Author Topic: (Solved). flash problem in Ubuntu 14.04  (Read 1913 times)
Offline mikep
  • Full Member
  • Me again!
« on: April 23, 2016, 08:34:34 pm »
Hello folks,
I had a problem a while back reinstalling Flash in Firefox in Ubuntu 14.04.
Mark suggested the following, and it worked.
sudo apt-get install flashplugin-installer
I'm now having a similar problem in a liveusb of Ubuntu 14.04, but the solution isn't working. What I get is..
ubuntu@ubuntu:~$ sudo apt-get install flashplugin-installer
Reading package lists... Done
Building dependency tree
E: Unable to locate package flashplugin-installer
Any help appreciated. Thanks.
« Last Edit: April 23, 2016, 09:34:10 pm by mikep »
Offline SeZo
Re: flash problem in Ubuntu 14.04
« Reply #1 on: April 23, 2016, 08:50:47 pm »
You probably need to enable the multiverse source first
Applications->System Tools->Preferences->Software & Updates.
Select Ubuntu Software tab and select the entry which (multiverse)
Offline mikep
  • Full Member
  • Me again!
(Solved) Re: flash problem in Ubuntu 14.04
« Reply #2 on: April 23, 2016, 09:16:44 pm »
Bingo!
Thanks Sezo - worked perfectly.
Damn, I've got a lot to learn about Linux...
Offline SeZo
« Reply #3 on: April 23, 2016, 09:24:23 pm »
Glad it worked for you.
