Author Topic: Samsung Xpress C410W  (Read 6148 times)
Offline Rich J
  • Sr. Member
  • A Linux Luvvie!
« on: June 09, 2014, 11:09:38 pm »
Hi All
My old HP All-in-one has now been consigned to the bin and I've just taken delivery of the above.  I'd hoped that it would have been detected automatically on switch-on but no such luck!  The supplied cd-rom seems to be just for Windows and the installation sheets only refer to Samsung's site with reference to 'download' for Linux.  I've had a good look at the site but, frankly, can't make head nor tail of it!  :-[
Could anyone point me in the right direction as to installation, please?
Thanks in advance
Rich
Re: Samsung Xpress C410W
« Reply #1 on: June 10, 2014, 01:25:52 am »
Run these commmands in sequence:
mkdir ~/samsung-unified-linux-driver
cd ~/samsung-unified-linux-driver
wget http://downloadcenter.samsung.com/content/DR/201403/20140312110057137/ULD_V1.00.21.tar.gz
tar xvf ULD_V1.00.21.tar.gz
cd ~/samsung-unified-linux-driver/uld
sudo ./install.sh
hit "Enter" when prompted.
When you see "--More--" hit the spacebar until you get to:-
**** Do you agree ? [y/n] :
type "y" .. and hit enter.
type "Y" again at the "configure firewall" prompt .. and hit enter.
When finished, see if your printer is detected if you switch it off/on again.
If it doesn't configure automatically .. add the printer in the normal way, and try one of these drivers
Samsung_C410_Series
Samsung_CLP-410_Series
Offline Rich J
  • Sr. Member
  • A Linux Luvvie!
« Reply #2 on: June 10, 2014, 07:29:22 am »
Mark - WOW, that is impressive!  All set up (on usb cable) and running automatically after entering the code!
I'll have a play with my laptop's wireless connection and get back to you on that, if needs be?
Thanks a million!  (Shakes head in wonderment.........)
Rich
« Reply #3 on: June 10, 2014, 01:45:16 pm »
You're most welcome :)
Offline ukimiku
« Reply #4 on: April 25, 2016, 07:55:12 am »
thank you for this excellent help. My Samsung C410W started working at once after I had entered the commands you gave.
Regards,
« Reply #5 on: April 29, 2016, 02:26:06 am »
