Author Topic: Multiple distro setup  (Read 6279 times)
Offline rc_mandar
« on: July 09, 2014, 04:39:02 pm »
Hey guys,
I have been Windows user for a long time and finally i had courage to step on the right side. I have been using Ubuntu for 4 months now and i want more.
I have got myself a second laptop Thinkpad X121e in order to mess things around on a proper playground instead of destroying my work setup.
I have browsed a lot and i think i will install 3 distros to deepen my knowledge.
1) Debian kde --> http://ftp.halifax.rwth-aachen.de/de...ybrid/?C=S;O=A
2) Korora (also kde)
3) I m not sure :-(
please comment. Also i m not sure if the link i mentioned for debian installation is right or not.
Please reply.
Re: Multiple distro setup
« Reply #1 on: July 09, 2014, 06:47:59 pm »
Hi rc_mandar, and welcome to the forum :)
Not 100% sure what you're asking here, but.....
a) AFAIK a standard install of Debian will offer you different desktop environment as part of the install process.
https://wiki.debian.org/KDE
or there are Debian/KDE Live images available
http://cdimage.debian.org/debian-cd/current-live/i386/iso-hybrid/
and for 64bit
http://cdimage.debian.org/debian-cd/current-live/amd64/iso-hybrid/
b) Never heard of it, but as it's KDE I'll never really have looked ;)
c) Peppermint 5 .. but then I'm biased :)
« Last Edit: July 09, 2014, 06:53:39 pm by Mark Greaves (PCNetSpec) »
Offline chemicalfan
« Reply #2 on: July 10, 2014, 04:41:56 pm »
Are you familiar with virtual machines and using Virtualbox? You could save yourself a whole load of work if you're still "distro hopping"
Offline rc_mandar
« Reply #3 on: July 18, 2014, 03:13:48 pm »
Hello,
Since this post i was doing research to install debian fluxbox lightweight distro on my x121e Thinkpad. I did it and now i have just one problem.  See the second snap shot i can't access my two 60gb and 193 gb partitions.
Please reply :)
« Reply #4 on: July 18, 2014, 03:32:00 pm »
You're going to need to either -
a) automagically mount the partitions at bootup by adding the correct stanza(s) to /etc/fstab
b) run your file manager "as root" when you want to access them.
Offline rc_mandar
« Reply #5 on: July 18, 2014, 04:41:19 pm »
Yes a) part seems right.
Please tell me how. ANy link that i can read?
Please elaborate.
« Reply #6 on: July 18, 2014, 04:52:02 pm »
from the distro that can't mount the partitions, post the output from:
sudo fdisk -l
mount
and the contents of
gedit /etc/fstab
if gedit isn't your text editor, replace gedit with the name of your text editor in the last command.
BTW, on your desktop wallpaper, it looks like Batman is wearing a low cut dress and showing his bust/cleavage :)
Offline rc_mandar
« Reply #7 on: July 20, 2014, 04:13:42 pm »
so you mean in the following file:
# / was on /dev/sdb3 during installation
UUID=83a1615f-2063-4b0b-86e8-bd7262e3516b /               ext4    errors=remount-ro 0       1
# /boot was on /dev/sdb1 during installation
#UUID=01ff646f-7e68-4b6b-b9be-e6b26f496504 /boot           ext2    defaults        0       2
# swap was on /dev/sdb2 during installation
UUID=6a3d69b0-064a-4bdd-ad54-6ebfd916a68e none            swap    sw              0       0
/dev/sda1       /media/usb0     auto    rw,user,noauto  0       0
i should just add
/dev/sda5     /media         auto         rw,user
/dev/sda6     /media         auto         rw,user
is it? I am confused about the later part after /media
please help
Offline SeZo
« Reply #8 on: July 20, 2014, 04:54:50 pm »
It would be advantageous if you could also post the results of the two commands Mark asked for:
(That is a lower case L)
sudo fdisk -l
mount
Could you also post the whole content of the file /etc/fstab
cat /etc/fstab
« Reply #9 on: July 20, 2014, 05:42:48 pm »
First see SeZo's response above.
i should just add
Close but no cigar ;)
Post the output from the earlier commands we assked fo and we'll assist.
