Author Topic: Drivers for Epson SX130 printer  (Read 6102 times)
Offline donwatson
  • Getting older
Re: Drivers for Epson SX130 printer
« Reply #15 on: June 15, 2015, 12:27:07 am »
The iscan-data went in ok but the iscan is still throwing up an error.
Error: Failed to satisfy all dependencies ( broken cache ) ?
Novatech build
Peppermint 7    64 bit     500 GB HD        496 GB Ext 4
« Reply #16 on: June 15, 2015, 12:35:24 am »
try:
sudo apt-get -f install
again
it's these damn alien converted packages ::)
Offline donwatson
  • Getting older
« Reply #17 on: June 15, 2015, 12:43:31 am »
I used the instructions and now have this. I think I will stop now as I don't remember what I am looking for.  :-\
don@ldwatson ~ $ sudo apt-get -f install
[sudo] password for don:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
  libatk1.0-0:i386 libcairo2:i386 libexif12:i386 libgd3:i386
  libgdk-pixbuf2.0-0:i386 libgphoto2-6:i386 libgphoto2-port10:i386
  libgraphite2-3:i386 libgtk2.0-0:i386 libharfbuzz0b:i386 libieee1284-3:i386
  libjasper1:i386 libltdl7:i386 libpango-1.0-0:i386 libpangocairo-1.0-0:i386
  libpangoft2-1.0-0:i386 libpixman-1-0:i386 libsane:i386 libusb-0.1-4:i386
  libusb-1.0-0:i386 libv4l-0:i386 libv4lconvert0:i386 libvpx1:i386
  libxcb-render0:i386 libxcb-shm0:i386 libxcomposite1:i386 libxcursor1:i386
  libxinerama1:i386 libxpm4:i386 libxrandr2:i386 linux-headers-3.16.0-37
  linux-headers-3.16.0-37-generic linux-image-3.16.0-37-generic
  linux-image-extra-3.16.0-37-generic
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED
  iscan:i386
0 to upgrade, 0 to newly install, 1 to remove and 0 not to upgrade.
1 not fully installed or removed.
After this operation, 1,487 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 240021 files and directories currently installed.)
Removing iscan (2.30.1-1~usb0.1.ltdl7) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Processing triggers for mime-support (3.54ubuntu1.1) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
don@ldwatson ~ $
Is this ok ?
Novatech build
« Reply #18 on: June 15, 2015, 01:49:56 am »
I'll have a look at this in the morning .. need sleep
« Reply #19 on: June 15, 2015, 11:16:47 am »
can you confirm you're on the 32bit kernel with ten output from:
uname -a
and I'll try testing the drivers installation myself.
Offline donwatson
  • Getting older
« Reply #20 on: June 15, 2015, 02:00:41 pm »
Is this what you are looking for ?
don@ldwatson ~ $ uname -a
Linux ldwatson 3.16.0-40-generic #54~14.04.1-Ubuntu SMP Wed Jun 10 17:30:45 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
don@ldwatson ~ $
Novatech build
« Reply #21 on: June 15, 2015, 04:34:48 pm »
Crud .. no wonder they're throwing a wobbly, we've been trying to install the 32bit drivers in 64bit Peppermint.
OK, run:
sudo apt-get remove --purge iscan
sudo apt-get remove --purge iscan-data
sudo apt-get remove --purge epson-inkjet-printer-201101w
did those complete without error ?
If so, I'll post links to the 64bit drivers in a bit.
Offline donwatson
  • Getting older
« Reply #22 on: June 15, 2015, 05:05:20 pm »
Thanks Mark,
Carried out the request and it seems quite happy so far.  :D
Novatech build
« Reply #23 on: June 15, 2015, 05:14:30 pm »
OK, let's download these 3 files and install them in this order (any problems, stop and tell me what they are):
epson-inkjet-printer-201101w_1.0.0-1lsb3.2_amd64.deb
iscan-data_1.36.0-1_all.deb
iscan_2.30.1-1~usb0.1.ltdl7_amd64.deb
Offline donwatson
  • Getting older
« Reply #24 on: June 15, 2015, 06:39:46 pm »
Carried out your suggestion and there are no problems showing  :D
Novatech build
« Reply #25 on: June 15, 2015, 07:58:17 pm »
So are you able to add the printer now ?
Offline donwatson
  • Getting older
« Reply #26 on: June 15, 2015, 08:15:19 pm »
Thanks Mark,
I have the Sx 130 installed ok, and the the Photosmart 7580, thanks very much.
The Epson SX 130 is an all-in-one, can I get the scanner working ?
Novatech build
« Reply #27 on: June 16, 2015, 02:31:26 am »
menu > Graphics > Image Scan! for Linux
maybe ?
Or isn't that there ?
Offline donwatson
  • Getting older
« Reply #28 on: June 16, 2015, 10:53:47 am »
 :-[ Thanks Mark  :-[ I could have sworn it wasn't there last night ?
It is working fine thanks  :D
Can I go and check out the cribbage now ?
take care
Don W
PS I will need to raise the spectre of WiFi again. I will wait for a little while.
Novatech build
« Reply #29 on: June 16, 2015, 11:21:10 am »
Sure .. the bsdgames should install fine now
