Author Topic: Going over to Linux  (Read 6762 times)
Re: Going over to Linux
« Reply #30 on: July 21, 2016, 10:12:07 pm »
Cool .. good luck Ed, not that you should need it :)
Offline Ed
  • Thanks to everybody helping me.
    • Swap Shop
« Reply #31 on: July 22, 2016, 02:41:25 pm »
You're right about it being FAT32 as opposed to NTFS. The chap was talking about booting from a disk when he stated NTFS. My mistake and I will pay particular attention in future to what's being said when the guy's first language isn't English.
With the above in mind and in regard to actually booting to the LiveUSB. Just to make absolutely sure the flash drive has been prepared correctly and I do things right, could you briefly run over the steps to boot from the USB please?
Cheers Mark,
Ed.
I read something funny the other day, it said: "The day you die will be like any other day - just shorter!"
« Reply #32 on: July 23, 2016, 02:32:11 pm »
This question is awkward to answer .. depending on the make/model of laptop you'll either have to
a) Find the key that rings up the boot device selection screen
b) Set the USB stick as the first boot device in the BIOS <-- this **may** already be the case, what happens if you just shut down the PC, insert the LiveUSB and turn on the PC .. does it show "Try Peppermint / Install Peppermint" or does it boot straight into Windows ? (if it offers "Try Peppermint / Install Peppermint", select "Try Peppermint" and let me know)
If it boots straight into Windows, let me know the make/model  of your PC.
« Last Edit: July 23, 2016, 02:33:51 pm by Mark Greaves (PCNetSpec) »
Offline Ed
    • Swap Shop
« Reply #33 on: July 27, 2016, 05:38:45 pm »
Hi again folks, sorry for delay, but I haven't been idle (makes a change says my wife), yes well... err, hmn!
Okay Mark, I have been having fun and games with the installation of Peppermint 7 and the following took place over the last few days...
Initially, I inserted the flash drive, pen drive, whatever - I never know what to call those things - and ran up the new HDD and selected: boot from USB. The first few attempts seemed to ignore my instructions and I discovered the machine had reverted to boot from Sata; however, it did eventually recognise the USB stick and presented me with the installer boot menu splash screen. I selected 'install Peppermint O/S' and my first attempt was rewarded with rows of figures and advice such as: "[3.143055] sd 8:0:0:0 [sdb] no catching mode page found", and then the machine froze.
On the second attempt I had similar numbers and thought: "oh no, here we go again", but then a reddish screen appeared with a moving circle, a globe, the words Peppermint and starting up - then I was presented with 5 rows of fuzzy, horizontal black and white lines and the machine seemed to crash again. I did this a few times and each time I got the same result - not because I'm an idiot (although some would give me an argument there) no, because I thought I might have been doing something slightly different each time. Eventually I recognise that I had done exactly the same thing each time and so it was time for a re-think.
This time I selected: 'try Peppermint live' and the system seemed to load up. Various screens appeared advising of the merits of Peppermint and then I was shown the programme selection buttons and all seemd okay apart from constant flashes over the screen. After the loading had completed I was advised to reboot, which I did, expecting the Peppermint screen to reappear - but nothing. And I mean nothing, I was just presented with a blanc screen. I tried rebooting a few more times, but the result was the same and that's where I am now.
I have thought long and hard about the experiences I have had and I feel that...
(1) the USB stick with the programme is working
(2) my machine seems to have recognised same
(3) the computer appears to have loaded Peppermint
(4) so all seems fine as regards Peppermint
So my thoughts return to the fuzzy screen and flashing and I am minded to think that my shiny new, 500 GiG, Hard Drive might be going gangster on me. So, before you and the other good people on this site begin to scrath your heads trying to figure out what might be wrong, let me test the HDD and determine it's state of health first.
Ed.
« Reply #34 on: July 27, 2016, 05:50:20 pm »
Sounds like a graphics driver issue.
If you can boot Peppermint from the USB stick by selecting "Try Peppermint" .. do so .. once at the desktop, open a terminal (Ctrl+Alt+T) and run this command
inxi -F
(note the capital F)
and post back here what's returned in the terminal.
Offline Ed
    • Swap Shop
« Reply #35 on: July 28, 2016, 06:47:27 pm »
I'm afraid to report that the above procedure was an unmitigated disaster, for which both me and my computer accept full responsibility.  :( I booted into 'Try Peppermint' a few times and this is what happened:
First Boot. All seemed well, the reddish screen appeared with the revolving circle and the starting up dialogue, then the black and white lines appeared and the screen went fuzzy again.
