Author Topic: Problem installing Peppermint 7  (Read 1801 times)
Re: Problem installing Peppermint 7
« Reply #15 on: July 14, 2016, 08:27:33 pm »
Erm Peppermint 7 doesn't come with LibreOffice AT ALL .. so you MUST have installed it.
If I were you I'd reinstall the whole thing
sudo apt-get install --reinstall libre-office
Offline donwatson
  • Getting older
« Reply #16 on: July 14, 2016, 08:34:41 pm »
Thanks Mark,
I am happy now. Libre Office is working   :D
@ SeZo, Thanks for the advice. All is now well  ;)
take care
Don W
I think I will mark this thread solved as I seemed to have strayed from the original topic.
Novatech build
Peppermint 7    64 bit     500 GB HD        496 GB Ext 4
