Author Topic: Installing Ubuntu One Sync in Peppermint 3  (Read 3638 times)
« on: November 06, 2012, 01:35:49 pm »
To install Ubuntu One (sync) in Peppermint 3 (LXDE)
Open a terminal and run:
sudo apt-get install desktopcouch-ubuntuone gir1.2-ubuntuoneui-3.0 python-ubuntuone-client python-ubuntuone-control-panel python-ubuntuone-storageprotocol ubuntuone-client ubuntuone-client-dbg ubuntuone-control-panel ubuntuone-control-panel-gtk ubuntuone-couch
It will show you a list of files that it's going to install .. read through it and make SURE these 2 packages are NOT included
ubuntuone-client-gnome
ubuntuone-client-gnome-dbg
If they are .. STOP NOW (by hitting n).. otherwise it will pull in a ton of GNOME dependencies including Nautilus.
If they are NOT in the list .. accept the changes (by hitting y)
Once that's done you will find Ubutnu One in the menu at - menu>Preferences>Ubuntu One
Click that, and you can sign in or set up an Ubuntu One accout .. if/when prompted to add a "Keyring Password" .. either leave them blank, and accept "Unsafe Storage", or be sure to use your Peppermint login password.
You'll now find a directory in you Home directory called Ubuntu One, which will sync whenever anything is put in it.
Offline SangNeeley
Re: Installing Ubuntu One Sync in Peppermint 3
« Reply #1 on: March 01, 2014, 08:48:38 am »
It will show you a list of files that it's going to solar panel install .. read through it and make SURE these 2 packages are NOT included
You'll now find a directory in you Home directory called Ubuntu One, which will sync whenever anything is put in it.[/u]
Thanks for sharing detailed installation process.. I have been searching for it for a while and finally got it..
« Last Edit: March 03, 2014, 04:55:32 pm by SangNeeley »
« Reply #2 on: March 01, 2014, 10:37:08 pm »
Glad they helped :)
