Author Topic: Low resolution nvidia geforce  (Read 2526 times)
0 Members and 3 Guests are viewing this topic.
Emegra
  • Guest
« on: June 11, 2016, 07:34:13 am »
Hi giys
I've just installed Peppermint 6 on a HP desktop with a nvidia geforce gt 710 gpu and the best resolution I can get is 1024x768 which is too low I've checked Additional Drivers but none are being offered
here's my terminal otput
graeme@Media-Centre ~ $ lshw -c display
  *-display UNCLAIMED
       product: NVIDIA Corporation
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:20:00.0
       version: a1
       width: 64 bits
       capabilities: vga_controller cap_list
       configuration: latency=0
       resources: memory:f2000000-f2ffffff memory:e8000000-efffffff memory:f0000000-f1ffffff ioport:1100(size=128) memory:f3080000-f30fffff
Emegra
  • Guest
Re: Low resolution nvidia geforce
« Reply #1 on: June 11, 2016, 09:31:39 am »
I solved the problem
the solution is here
http://www.binarytides.com/install-nvidia-drivers-ubuntu-14-04/
I've never had to do that before but it work fine
« Reply #2 on: June 11, 2016, 11:02:21 am »
Thanks Graeme, that might help out mikep here:
http://linuxforums.org.uk/index.php?topic=12874.msg105490#msg105490
if he decides to go for the GT 710 I suggested :)
Offline nomko
  • Using Linux since Ubuntu version 7.04
    • Tips for Linux
« Reply #3 on: September 02, 2016, 02:08:55 pm »
No, not the best solution! And beside that, the xorg PPA doesn't contain any Nvidia drivers. All Nvidia drivers are moved to here: https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa.
Please, before responding and providing solutions, please check them first if they are still applicable, up-to-date, valid and maintained! In this case, referring to the xorg PPA using a link to a website is a) not valid b) not applicable.
Also, building a driver without good knowledge of Linux systems will only lead to broken systems. Also, the driver downloaded ffrom the Nvidia website is a generic driver not specific meant for Ubuntu-based distributions/derivatives. The change of breaking a system either by running a wrong command or by the driver not compiled correctly is a real threat here. Therefore it is much wiser to refer to the graphics-drivers PPA:
sudo add-apt-repository ppa:graphics-drivers/ppa
Now go to your Device Driver Manager and install the Nvidia driver which is marked as recommended. Nothing can go wrong here!
« Last Edit: September 02, 2016, 02:12:44 pm by nomko »
MSI GE70-2PE Hybrid laptop:
Quad core Intel Core i7-4710HQ*Kingston 16 GB RAM*Intel 4th Gen. Integr. GPU/NVidia GeForce GTX860M*Qualcomm Atheros Killer E2200/Intel Wireless 3160*128 GiB SSD*1 TB HDD*17.3" Full HD anti-glare LCD panel
