Author Topic: No internet connection any more  (Read 6228 times)
0 Members and 3 Guests are viewing this topic.
Offline mikep
  • Full Member
  • Me again!
« on: February 24, 2016, 08:35:45 pm »
Hello folks,
Recently our internet connection stopped working in both windows and Ubuntu 14.04. I assumed I'd broken it while fiddling about with the router's wi-fi settings.
I returned the router to factory settings. No luck. So I turned off the router (and everything else) for several hours. Now Windows can access the internet again, but not Ubuntu.
It appears to connect (green lights on the router etc), and our ISP confirms that the connection has been made, but pages just won't load.
Anyone got any ideas please?
Offline SeZo
Re: No internet connection any more
« Reply #1 on: February 24, 2016, 08:54:26 pm »
This could be down to number of things but you could try:
sudo route -n
ping -n -c5 linux.co.uk
if that fails then try:
ping -n -c5 130.193.92.18
Post what you get
Offline mikep
  • Full Member
  • Me again!
« Reply #2 on: February 24, 2016, 09:10:20 pm »
Thanks SeZo,
Will do.
Got to reboot to try it (I'm on a dual boot PC).
Offline mikep
  • Full Member
  • Me again!
« Reply #3 on: February 24, 2016, 09:22:00 pm »
This is what I got... double Dutch to me! I hope you can make something of it...
mike@mike-abit:~$ sudo route -n
[sudo] password for mike:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.0.1     0.0.0.0         UG    0      0        0 eth1
192.168.0.0     0.0.0.0         255.255.255.0   U     1      0        0 eth1
mike@mike-abit:~$ ping -n -c5 linux.co.uk
ping: unknown host linux.co.uk
mike@mike-abit:~$ ping -n -c5 130.193.92.18
PING 130.193.92.18 (130.193.92.18) 56(84) bytes of data.
64 bytes from 130.193.92.18: icmp_seq=1 ttl=56 time=388 ms
64 bytes from 130.193.92.18: icmp_seq=2 ttl=56 time=334 ms
64 bytes from 130.193.92.18: icmp_seq=3 ttl=56 time=426 ms
64 bytes from 130.193.92.18: icmp_seq=4 ttl=56 time=344 ms
64 bytes from 130.193.92.18: icmp_seq=5 ttl=56 time=466 ms
--- 130.193.92.18 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4004ms
rtt min/avg/max/mdev = 334.332/392.233/466.642/49.748 ms
mike@mike-abit:~$
Offline SeZo
« Reply #4 on: February 24, 2016, 09:36:58 pm »
The ip address 130.193.92.18 is linux.co.uk
The fact that you received 5 replies from 130.193.92.18 means that you have access to the internet but have no DNS server available.
You could put OpenDNS as a DNS resolver manually in your Ubuntu network settings for that connection.
208.67.222.222
208.67.220.220
Offline mikep
  • Full Member
  • Me again!
« Reply #5 on: February 24, 2016, 09:48:54 pm »
Thanks SeZo,
I may be back asking for instructions on exactly how to do that. I'll try to figure it out first though.
But why do I suddenly have no DNS server? I'm prepared to believe that I messed up the router, but I've restored the factory defaults?
Offline mikep
  • Full Member
  • Me again!
« Reply #6 on: February 25, 2016, 12:44:38 am »
Thanks again SeZo,
Using OpenDNS has got us back online, albeit more slowly than before. I assume that's because the router is starting from scratch and building up to the maximum speed possible.
I'm still baffled as to how we lost the DNS server though..
I'll watch this for a couple of days before marking it solved.
Regards,
M
« Reply #7 on: February 25, 2016, 12:14:30 pm »
If Windows is accessing the web properly it's not a problem with the router, it's likely a problem with Ubuntu's network settings.
What was set as the DNS server in network manager .. was it the routers IP ?
« Last Edit: March 06, 2016, 01:33:29 am by Mark Greaves (PCNetSpec) »
Offline mikep
  • Full Member
  • Me again!
« Reply #8 on: March 05, 2016, 11:04:55 pm »
Hello Mark,
Sorry for the delayed reply.
DNS in Ubuntu's network manager is 192.168.0.1, which I believe is the router..
Still online, albeit a bit slower than before. I'll talk to our ISP about it - we used to leave the DNS to them and things were fine. No idea why that changed.
« Reply #9 on: March 06, 2016, 01:36:00 am »
do you mean DNS "was" set to the routers IP in networkmanager .. or DNS "is now" set to the routers IP in networkmanager
In which case, where did you set the opendns servers ? .. in the router itself ?
Offline mikep
  • Full Member
  • Me again!
« Reply #10 on: March 07, 2016, 11:28:26 pm »
DNS was set to 'automatically from the ISP'
Then set to the openDNS ones suggested by sezo, which got us back online, albeit slower.
Now, infuriatingly, still set to the openDNS ones suggested by sezo, but as of tonight, no longer online in Ubuntu (although we are in XP).
Grrrrr......
« Reply #11 on: March 08, 2016, 12:10:58 am »
Yeah but WHERE are you applying those DNS settings .. in networkmanager, or in the router ?
Offline mikep
  • Full Member
  • Me again!
« Reply #12 on: March 08, 2016, 01:35:52 am »
In the router...
« Reply #13 on: March 08, 2016, 10:59:45 am »
Ahh, right .. (IN THE ROUTER) set it back to the DNS from your ISP.
Then run:
nm-connection-editor
highlight your connection, and click the "Edit" button.
On the IPv4 tab, set:-
Method: Automatic (DHCP) addresses only
DNS Servers: <IP.address.of.router>
eg.
DNS Servers: 192.168.1.1
Then click the "Save" button.
at this point you may need to log off/on to restart the network.
You might also want to set the IPv6
Method: Ignore
If it doesn't work .. just set it back the way it was.
Offline mikep
  • Full Member
  • Me again!
« Reply #14 on: March 08, 2016, 10:34:15 pm »
No luck Mark.
Tried every combination of your suggestions, but still offline in Ubuntu and online in Windows...
