Author Topic: where can I get drivers for my Epson SX 130 printer/scanner (SOLVED)  (Read 1575 times)
Offline donwatson
  • Getting older
I have looked back at these threads and found one I posted earlier. I have downloaded the first link and installedut it came with an error message. I ran the commands it gave and everything seems ok.
When I try to get the second link (and the third) I get a 404 not found error.
Can you help again ?
take care
Don W
EDIT When I go back to the desktop the' Package Installer ' error message is still there and I can't delete it ?
« Last Edit: July 14, 2016, 02:30:42 pm by donwatson »
Novatech build
Peppermint 7    64 bit     500 GB HD        496 GB Ext 4
Offline donwatson
  • Getting older
Re: where can I get drivers for my Epson SX 130 printer/scanner
« Reply #1 on: July 14, 2016, 02:29:57 pm »
Mark,
I have been to 'Printers' in the Menu and it installed the printer and printed the test page.
i then scanned this page and saved it a test and all is looking great.
Sorry to bother you.
take care
Don W
Novatech build
Re: where can I get drivers for my Epson SX 130 printer/scanner (SOLVED)
« Reply #2 on: July 14, 2016, 05:03:10 pm »
So is this all working now Don ?
Offline donwatson
  • Getting older
« Reply #3 on: July 14, 2016, 07:30:27 pm »
Yes thanks Mark.
It seemed to do it magically ?
I found the last thread you did for me on this printer and I installed the first link but it said all the dependencies were not met. I couldn't get rid of this screen so I rebooted.
I then chose 'Printers' from the menu and it more or less installed itself. Great result.
take care
Don W
Novatech build
