a single line that reads
options rtl8723be fwlps=0 ips=0
SAVE the file and exit gedit
REBOOT
Test
On the offchance that kills your wireless, run:
sudo rm -v /etc/modprobe.d/rtl8723be.conf
and reboot .. and you'll be back to where you are now.
Offline vinea
« Reply #170 on: April 30, 2015, 07:39:38 am »
It works now ! Thank you so much !
« Reply #171 on: May 01, 2015, 03:58:23 am »
You're most welcome :)
