Author Topic: Is kernel upgrade possible ? (Solved again)  (Read 25590 times)
Offline donwatson
  • Getting older
« on: April 15, 2015, 10:30:59 am »
I am having problems ( again ) with my internet connection.
Would it be possible to upgrade to the 3.16 kernel series ?
I am running Peppermint 5
take care
Don W
« Last Edit: May 02, 2015, 04:41:32 pm by donwatson »
Novatech build
Peppermint 7    64 bit     500 GB HD        496 GB Ext 4
Re: Is kernel upgrade possible ?
« Reply #1 on: April 15, 2015, 11:51:17 pm »
Yes, open a terminal and run:
sudo apt-get install --install-recommends linux-generic-lts-utopic xserver-xorg-lts-utopic libgl1-mesa-glx-lts-utopic libegl1-mesa-drivers-lts-utopic
when that's finished, REBOOT.
Then post the output from:
uname -a
Offline donwatson
  • Getting older
« Reply #2 on: April 16, 2015, 09:40:02 am »
Is this ok,
don@ldwatson ~ $ uname -a
Linux ldwatson 3.16.0-34-generic #47~14.04.1-Ubuntu SMP Fri Apr 10 17:49:16 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
take care
Don W
Novatech build
« Reply #3 on: April 16, 2015, 11:24:16 am »
Yup, let's hope that helps with your wireless problem :)
Offline chemicalfan
« Reply #4 on: April 17, 2015, 09:33:54 am »
Won't he have to recompile the drivers against the new kernel headers? Or have I misunderstood how that fits together (again)?
« Reply #5 on: April 17, 2015, 10:13:29 am »
Did donwatson compile any drivers in the first place ? .. I thought he was just using the ones provided by the kernel, in which case they'll now be provided by the 3.16 kernel
Offline donwatson
  • Getting older
« Reply #6 on: April 17, 2015, 01:45:46 pm »
Mark,
This is the third time I have posted this, hope it works this time.
Everything is looking ok at the moment but I will leave it until Monday before marking solved.
One point I have to ask is, at the moment I switch the computer on and off about 6 times a day, would I be better to switch on in the morning and off at night ?
Or indeed can I leave the computer permanently on ?
Your thoughts please.
take care
Don W
Novatech build
Offline chemicalfan
« Reply #7 on: April 17, 2015, 01:53:01 pm »
@Mark - I can't remember, there's so many posts about wireless adaptors, most seem to end up compiliing drivers! Considering the issues Don has had, I guessed it might have been suggested at some point. Anyway, seems like he didn't from his follow up post :)
@Don - There's nothing wrong with leaving it on apart from the waste of power. You can always set it to suspend instead of turning it out - it'll still be on, but in a very-low power "sleep" state. If suspend doesn't work (can be flaky), I'd do the morning-night suggestion
Offline donwatson
  • Getting older
« Reply #8 on: April 17, 2015, 02:00:11 pm »
Thanks chemicalfan
Novatech build
« Reply #9 on: April 17, 2015, 03:29:17 pm »
This is a tough one to answer, different people have different opinions, it also depends on your priorities .. certainly continued power cycling of electronics can cause them to fail sooner (keep heating/cooling something is akin to bending a piece of metal backwards and forwards) .. but components with moving parts such as hard drives MAY last longer the less wear they get.
Personally I go with the always on option for desktops (except where noise may be a consideration such as in the living room) and my NAS .. laptops on in the morning/off at night.
As I said other people will likely have differing opinions about the "always on", but I think most people would say if you switch your PC on /off 6 times a day, you'd probably be better off just powering on in the morning, and off at night (unless of course power usage is the main consideration, say on a laptop that's on battery)
Offline donwatson
  • Getting older
« Reply #10 on: April 17, 2015, 05:45:43 pm »
Thanks for the advice chaps  :)
I removed the battery at the beginning of the week as I only use the laptop at home.
If I sit in the garden I can use the power from the shed, it just means switching off before going outside, or refitting the battery.
@chemicalfan, I will go with the on in the morning and off at night option.
@ Mark, I remember reading somewhere about the chips becoming loose due to to heating/cooling, it was a long time ago.
I think that was what prompted the lock on the socket ? I dunno :D
I will wait until Monday before marking this solved, when I will have another problem to set you  ???
take care
Don W
Novatech build
Offline donwatson
  • Getting older
« Reply #11 on: April 20, 2015, 07:03:02 pm »
The internet connection has dropped out again.  :'(
I checked emails etc this morning and all was ok.
I left the computer running while I did some work, after tea I woke the computer up and signed in, and, lo and behold no internet connection.
What's next Mark ?
take care
Don W
Novatech build
« Reply #12 on: April 20, 2015, 08:29:05 pm »
So this is purely a resume from suspend issue ?
it's no longer dropping out prior to suspending ?
next time it suspends and doesn't reconnect after resume .. whilst it's NOT connecting, please run:
nmcli nm status
copy the output to a text file.
Reboot so you can connect
post the output back here
Offline donwatson
  • Getting older
« Reply #13 on: April 20, 2015, 09:08:04 pm »
Thanks Mark,
When I finished my tea I came back to the computer, moved the mouse and signed in.
I saw that it hadn't connected and the icon whizzed around a few times but it is still disconnected.
I will go back to the Linux machine and carry out the above request.
take care
Don W
I have ran the command, saved it and shutdown the computer.
I re started computer and I am connected to internet.
This is what I got from the command
don@ldwatson ~ $ nmcli nm status
RUNNING         STATE           WIFI-HARDWARE   WIFI       WWAN-HARDWARE   WWAN
running         disconnected    enabled         enabled    enabled         enabled
don@ldwatson ~ $
Hope this helps
« Last Edit: April 20, 2015, 09:16:45 pm by donwatson »
Novatech build
« Reply #14 on: April 20, 2015, 10:59:53 pm »
If your connection is called "VM185937-2G", and the wireless device is "wlan0" does it reconnect it you run:
nmcli -p con up id "VM185937-2G" iface wlan0