Second Boot: As above, but then the computer froze.
Third Boot: As above, and in each of these scenarios I lost the use of the mouse and keyboard - disconnecting and reconnecting made no difference - the computer would not recognise them.
Finally I loaded P7 as a dual boot with Win10, but on re-booting I was advised I had no 'Boot Mgr' - so now I could not access any O/S at all, not even MS. Still, in a way this did me a favour as I spent yesterday and today re-installing Win7 and my programmes and that is how I am now writing to this thread.
After much deliberation it seems to me that for some reason my computer will not accept Linux. Well I'm not beaten yet and I will emigrate to Linux and P7, but via a new computer and to that end I have been looking on the Internet.
I spent some time building a contemporary PC, online with PC Specialists, at the end of which I was advised that it was not advisable to put a Linux operating system on the particular configuration I had chosen. I suspect this is because they want to sell the MS O/S. Anyhow I have written asking them why Linux would be a bad choice; meanwhile could you Mark or anybody reading this thread recommend where I could get a good Linux ready Desktop PC, for not too many pennies?  ;)
Ed
« Reply #36 on: July 28, 2016, 07:08:23 pm »
If you can post the specs maybe we can check the hardware for known issues.
Offline Ed
    • Swap Shop
« Reply #37 on: July 29, 2016, 02:21:15 pm »
Hi again,
Please find below the information requested, I have included as much as I could to help you to help me, which as ever I value and I am grateful for.
Do you have any ideas re: a new computer? I would particularly like to buy a used one from a private individual, not because I am a mean t**t, but because I hate paying VAT, generally known as Value Added Tax (value, what value?) and which I call Vile Autocratic Theft, which I feel is a more accurate description of the scam.
Although it is virtually impossible not to pay VAT - as all of our big spends are covered, such as power and water, fuel etc - it is not necessary to pay it for everything and some years ago I began selling/buying and swapping my stuff to avoid the nasty thing, and for the most part I am successful as I will go out of my way to avoid it; I even have a website dedicated to avoiding paying it at: http://swappy.simplesite.com if anybody is interested.
Anyhow, here is the data requested:
Security Benchmark Score    0.63 of 10
Virus Protection OK    Up-to-date
Computer Profile Summary
Computer Name:    Edd-PC (in WORKGROUP)
Operating System Windows 7 Home Premium (x64) (build 7600)
Install Language: English (United States)
System Locale: English (United Kingdom)
Boot Mode: BIOS (Secure Boot not supported)
Enclosure Type: Desktop
Processor a
Main Circuit Board b3.20 gigahertz AMD Phenom II X6 1090T
768 kilobyte primary memory cache
3072 kilobyte secondary memory cache
64-bit ready
Multi-core (6 total)
Not hyper-threaded
Board: ASRock 770 Extreme3
Bus Clock: 200 megahertz
BIOS: American Megatrends Inc. P1.80 10/18/2010
Drives     Memory Modules c,d
1233.04 Gigabytes Usable Hard Drive Capacity
1122.12 Gigabytes Hard Drive Free Space
LITE-ON DVDRW SOHW-1673S ATA Device [Optical drive]
SAMSUNG HD103SJ [Hard drive] (1000.20 GB) -- drive 0, s/n S246J9AZC08395, rev 1AJ10001, SMART Status: Healthy
WDC WD2500JS-00MHB0 [Hard drive] (250.06 GB) -- drive 1, s/n WD-WCANK3096225, rev 02.01C03, SMART Status: Healthy             8192 Megabytes Usable Installed Memory
Slot 'DIMM0' has 2048 MB
Slot 'DIMM1' has 2048 MB
Slot 'DIMM2' has 2048 MB
Slot 'DIMM3' has 2048 MB
       Local Drive Volumes
c: (NTFS on drive 1) *    239.25 GB    172.60 GB free
d: (NTFS on drive 0)    248.08 GB    235.30 GB free
e: (NTFS on drive 0)    239.69 GB    238.28 GB free
f: (NTFS on drive 0)    247.50 GB    235.21 GB free
g: (NTFS on drive 0)    247.82 GB    230.26 GB free
h: (NTFS on drive 1)    10.70 GB    10.47 GB free
Display
ATA Channel 0 [Controller] (3x)
ATA Channel 1 [Controller] (3x)
Standard Dual Channel PCI IDE Controller (3x)
ATI Radeon HD 4350 (Microsoft Corporation WDDM 1.1) [Display adapter]
NVIDIA GeForce 6200 (Microsoft Corporation - WDDM) [Display adapter]
Acer AL1916 [Monitor] (19.3"vis, s/n 1695605694, December 2006)
Acer AL1916 [Monitor] (19.1"vis, s/n ETL490863470702251424F, February 2007)
HP 2311x [Monitor] (23.1"vis, s/n 3CQ220014C, May 2012)
Bus Adapters
  Microsoft - .NET Framework Version 2.0.50727.4927 (32/64-bit)
i
  Microsoft - .NET Framework Version 3.0.6920.4902 (32/64-bit)
  ıı
Thanks again,
Ed
Offline Ed
    • Swap Shop
« Reply #38 on: July 29, 2016, 02:30:41 pm »
Sorry, I must have hit POST by mistake and seem to have posted the same message twice. I have removed it from this space and inserted this text.
