Author Topic: Flash problems revisited (solved)  (Read 1525 times)
Offline mikep
  • Full Member
  • Me again!
« on: August 10, 2016, 11:15:05 pm »
Hello folks,
I'm using Ubuntu 14.04 and Flash is working fine in Firefox - except on the channel 4 site.
It says I need to install or upgrade Adobe Flash Player.
However, when I run sudo apt-get install flashplugin-installer, I get the following
Reading package lists... Done
Building dependency tree
flashplugin-installer is already the newest version.
0 to upgrade, 0 to newly install, 0 to remove and 43 not to upgrade.
What is WRONG with Flash (or me)?
Thanks for any suggestions..
M
« Last Edit: September 11, 2016, 02:35:34 pm by mikep »
Re: Flash problems revisited
« Reply #1 on: August 11, 2016, 01:26:16 am »
Try Chrome
Offline mikep
  • Full Member
  • Me again!
« Reply #2 on: August 19, 2016, 09:08:16 pm »
I tend to avoid all things google..
Something about giant corporations sticking their noses into every aspect of my life seems to irritate me.
Offline Tramlink
  • Is the mist clearing
« Reply #3 on: August 30, 2016, 11:13:46 am »
You can Try chromium but you have to follow the instructions on their site to unable flash.
Offline SneakyTommy
« Reply #4 on: August 30, 2016, 02:14:04 pm »
try this:
http://superuser.com/questions/873093/firefox-thinks-im-using-and-older-flash-version
alternatively you can always use chromium's flash plugin in firefox
Offline mikep
  • Full Member
  • Me again!
« Reply #5 on: August 31, 2016, 12:30:50 am »
Thanks Guys,
Will look into these solutions and report back..
M
Offline mikep
  • Full Member
  • Me again!
Solved: Re: Flash problems revisited
« Reply #6 on: September 02, 2016, 08:53:56 pm »
Hello Folks,
The channel 4 site is now working in FF, which is very convenient as SneakyTommy's link and the difference between chrome and chromium were making my head hurt..
Looks like a C4 problem..  fingers crossed.
Thanks all. I'll mark this solved.
M
