Author Topic: i cant rcover my pc after sleep !!  (Read 2915 times)
Offline Hayder
  • Full Member
« on: March 24, 2016, 08:44:10 pm »
Hello:
I'm used to close laptop lid to make it sleep, but in Linux after 2 times closed , the pc just show me the blank desktop , with blank menu!!
any  suggestion please
Re: i cant rcover my pc after sleep !!
« Reply #1 on: March 24, 2016, 09:25:22 pm »
Hold Ctrl+SysRq and type r e i s u b (waiting a couple of seconds between key strokes)
Your system should reboot .. is it displaying properly after a reboot ?
Offline Hayder
  • Full Member
« Reply #2 on: March 24, 2016, 09:42:15 pm »
Hello
yes it works ok after reboot, but close the lid 2 times make all thing disappear , so i must reboot again and loose my work,
« Reply #3 on: March 25, 2016, 12:50:05 am »
Okay there are a few things that might cause this
1) Peppermint set to hibernate on lid close, and the swap partition not being large enough
2) Your system not being happy with the MATE power manager
3) This problem
http://forum.peppermintos.com/index.php/topic,1046.0.html
For now, post the output from:
free -m
Offline Hayder
  • Full Member
« Reply #4 on: March 25, 2016, 07:45:36 am »
total       used       free     shared    buffers     cached
Mem:          7904       6946        957        168        127       4254
-/+ buffers/cache:       2564       5340
Swap:         8107          0       8107
« Reply #5 on: March 25, 2016, 09:07:26 pm »
Okay, you seem to have enough swap space .. JUST!!!
Next, let's try changing the power manager
sudo apt-get remove --purge mate-power-manager mate-power-manager-common
sudo apt-get install xfce4-power-manager
now go to
menu > Preferences > Default applications for LXSession > Core applications (tab)
and change
Power Manager mate-power-manager
to
Power Manager xfce4-power-manager
Now log off/on or reboot.
Now right-cick the power manager icon by the system clock, and select "About" .. it should now say it's the "xfce4-power-manager"
If it does, check what happens if you close the lid now ??
if it works, great.
If it doesn't, run
gksudo gedit /var/lib/polkit-1/localauthority/50-local.d/com.ubuntu.enable-hibernate.pkla
and when a blank file opens make it read
[Re-enable hibernate by default in upower]
Identity=unix-user:*
Action=org.freedesktop.upower.hibernate
ResultActive=yes
[Re-enable hibernate by default in logind]
Action=org.freedesktop.login1.hibernate
ResultActive=yes
then test again.
Offline Hayder
  • Full Member
« Reply #6 on: March 25, 2016, 11:13:17 pm »
I replace the power manager, then i choose Suspend when i close the lid" but same thing, just blank windows, and i must force power down to get control over the system
« Reply #7 on: March 26, 2016, 01:23:27 pm »
does
sudo pm-suspend
do the same thing .. ie. leave you at a blank screen that you cannot resume from ?
if so, use the REISUB trick to reboot then post the output from
inxi -F
Offline Hayder
  • Full Member
« Reply #8 on: March 26, 2016, 04:13:42 pm »
Hello:
i found this in Ask Ubuntu , and its work good ,just the menu is still blank but if you put the cursor on it , its return
I had a similar problem on Ubuntu Gnome 15.10. This is what worked for me:
sudo gedit /etc/default/grub
Edit the line: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash'"
Replace it with: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor
acpi_osi='!Windows 2013' acpi_osi='!Windows 2012'"
sudo update­grub
Then you have to reboot twice. I know. You have to do it twice, though.
That fixed the issue for me, hopefully, this helps someone else.
and this is the output from your command
System:    Host: hayder-Lenovo-G50-80 Kernel: 3.16.0-67-generic x86_64 (64 bit) Desktop: N/A Distro: Peppermint Six
Machine:   System: LENOVO product: 80E5 version: Lenovo G50-80
           Mobo: LENOVO model: Lenovo G50-80 version: NO DPK Bios: LENOVO version: B0CN97WW date: 01/08/2016
CPU:       Dual core Intel Core i7-5500U CPU (-HT-MCP-) cache: 4096 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx)
           Clock Speeds: 1: 2958.375 MHz 2: 1966.125 MHz 3: 2997.656 MHz 4: 2974.968 MHz
Graphics:  Card: Intel Broadwell-U Integrated Graphics
           X.Org: 1.16.0 drivers: ati,radeon,intel (unloaded: fbdev,vesa) Resolution: 1366x768@60.0hz
           GLX Renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2) GLX Version: 3.0 Mesa 10.3.2
Audio:     Card-1: Intel Wildcat Point-LP High Definition Audio Controller driver: snd_hda_intel
           Card-2: Intel Broadwell-U Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture ver: k3.16.0-67-generic
Network:   Card-1: Realtek RTL8723BE PCIe Wireless Network Adapter driver: rtl8723be
           IF: wlan0 state: up mac: 18:4f:32:02:c1:39
           Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
           IF: eth0 state: down mac: 50:7b:9d:2c:4b:89
Drives:    HDD Total Size: 1000.2GB (19.0% used) 1: id: /dev/sda model: ST1000LM024_HN size: 1000.2GB
Partition: ID: / size: 909G used: 177G (21%) fs: ext4 ID: /boot size: 236M used: 71M (32%) fs: ext2
           ID: swap-1 size: 8.50GB used: 0.05GB (1%) fs: swap
RAID:      No RAID devices detected - /proc/mdstat and md_mod kernel raid module present
Sensors:   System Temperatures: cpu: 38.0C mobo: N/A gpu: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 213 Uptime: 16:46 Memory: 2479.0/7904.4MB Client: Shell (bash) inxi: 1.9.17
Offline Hayder
  • Full Member
« Reply #9 on: June 25, 2016, 12:50:17 am »
Hello
After I update to version 7, and close the lid , I cant recover my PC !!
« Reply #10 on: June 25, 2016, 03:07:09 pm »
Have you tried your GRUB edits again ?
Offline Hayder
  • Full Member
« Reply #11 on: June 25, 2016, 03:19:40 pm »
yes i did, but the last command ( sudo update grub) not works !!
« Reply #12 on: June 25, 2016, 03:22:58 pm »
The command is
sudo update-grub
Offline Hayder
  • Full Member
« Reply #13 on: June 25, 2016, 06:36:22 pm »
I did it now , but still same problem....
