Author Topic: Canon Pixma MG6150 doesn't want to talk to Mint 17 mate! (SOLVED)  (Read 10245 times)
Offline ahead
Hello, this is my first post. As an introduction, I have been using Linux Mint exclusively since 2010. I migrated from XP onto Mint 9 Isadora and have never looked back. I managed to install my Pixma MG 6150 onto isadora using WiFi. I seem to remember that it was very straight forward.
I have just upgraded to 17 Mate but can not get the printer to work.
On the 'localhost' the printer is featured when I click 'Add'. I found the URL of the printer by plugging the laptop I use into the printer's USB. The drivers are the same ones I used with Isadora.
2 things, when I attempt to print via the USB the printer starts to pick up the paper out of the tray, there is a clicking sound and after the fourth attempt an error comes up saying the tray is empty. The printer works perfectly when plugged into my son's computer (Win 7). When I try to print via WiFi I get errors saying 'Printer Not Found' or 'Printer not Connected' or 'There Was An Error During The CUPS Operation: Broken Pipe.' (???!!?)
Even though I am a long term Linux user I am not particularly knowledgeable about how it all works so if there is a remedy a reply in easy to understand language would be gratefully received!
Thank you.
« Last Edit: June 30, 2014, 11:43:40 pm by Mark Greaves (PCNetSpec) »
Re: Canon Pixma MG6150 doesn't want to talk to Mint 17 mate!
« Reply #1 on: June 17, 2014, 06:40:56 pm »
try this...
Delete all printers currently added to the system
Open a terminal and run these commands in sequence:
mkdir ~/printer-drivers
cd ~/printer-drivers
wget http://files.canon-europe.com/files/soft40261/Software/MG6100series-printer_driver.tar
tar xvf MG6100series-printer_driver.tar
tar xvf cnijfilter-mg6100series-3.40-1-deb.tar.gz
cd ~/printer-drivers/cnijfilter-mg6100series-3.40-1-deb
sudo ./install.sh
then follow the onscreen instructions.
For the scanner driver...
open a terminal and run:
mkdir ~/scanner-driver
cd ~/scanner-driver
wget http://files.canon-europe.com/files/soft40264/Software/MG6100series-scanner_driver.tar
tar xvf MG6100series-scanner_driver.tar
tar xvf scangearmp-mg6100series-1.60-1-deb.tar.gz
cd scangearmp-mg6100series-1.60-1-deb
sudo ./install.sh
and follow the onscreen instructions
Offline ahead
« Reply #2 on: June 18, 2014, 08:58:48 am »
Thanks Mark, I pasted all the commands into Terminal but after the 'Install' command and my password this happened:
tar.error is not recoverable:exiting now
sudo:./install.sh:command not found
graham@graham-calpella-platform~/printer-drivers $
Any ideas?
Thanks again. Graham.
« Last Edit: June 18, 2014, 09:23:20 am by ahead »
Offline ahead
« Reply #3 on: June 18, 2014, 10:51:24 am »
Mark I had another go with differing result! I opened all the drivers in my downloads.
I have attached the Terminal screenshot. I still can't access the printer. Strangely enough I got straight into it with Mint 9 with none of these problems.
Regards, Graham
« Reply #4 on: June 18, 2014, 11:59:30 am »
Install the  libtiff4 package:
sudo apt-get install libtiff4
then try again, with:
./install.sh
PS.
In the future it would be better if you copied the text from the terminal and pasted it into your posting rather than attach a screen shot ;)
« Last Edit: June 18, 2014, 12:11:22 pm by Mark Greaves (PCNetSpec) »
Offline ahead
« Reply #5 on: June 18, 2014, 05:05:14 pm »
Hello Mark, Thanks for that but still no joy. I will delete everything and have another go. I am getting a message that the printer can not be detected.
I rather wish now I had not updated the Mint 9 - it used to run like a quality Swiss watch!
Regards.
« Reply #6 on: June 18, 2014, 06:17:25 pm »
How is the printer attached, wireless or USB ?
Offline ahead
« Reply #7 on: June 18, 2014, 07:33:32 pm »
A laptop via WiFi - always worked a treat before so I'm hopeful it can work again. more to the point I'm very grateful for your help.
Regards
Offline ahead
« Reply #8 on: June 19, 2014, 07:36:08 pm »
Do you think it is possible to connect to this printer or is it a matter of complete incompatibility - in other words buy a dedicated printer for Linux that will work?
« Reply #9 on: June 19, 2014, 10:02:04 pm »
As far as I'm aware it *should* work .. just a matter of getting things right.
Can you be more descriptive about the message that the printer can't be detected .. what is telling you that ?
Does the printer work if connected via USB cable ?
