Author Topic: Setting up wireless printing  (Read 2762 times)
0 Members and 3 Guests are viewing this topic.
Offline pooky2483
« on: January 11, 2015, 01:20:02 pm »
I have this setup;
Kubuntu 14.04 wired connection to router
HP Officejet 4630 wired connection to Kubuntu 14.04
Peppermint 5 wired connection to router
HP Deskjet 3070A wired connection to Peppermint 5
Windows 7 laptop wireless connection to router
No printer connected
I want to be able to use either printer by either system wirelessly, how do I do it?
Kubuntu 14.04LTS 64bit|KDE 4.14.13|QT 4.8.6|Linux 4.2.0-42-generic|M5A78L-M USB3|BIOS 2101|AMD PhenomII X4 965 3400+|P8H77-I Motherboard NIC|32.0GB PC3-10600 1333Mhz CL9 ( 9-9-9-24 ) DDR3
Offline SeZo
Re: Setting up wireless printing
« Reply #1 on: January 11, 2015, 01:55:25 pm »
So what is stopping you printing AS-IS?
If you have samba installed and the printers shared then it should work.
Some instructions here
Offline pooky2483
« Reply #2 on: January 11, 2015, 06:15:59 pm »
I have some documents that need to be printed full page (borderless) yet the 4630 won't print borderless. I am having loads of trouble setting it up to print borderless.
I did manage to get the 3070 to print borderless but can't remember how I did it.
I know photo printing prints borderless but I somehow managed to get it to print draft/normal borderless.
I have been on HP's own forum and asked the same question and was told that I can only print borderless in PHOTO printing mode. I have hit a brick wall with help from them.
I want to be able to print borderless on all my printers as I dont want to have to keep using a USB stick to transfer files just so I can print it how I need it.
I have 2 options;;
1. Set up wireless printing
2. Set up borderless printing on my 4630
Offline pooky2483
« Reply #3 on: January 11, 2015, 06:26:20 pm »
Sezo, I've had a look at the instructions you gave the link to but I am totally lost.
For one, I do not have a 'Launcher' as I am running Kubuntu.
Offline pooky2483
« Reply #4 on: January 11, 2015, 09:16:47 pm »
I've been doing a bit of searching and discovered theres a GUI for CUPS. How do I install & use it as I am only able to use the web version of CUPS.
« Reply #5 on: January 11, 2015, 09:26:28 pm »
what's the output from:
dpkg -l | grep hplip
Offline pooky2483
« Reply #6 on: January 11, 2015, 09:29:34 pm »
ii  hplip                                       3.14.3-0ubuntu3.2                     amd64        HP Linux Printing and Imaging System (HPLIP)
ii  hplip-data                                  3.14.3-0ubuntu3.2                     all          HP Linux Printing and Imaging - data files
ii  hplip-dbg                                   3.14.3-0ubuntu3.2                     amd64        HP Linux Printing and Imaging - debugging information
ii  hplip-doc                                   3.14.3-0ubuntu3.2                     all          HP Linux Printing and Imaging - documentation
ii  hplip-gui                                   3.14.3-0ubuntu3.2                     all          HP Linux Printing and Imaging - GUI utilities (Qt-based)
Offline SeZo
« Reply #7 on: January 11, 2015, 09:30:57 pm »
You do not need Launcher, just locate Samba in the main menu (or however you are starting your applications).
If you are still have problem then do it in the Terminal:
Make sure samba is installed. if not then:
sudo apt-get install samba
sudo cp /etc/samba/smb.conf /etc/samba/smb.conf.old
sudo kwrite /etc/samba/smb.conf
locate the line
[global]
   workgroup =workgroup
change it to(without <>)
[global]
   workgroup =<workgroup name used in Windows>
then save and exit
sudo /etc/init.d/samba restart
then follow the rest of the instructions
No idea, not used it myself
Offline pooky2483
« Reply #8 on: January 11, 2015, 10:00:13 pm »
Took me ages to find out how to find out the name and it's the same as whats already in the ocnfig file so I have left it alone.
