Author Topic: Peppermint OS 4 on Toshiba nb250  (Read 4773 times)
0 Members and 3 Guests are viewing this topic.
Offline goncaloq12
« on: November 12, 2013, 11:31:17 pm »
Hi guys, i have a toshiba nb250 netbook with windows 7 starter and it performs very poorly. I've been thinking about changing to linux, and I heard Peppermint OS is considered a very suitable OS for netbooks. Can I install it and keep both OS's? And would it result in slower pc performance, or should I delete Windows 7, even though I never used a Linux OS? What do you guys recommend? :D Thanks in advance guys.
Re: Peppermint OS 4 on Toshiba nb250
« Reply #1 on: November 13, 2013, 12:24:41 am »
There's *probably* nothing stopping you setting up a dual boot system .. but to be 100% sure, you'll need to create a LiveUSB stick, bnoot to it, and send the output from a couple of commands for us.
If you're unsure how to create a LiveUSB of Peppermint 4 .. see "Stage 1" here:
http://linuxforums.org.uk/index.php?topic=11109.0
DO NOT install Peppermint yet .. just create the LiveUSB and make sure you can boot to it selecting "Try Peppermint".
The reason I say don't install yet is I want to see the partition layout, and see if we'd be better off keeping the Windows bootloader .. so you don't loose access to the recovery partition.
Let us know when you've created and can boot the LiveUSB, and we'll go from there.....
Any questions, just ask ;)
BTW .. Welcome to the forum :)
Offline goncaloq12
« Reply #2 on: November 14, 2013, 03:00:03 pm »
Ok I booted Usb Loader and selected "Try Peppermint" and the mouse pad doesn't work, what should I do? Thanks man
« Reply #3 on: November 14, 2013, 11:59:46 pm »
Hmm, hat's a new one :)
Have you got a mouse you can use for a bit whilst we troubleshoot this ?
If so, hit Ctrl+Alt+T .. a terminal should open, run:
xinput list
and post the output back here.
Offline uniescie
« Reply #4 on: July 31, 2015, 09:12:43 pm »
hello there,
I googled this topic and decided that I can continue it where it finished :)
I run "Try Peppermint" from prepared previously USB installation of Peppermint OS 6.
My platform is Toshiba NB250 and my touchpad does not work either.
Here you have output from xinput list:
peppermint@peppermint ~ $ xinput list
⎡ Virtual core pointer                    id=2 [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              id=4 [slave  pointer  (2)]
⎣ Virtual core keyboard                    id=3 [master keyboard (2)]
    ↳ Virtual core XTEST keyboard              id=5 [slave  keyboard (3)]
    ↳ Power Button                            id=6 [slave  keyboard (3)]
    ↳ Video Bus                                id=7 [slave  keyboard (3)]
    ↳ Power Button                            id=8 [slave  keyboard (3)]
    ↳ Chicony USB 2.0 Camera                  id=9 [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard            id=10 [slave  keyboard (3)]
    ↳ Toshiba input device                    id=11 [slave  keyboard (3)]
« Reply #5 on: July 31, 2015, 09:28:58 pm »
Have you ever had any version of Linux working on your NB250 ? .. if so, which ?
Offline uniescie
« Reply #6 on: July 31, 2015, 10:57:14 pm »
no, never installed any linux on that machine
« Reply #7 on: August 01, 2015, 03:32:37 pm »
Can you open a tgerminal and post the output from running this command:
cat /proc/bus/input/devices
Offline uniescie
« Reply #8 on: August 01, 2015, 04:00:56 pm »
I have managed to get the touchpad working.
I downloaded Linux Mint 17.2 Rafaela and installed synaptics drivers and after restart touchpad is working.
Now I might need some assistance in installing Mint beside Windows as I want to have a dual boot on that netbook.
thanks in advance.