Sorry that it's taking me a while between postings .. we've been busy testing Peppermint 5 ready for release .. the good news is it's pretty much done now, so I should be around more (touch wood) :)
« Last Edit: June 19, 2014, 10:05:34 pm by Mark Greaves (PCNetSpec) »
Offline ahead
« Reply #10 on: June 20, 2014, 02:07:11 pm »
Thanks Mark,
I have connected the printer via the USB and I get exactly the same messages as the WiFi attempt.
On opening a document, I click File> Print>  a print window opens with a green highlighted message saying:
Canon-PIXMA-MG 6150 unable to locate printer ''canon''
Also a small window opens in the top RHS of the screen saying:
Not connected? Printer Canon-Pixma MG6150 'may not be connected'
As I said I get exactly the same messages when I attempt to connect to the printer via WiFi.
« Reply #11 on: June 20, 2014, 02:41:13 pm »
can you connect the printer via USB cable, then open a terminal and post the output from:
lsusb
did the printer drivers install correctly when you followed my instructions ?
Offline ahead
« Reply #12 on: June 21, 2014, 10:35:42 am »
Mark, this is the result
Bus 002 Device 004: ID 04a9:174a Canon, Inc.
Bus 002 Device 003: ID 045e:07b2 Microsoft Corp.
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
graham@graham-Calpella-platform ~ $ lsusb
I don't know whether the drivers installed correctly, I followed your instructions - is there a way to check?
« Reply #13 on: June 21, 2014, 11:18:50 am »
OK, what's the output from:
uname -a
dpkg -l | grep cnijfilter
can you also, unlug the printer from the USB socket .. wait ten seconds .. replug the USB cable, then post the output from:
dmesg | tail -n 30
« Last Edit: June 21, 2014, 11:22:29 am by Mark Greaves (PCNetSpec) »
Offline ahead
« Reply #14 on: June 22, 2014, 08:54:55 am »
Hello Mark, this is the Terminal screen shot
graham@graham-Calpella-platform ~ $ uname -a
Linux graham-Calpella-platform 3.13.0-24-generic #46-Ubuntu SMP Thu Apr 10 19:11:08 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
graham@graham-Calpella-platform ~ $ dpkg -l | grep cnijfilter
ii  cnijfilter-common                           3.40-1                                              amd64        IJ Printer Driver for Linux.
graham@graham-Calpella-platform ~ $ dmesg | tail -n 30
[ 3263.127446] usb 2-1.6: New USB device found, idVendor=04a9, idProduct=174a
[ 3263.127451] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3263.127476] usb 2-1.6: Product: MG6100 series
[ 3263.127480] usb 2-1.6: Manufacturer: Canon
[ 3263.127483] usb 2-1.6: SerialNumber: 134F2F
[ 3263.198163] WARNING! power/level is deprecated; use power/control instead
[ 3263.262752] usb-storage 2-1.6:1.2: USB Mass Storage device detected
[ 3263.262935] scsi6 : usb-storage 2-1.6:1.2
[ 3263.263094] usbcore: registered new interface driver usb-storage
[ 3263.268943] usblp 2-1.6:1.1: usblp1: USB Bidirectional printer dev 4 if 1 alt 0 proto 2 vid 0x04A9 pid 0x174A
[ 3263.268987] usbcore: registered new interface driver usblp
[ 3264.261984] scsi 6:0:0:0: Direct-Access     Canon    MG6100 series    0104 PQ: 0 ANSI: 2
[ 3264.262379] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 3264.267792] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 3393.672132] usb 2-1.6: USB disconnect, device number 4
[ 3393.672421] usblp1: removed
[ 3409.746299] usb 2-1.6: new high-speed USB device number 5 using ehci-pci
[ 3409.842092] usb 2-1.6: New USB device found, idVendor=04a9, idProduct=174a
[ 3409.842097] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3409.842101] usb 2-1.6: Product: MG6100 series
[ 3409.842104] usb 2-1.6: Manufacturer: Canon
[ 3409.842107] usb 2-1.6: SerialNumber: 134F2F
[ 3409.849661] usblp 2-1.6:1.1: usblp1: USB Bidirectional printer dev 5 if 1 alt 0 proto 2 vid 0x04A9 pid 0x174A
[ 3409.849763] usb-storage 2-1.6:1.2: USB Mass Storage device detected
[ 3409.850080] scsi7 : usb-storage 2-1.6:1.2
[ 3410.852354] scsi 7:0:0:0: Direct-Access     Canon    MG6100 series    0104 PQ: 0 ANSI: 2
[ 3410.852948] sd 7:0:0:0: Attached scsi generic sg2 type 0
[ 3410.858268] sd 7:0:0:0: [sdb] Attached SCSI removable disk
[ 3411.064203] usblp1: removed
[ 3411.070654] usblp 2-1.6:1.1: usblp1: USB Bidirectional printer dev 5 if 1 alt 0 proto 2 vid 0x04A9 pid 0x174A
