Author Topic: Drivers for Epson SX130 printer  (Read 5138 times)
Offline donwatson
  • Getting older
« on: June 13, 2015, 03:59:45 pm »
I have upgraded to Peppermint 6 using the tutorial about installing Pep 5 on an Acer.
I have most things sorted ok but I have came to a halt with the printer.
I found the following that I used before
epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb
iscan-data_1.26.0-1_all.deb
iscan_2.29.3-1~usb0.1.ltdl7_i386.deb
but I downloaded the first part and ran that but I only get an error 404 for the other 2 parts
Is there another source for updates ?
take care
Don W
Novatech build
Peppermint 7    64 bit     500 GB HD        496 GB Ext 4
Offline donwatson
  • Getting older
Re: Drivers for Epson SX130 printer
« Reply #2 on: June 13, 2015, 11:49:33 pm »
I get an error when I have tried to install the first part ( epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb )
Error: Failed to satisfy all dependencies (broken cache )
EDIT I have 2 instances of 'Package Installer' in the toolbar that won't delete.
EDIT EDIT I have moved upstairs and connected the printer.
I have used Menu>System Tools>Printers and loaded the Epson Printer and printed the usual Test Page.
Thanks for the help Mark. I was trying to get these bits and pieces to work on my own (with your help actually) as most of these things I have asked about before, so they must be on the forums.
I need a method of finding them, should I search using posts by don watson including google, wifi. printer, etc.
« Last Edit: June 14, 2015, 12:18:40 am by donwatson »
Novatech build
« Reply #3 on: June 14, 2015, 12:48:22 am »
you've lost me...
Are you still having problems installing ? .. if so, can you post the output from:
then put those 3 files on your Desktop .. then post the output from:
sudo dpkg -i ~/Desktop/epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb
and post the output from that too.
Offline donwatson
  • Getting older
« Reply #4 on: June 14, 2015, 10:14:16 am »
Hi Mark
The first part gives this
don@ldwatson ~ $ sudo apt-get update
[sudo] password for don:
Ign http://ppa.launchpad.net trusty InRelease
Ign http://extras.ubuntu.com trusty InRelease
Hit http://ppa.launchpad.net trusty Release.gpg
Ign http://archive.canonical.com trusty InRelease
Ign http://gb.archive.ubuntu.com trusty InRelease
Hit http://extras.ubuntu.com trusty Release.gpg
Ign http://gb.archive.ubuntu.com trusty-updates InRelease
Ign http://gb.archive.ubuntu.com trusty-backports InRelease
Hit http://archive.canonical.com trusty Release.gpg
Hit http://ppa.launchpad.net trusty/main Sources
Hit http://gb.archive.ubuntu.com trusty Release.gpg
Hit http://extras.ubuntu.com trusty/main Sources
Hit http://gb.archive.ubuntu.com trusty-updates Release.gpg
Hit http://ppa.launchpad.net trusty/main amd64 Packages
Hit http://extras.ubuntu.com trusty/main amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-backports Release.gpg
Hit http://extras.ubuntu.com trusty/main i386 Packages
Hit http://ppa.launchpad.net trusty/main i386 Packages
Hit http://archive.canonical.com trusty/partner Sources
Hit http://ppa.launchpad.net trusty/main Translation-en
Ign http://security.ubuntu.com trusty-security InRelease
Hit http://archive.canonical.com trusty/partner amd64 Packages
Hit http://archive.canonical.com trusty/partner i386 Packages
Hit http://gb.archive.ubuntu.com trusty/multiverse Sources
Hit http://archive.canonical.com trusty/partner Translation-en
Hit http://gb.archive.ubuntu.com trusty/main Sources
Hit http://gb.archive.ubuntu.com trusty/restricted Sources
Hit http://security.ubuntu.com trusty-security Release.gpg
Hit http://gb.archive.ubuntu.com trusty/universe Sources
Hit http://gb.archive.ubuntu.com trusty/main amd64 Packages
Ign http://extras.ubuntu.com trusty/main Translation-en_GB
Hit http://gb.archive.ubuntu.com trusty/restricted amd64 Packages
Hit http://gb.archive.ubuntu.com trusty/universe amd64 Packages
Hit http://gb.archive.ubuntu.com trusty/multiverse amd64 Packages
Hit http://gb.archive.ubuntu.com trusty/main i386 Packages
Hit http://gb.archive.ubuntu.com trusty/restricted i386 Packages
Hit http://security.ubuntu.com trusty-security/multiverse Sources
Hit http://gb.archive.ubuntu.com trusty/universe i386 Packages
Hit http://gb.archive.ubuntu.com trusty/multiverse i386 Packages
Hit http://gb.archive.ubuntu.com trusty/main Translation-en_GB
Hit http://security.ubuntu.com trusty-security/main Sources
Hit http://gb.archive.ubuntu.com trusty/multiverse Translation-en_GB
Hit http://gb.archive.ubuntu.com trusty/restricted Translation-en_GB
Hit http://security.ubuntu.com trusty-security/restricted Sources
Hit http://gb.archive.ubuntu.com trusty/universe Translation-en_GB
Hit http://gb.archive.ubuntu.com trusty-updates/multiverse Sources
Hit http://gb.archive.ubuntu.com trusty-updates/main Sources
Hit http://security.ubuntu.com trusty-security/universe Sources
Hit http://gb.archive.ubuntu.com trusty-updates/restricted Sources
Hit http://gb.archive.ubuntu.com trusty-updates/universe Sources
Hit http://gb.archive.ubuntu.com trusty-updates/main amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/restricted amd64 Packages
Hit http://security.ubuntu.com trusty-security/main amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/universe amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/multiverse amd64 Packages