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Some options that are often worth tuning have been included as
# commented-out examples in this file.
#  - When such options are commented with ";", the proposed setting
#    differs from the default Samba behaviour
#  - When commented with "#", the proposed setting is the default
#    behaviour of Samba but the option is considered important
#    enough to be mentioned here
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
   workgroup = WORKGROUP
# server string is the equivalent of the NT Description field
   server string = %h server (Samba, Ubuntu)
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable its WINS Server
#   wins support = no
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;   wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
   dns proxy = no
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
;   interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself.  However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
;   bind interfaces only = yes
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
   log file = /var/log/samba/log.%m
# Cap the size of the individual log files (in KiB).
   max log size = 1000
# If you want Samba to only log through syslog then set the following
# parameter to 'yes'.
#   syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
# through syslog you should set the following parameter to something higher.
   syslog = 0
# Do something sensible when Samba crashes: mail the admin a backtrace
   panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# Server role. Defines in which mode Samba will operate. Possible
# values are "standalone server", "member server", "classic primary
# domain controller", "classic backup domain controller", "active
# directory domain controller".
# Most people will want "standalone sever" or "member server".
# Running as "active directory domain controller" will require first
# running "samba-tool domain provision" to wipe databases and create a
# new domain.
   server role = standalone server
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
   passdb backend = tdbsam
   obey pam restrictions = yes
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
   unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
   passwd program = /usr/bin/passwd %u
   passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
   pam password change = yes
# This option controls how unsuccessful authentication attempts are mapped
# to anonymous connections
   map to guest = bad user
########## Domains ###########
# The following settings only takes effect if 'server role = primary
# classic domain controller', 'server role = backup domain controller'
# or 'domain logons' is set
# It specifies the location of the user's
# profile directory from the client point of view) The following
# required a [profiles] share to be setup on the samba server (see
# below)
;   logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
# (this is Samba's default)
#   logon path = \\%N\%U\profile
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of a user's home directory (from the client
# point of view)
;   logon drive = H:
#   logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
;   logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe.  The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
# This allows machine accounts to be created on the domain controller via the
# SAMR RPC pipe.
# The following assumes a "machines" group exists on the system
; add machine script  = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
# This allows Unix groups to be created on the domain controller via the SAMR
# RPC pipe.
; add group script = /usr/sbin/addgroup --force-badname %g
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
;   include = /home/samba/etc/smb.conf.%m
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
;   idmap uid = 10000-20000
;   idmap gid = 10000-20000
;   template shell = /bin/bash
# Setup usershare options to enable non-root users to share folders
# with the net usershare command.
# Maximum number of usershare. 0 (default) means that usershare is disabled.
;   usershare max shares = 100
# Allow users who've been granted usershare privileges to create
# public shares, not just authenticated ones
   usershare allow guests = yes
#======================= Share Definitions =======================
# Un-comment the following (and tweak the other settings below to suit)
# to enable the default home directory shares. This will share each
# user's home directory as \\server\username
;[homes]
;   comment = Home Directories
;   browseable = no
# By default, the home directories are exported read-only. Change the
# next parameter to 'no' if you want to be able to write to them.
;   read only = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
;   create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
;   directory mask = 0700
# By default, \\server\username shares can be connected to by anyone
# with access to the samba server.
# Un-comment the following parameter to make sure that only "username"
# can connect to \\server\username
# This might need tweaking when using external authentication schemes
;   valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
;   comment = Network Logon Service
;   path = /home/samba/netlogon
;   guest ok = yes
;   read only = yes
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
;   comment = Users profiles
;   path = /home/samba/profiles
;   guest ok = no
;   browseable = no
;   create mask = 0600
[printers]
   comment = All Printers
   browseable = no
   path = /var/spool/samba
   printable = yes
   guest ok = no
   read only = yes
   create mask = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   guest ok = no
# Uncomment to allow remote administration of Windows print drivers.
# You may need to replace 'lpadmin' with the name of the group your
# admin users are members of.
# Please note that you also need to set appropriate Unix permissions
# to the drivers directory for these users to have write rights in it
;   write list = root, @lpadmin
« Reply #9 on: January 12, 2015, 03:29:10 pm »
Are you attempting to *share* the printer .. or set it up wirelessly ?
Does hplip-gui not just find it wirelessly ?
« Last Edit: January 12, 2015, 03:46:41 pm by Mark Greaves (PCNetSpec) »
Offline SeZo
« Reply #10 on: January 12, 2015, 08:49:01 pm »
@Mark
The only wireless is the Win 7 laptop. The printers are connected to the two wired PCs (see first post)
My understanding is if the printers are shared to the LAN then the wireless laptop can see them too.
« Reply #11 on: January 12, 2015, 10:37:30 pm »
@SeZo
You're probably right, and that's the way I'd have read it right up to this:-
but as the 3070A is a wireless printer and he says "by either system wirelessly"........
So I just thought a bit of clarity can't hurt :)
@pooky2483
Is the plan to leave al connections "as is", and share one of the printers with the others via "sharing" .. or is the plan to have ALL PC's connecting to the printer wirelessly.