« Last Edit: July 29, 2016, 02:38:11 pm by Ed »
« Reply #39 on: July 29, 2016, 02:55:49 pm »
So you have 2 graphics cards and 3 monitors ?
Just as an experiment, what happens if you set either the ATI or nVidia adapter as the primary graphics adapter, then only have a single monitor connected ?
We can get around to the multi-monitor setup later, but at this point it would probably be a good idea to see if it's one of the graphics cards in particular that's causing the issue.
Offline Ed
    • Swap Shop
« Reply #40 on: August 01, 2016, 12:05:27 pm »
I have tried every possible combination and still I experience the same problems either trying P7 or loading P7, although Win7 is, and always has been, quite happy running with both video cards and the three monitors.
Anyhow I have been absolved from any further trouble-shooting as my granddaughter has solved my dilemma for me and all from a throw-a-way comment I made whilst day dreaming . I happened to say: "I'm getting fed-up with messing about with this damn computer and have asked on the forum where I might buy one with the Linux distro' installed."
She looked thoughtful for a moment and then said: That's what I should do; I should buy a new computer Linux ready and she would do me the great favour of taking my current machine, thereby relieving me of the headache of trying to install Linux on it.
Aren't kids really thoughtful? Or am I missing something? lol.
« Reply #41 on: August 01, 2016, 03:37:12 pm »
If you're in the market for a seccond hand Linux PC, just search ebay or similar .. there's plenty with say Ubuntu/Mint reinstalled.
If you have any questions before buying .. simply post a link here and we'll try to answer.
That said Linux works with pretty well with just about any hardware .. you've been extremely unlucky so far :(
Offline Ed
    • Swap Shop
« Reply #42 on: August 04, 2016, 07:23:31 pm »
Thanks for everything folks, I'm sorry if I have messed you around, but I have done all within my power to try/load P7, but my machine seems to be unable to run it.
I will let you know when I have the new machine up and running and I hope eventually to be able to repay your efforts by having some experience of Linux operating systems that I will be able to pass on. In the spirit of the film - Pay it Forward.
Ed.
« Reply #43 on: August 04, 2016, 07:43:50 pm »
Great attitude you have there Ed :)
Offline Ed
    • Swap Shop
« Reply #44 on: August 10, 2016, 03:45:13 pm »
I'm still on the hunt for a Unix machine and am having a chat with a bloke in Wales, but collecting is a bit of a problem at the moment. Meanwhile, I mentioned I had tried to build a machine with PC Specialists that I would load with P7, but they told me I could not do it with the specification I had chosen and I wrote asking them what would I need to build one. It's taken them long enough, but here is their reply, just for interest:
"Hi Edward,
Thank you for your email, I can confirm that we as a company do not support Linux at all.  This message will be visible on all systems at the moment as we do not test our systems on Linux and cannot guarantee that you will not have issues when using Linux.
If you have any other enquiries do not hesitate to contact us.
Regards,
Ryan Slinger
PC Specialist Support Team
PC Specialist Ltd, Unit 12 Jubilee Business Park, Jubilee Way, Grange Moor, Wakefield, WF4 4TD
( 0333 011 7000
enquiries@pcspecialist.co.uk
http://www.pcspecialist.co.uk"
So it would seem that my choice of spec' had nothing to do with it.
Ed.