Hit http://security.ubuntu.com trusty-security/restricted amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/main i386 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/restricted i386 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/universe i386 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/multiverse i386 Packages
Hit http://security.ubuntu.com trusty-security/universe amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-updates/main Translation-en
Hit http://gb.archive.ubuntu.com trusty-updates/multiverse Translation-en
Hit http://gb.archive.ubuntu.com trusty-updates/restricted Translation-en
Hit http://gb.archive.ubuntu.com trusty-updates/universe Translation-en
Hit http://security.ubuntu.com trusty-security/multiverse amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/main Sources
Hit http://gb.archive.ubuntu.com trusty-backports/restricted Sources
Hit http://gb.archive.ubuntu.com trusty-backports/universe Sources
Hit http://gb.archive.ubuntu.com trusty-backports/multiverse Sources
Hit http://security.ubuntu.com trusty-security/main i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/main amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/restricted amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/universe amd64 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/multiverse amd64 Packages
Hit http://security.ubuntu.com trusty-security/restricted i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/main i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/restricted i386 Packages
Hit http://security.ubuntu.com trusty-security/universe i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/universe i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/multiverse i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/main Translation-en
Hit http://gb.archive.ubuntu.com trusty-backports/multiverse Translation-en
Hit http://gb.archive.ubuntu.com trusty-backports/restricted Translation-en
Hit http://security.ubuntu.com trusty-security/multiverse i386 Packages
Hit http://gb.archive.ubuntu.com trusty-backports/universe Translation-en
Hit http://security.ubuntu.com trusty-security/main Translation-en
Hit http://security.ubuntu.com trusty-security/multiverse Translation-en
Hit http://security.ubuntu.com trusty-security/restricted Translation-en
Hit http://security.ubuntu.com trusty-security/universe Translation-en
Reading package lists... Done
don@ldwatson ~ $
Novatech build
Offline donwatson
  • Getting older
« Reply #5 on: June 14, 2015, 10:22:09 am »
This is the other result
don@ldwatson ~ $ sudo dpkg -i ~/Desktop/epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb
Selecting previously unselected package epson-inkjet-printer-201101w.
(Reading database ... 237603 files and directories currently installed.)
Preparing to unpack .../epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb ...
Unpacking epson-inkjet-printer-201101w (1.0.0-1lsb3.2) ...
dpkg: dependency problems prevent configuration of epson-inkjet-printer-201101w:
 epson-inkjet-printer-201101w depends on lsb (>= 3.2).
dpkg: error processing package epson-inkjet-printer-201101w (--install):
 dependency problems - leaving unconfigured
don@ldwatson ~ $
I have used Menu>System Tools>Printers and loaded the Epson Printer SX130 under 'Network'. It is printing at the moment.
Novatech build
« Reply #6 on: June 14, 2015, 06:20:12 pm »
OK, can you run:
sudo apt-get remove --purge epson-inkjet-printer-201101w
sudo apt-get install lsb
then double click on the epson-inkjet-printer-201101w_1.0.0-1lsb3.2_i386.deb file and click the "Install" button
did it install without error ?
Offline donwatson
  • Getting older
« Reply #7 on: June 14, 2015, 06:28:12 pm »
Sorry Mark,
It came up with the same error
Novatech build
« Reply #8 on: June 14, 2015, 10:57:47 pm »
what happens if you run:
sudo apt-get -f install
does that fix things ?
Offline donwatson
  • Getting older
« Reply #9 on: June 14, 2015, 11:33:44 pm »
I ran that and it produced this
don@ldwatson ~ $ sudo apt-get -f install
Building dependency tree
  linux-headers-3.16.0-37 linux-headers-3.16.0-37-generic
  linux-image-3.16.0-37-generic linux-image-extra-3.16.0-37-generic
Use 'apt-get autoremove' to remove them.
don@ldwatson ~ $
Do I need to run the other 2 parts now ? ( iscan_2.30.1-1~usb0.1.ltdl7_i386.deb and iscan-data_1.36.0-1_all.deb ) ?
Novatech build
« Reply #10 on: June 14, 2015, 11:59:06 pm »
if you get a any return from:
dpkg -l | grep epson-inkjet-printer-201101w
then yeah .. install the other 2 packages
If nothing is returned, let me know.
Offline donwatson
  • Getting older
« Reply #11 on: June 15, 2015, 12:03:48 am »
I get this
don@ldwatson ~ $ dpkg -l | grep epson-inkjet-printer-201101w
rc  epson-inkjet-printer-201101w                1.0.0-1lsb3.2                           i386         EPSON Stylus NX130 Series - Epson Inkjet Printer Driver
don@ldwatson ~ $
Is that safe for me to install the other 2 packages now ?
Novatech build
« Reply #12 on: June 15, 2015, 12:05:55 am »
yep, go for it :)
You should also be good to go in your cribbage topic now too
Offline donwatson
  • Getting older
« Reply #13 on: June 15, 2015, 12:15:32 am »
Sorry Mark,
When I double click on Iscan package installer it says 'Error: Dependency  is not satisfiable: iscan data
Novatech build
« Reply #14 on: June 15, 2015, 12:17:31 am »
install iscan-data first .. THEN iscan ;)
In other words .. install them in this order
« Last Edit: June 15, 2015, 12:19:41 am by Mark Greaves (PCNetSpec) »