Offline rc_mandar
« Reply #10 on: July 20, 2014, 09:57:13 pm »
output 1:
sudo fdisk -l
Disk /dev/sda: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142448 sectors
Disk identifier: 0x0000f32c
/dev/sda1            2048     1026047      512000   83  Linux
/dev/sda2         1026048     9414655     4194304   82  Linux swap / Solaris
/dev/sda3   *     9414656    93300735    41943040   83  Linux
/dev/sda4        93302782   625141759   265919489    5  Extended
Partition 4 does not start on physical sector boundary.
/dev/sda5        93302784   219131903    62914560   83  Linux
/dev/sda6       219133952   625141759   203003904    7  HPFS/NTFS/exFAT
output 2: mount
mad@Xdeb:~$ mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,relatime,size=10240k,nr_inodes=713123,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=571744k,mode=755)
/dev/disk/by-uuid/83a1615f-2063-4b0b-86e8-bd7262e3516b on / type ext4 (rw,relatime,errors=remount-ro,user_xattr,barrier=1,data=ordered)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /run/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=1982340k)
/dev/sda1 on /boot type ext2 (rw,relatime,errors=continue,user_xattr,acl)
rpc_pipefs on /var/lib/nfs/rpc_pipefs type rpc_pipefs (rw,relatime)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
output 3:
sudo nano /etc/fstab
« Reply #11 on: July 20, 2014, 11:32:00 pm »
OK, we're going to create 2 mountpoints in /mnt for sda5 and sda6 then mount them through fstab.. what would you like to call the mountpoints ?
Something like
sda5 = <whatever distro is on it>
sda6 = windows
sudo blkid
Offline rc_mandar
« Reply #12 on: July 21, 2014, 03:53:00 pm »
mad@Xdeb:~$ sudo blkid
[sudo] password for mad:
/dev/sda1: LABEL="btldr" UUID="01ff646f-7e68-4b6b-b9be-e6b26f496504" TYPE="ext2"
/dev/sda2: UUID="6a3d69b0-064a-4bdd-ad54-6ebfd916a68e" TYPE="swap"
/dev/sda3: UUID="83a1615f-2063-4b0b-86e8-bd7262e3516b" TYPE="ext4"
/dev/sda5: LABEL="linux2" UUID="760b8214-cee3-4f7e-a7bb-0743ff806da9" TYPE="ext4"
/dev/sda6: LABEL="data" UUID="1C4167532131C952" TYPE="ntfs"
thank you so much Mark. I must say your help ( you had replied to my threads before as well) brought me closer to linux as an OS user. It gave me courage to stop using Windows.
« Reply #13 on: July 21, 2014, 07:47:53 pm »
OK, first make sure ntfs-3g is installed
sudo apt-get install ntfs-3g
then create the mountpoints .. run:
sudo mkdir -v /mnt/linux2
sudo mkdir -v /mnt/data
then let's backup fstab before editing
sudo cp -v /etc/fstab /etc/fstab.bak
now open fstab for editing:
sudo gedit /etc/fstab
and add these 4 lines at the end
## Auto-mounts added by mad ##
UUID=760b8214-cee3-4f7e-a7bb-0743ff806da9 /mnt/linux2    ext4    defaults    0    0
UUID=1C4167532131C952 /mnt/data    ntfs-3g    defaults,windows_name    0    0
## End auto-mounts added by mad ##
SAVE the file and exit gedit.
Back in the terminal,see if there are any errors if you run:
sudo mount -a
then see if your files are visible if you go to
/mnt/linux2
/mnt/data
If everything went well .. reboot to test the partitions are auto mounted
Obviously if gedit isn't your text editor, you'll have to adjust the commands to relace "gedit" with your text editor.
« Last Edit: July 21, 2014, 07:51:02 pm by Mark Greaves (PCNetSpec) »
Offline rc_mandar
« Reply #14 on: July 22, 2014, 07:23:48 am »
Well done! THanks for your support! I am happy tht i can now access my other partitions in deb.
However, in THunar the icons on left pane that were there previously 60gb and 193.6gb are disappeared.
May be now i have to take a closer look to THunar.  ???
Anyway, Mark please please can you tell me how can i modify grub to show my second linux distro in grub menu when my ATA HDD boots up?
any link? Tutorial?  ::)
