Author Topic: Help Required for Gparted  (Read 1301 times)
Offline osama.mansoor
« on: May 26, 2016, 11:49:09 am »
I am new in linux and stuck in a situation , i am trying to install & configure gparted on one of my linux machine to re-size disk its not working i just stuck at end of steps , i take help from below site.
http://ask.xmodulo.com/install-gparted-linux.html
I have already full fill all required pre-requites
[root@starwind gparted]# ls
AUTHORS     compose       COPYING-DOCS  gnome-doc-utils.make    gparted.desktop.in.in  HACKING  m4           po      testbuild.sh
autogen.sh  configure.ac  data          gparted                 gparted.doap           help     Makefile.am  README
ChangeLog   COPYING       doc           gparted.appdata.xml.in  gparted.in             include  NEWS         src
[root@starwind gparted]# ./autogen.sh
/usr/bin/gnome-autogen.sh
checking for autoconf >= 2.53...
  testing autoconf2.50... not found.
  testing autoconf... found 2.63
checking for automake >= 1.9...
  testing automake-1.11... found 1.11.1
checking for libtool >= 1.4.3...
  testing libtoolize... not found.
***Error***: You must have libtool >= 1.4.3 installed
  to build gparted.  Download the appropriate package for
  from your distribution or get the source tarball at
    http://ftp.gnu.org/pub/gnu/libtool/libtool-1.4.3.tar.gz
[root@starwind gparted]# ./configure.ac
-bash: ./configure.ac: Permission denied
Re: Help Required for Gparted
« Reply #1 on: May 26, 2016, 05:03:31 pm »
You don't say which Linux distro you're using ?
GParted is HIGHLY likely to be pre-packaged and already in the default software repositories no matter which distro you're using .. so no need to compile from source code.
If you're running Debian/Ubuntu or any derivative distro, simply running:
sudo apt-get install gparted
will download and install it for you
or on a Redhat derivative
sudo yum install gparted
would probably do the trick
« Last Edit: May 26, 2016, 05:05:45 pm by Mark Greaves (PCNetSpec) »
« Reply #2 on: May 27, 2016, 07:48:23 am »
I have REDHAT 6.5
i already installed by yum install command also full fill all required pre-requites like set up EPEL repository, but issue comes when i try to launch Gparted which mention in last of below link
Issues comes here
« Reply #3 on: May 27, 2016, 03:04:51 pm »
It's most likely that it's a script that doesn't have the execute bit enabled
try running
sudo chmod +x ./configure.ac
otherwise (depending on where you've downloaded it to) maybe you need to run it as root.
« Reply #4 on: May 31, 2016, 04:56:46 am »
Thanks for your help and suggestion it works using Gparted boot CD
