Author Topic: Installing Peppermint on Asus Rog [ Solved]  (Read 2630 times)
Offline Hayder
  • Full Member
« on: August 16, 2016, 03:22:16 pm »
Hello
Today I got my new laptop Asus Rog gl552v, i7 6700hq 8g ram .
I downloaded peppermint 7 into usb , then enter the menu of peppermint ,choose live cd then ..... Stop at startup!!
I tried some other distro ( Ubuntu 16, mint 18) same thing.
I have Ubuntu 14 cd it's worked , but without touchpad !!
Ok install them , same problem no touchpad, try to upgrade to version 16 also stop working !
In BIOS
NO secure boot and no virtuallzation
Thanks
« Last Edit: August 17, 2016, 09:56:33 pm by Hayder »
Re: Installing Peppermint on Asus Rog
« Reply #1 on: August 16, 2016, 04:06:31 pm »
When you say Peppermint 7 stops at startup, what exactly happens ?
do you get as far as the Peppermint splash screen (with the spinner) ?
if so, hit the Esc or Tab key .. is anything displayed onscreen ?
« Reply #2 on: August 16, 2016, 04:17:01 pm »
Okay after some googling it seems the detection for the Elan touchpad was only added in the 4.3 or greater kernel.
but the ROG doesn't seem to like the 4.x kernels because of the skylake CPU (this is fixed in 4.5 onwards I think).
There is however a couple of kernel boot parameters that are supposed to work for the 4.4 kernel as used in Peppermint 7 / Ubuntu 16.04 / Mint 18 / etc.
Boot the Peppermint 7 (64bit) LiveDVD/LiveUSB, and when you get to the "Try Peppermint" or "Install Peppermint" screen, hit F6
now hit Esc
Now you should see some white writing at the bottom of screen that ends with:-
quiet splash ---
change that so it ends with:-
quiet splash acpi_osi=! idle=nomwait
and hit enter to boot.
Did it boot ?
Bug report:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1520519
« Last Edit: August 16, 2016, 04:30:19 pm by Mark Greaves (PCNetSpec) »
Offline Hayder
  • Full Member
« Reply #3 on: August 16, 2016, 04:46:41 pm »
Hello
When I hit F6 nothing happened , then press Esc , screen of GNU GRUB appear, then grub>
« Reply #4 on: August 16, 2016, 05:01:34 pm »
Oh sh** yeah it's different for UEFI .. I'll post instructions in a bit
« Reply #5 on: August 16, 2016, 05:18:29 pm »
Boot the Peppermint 7 (64bit) LiveDVD/LiveUSB, you should be presented with the GRUB menu...
now hit the E key (to edit)
Now you should see some white writing on screen where one of the lines ends with:-
quiet splash ---
change that line so it ends with:-
Did it boot ?
Offline Hayder
  • Full Member
« Reply #6 on: August 16, 2016, 05:28:34 pm »
Ok I write the line then boot.... Starting Up and .... Stop
I pressed Esc or Tab , nothing happens just freeze
« Reply #7 on: August 16, 2016, 05:37:31 pm »
Just as a matter of interest, does Ubuntu 16.10 (yaketty yak) work, including the touchpad ?
(which theoretically should have skylake support baked in)
You can download the daily build of yakety here:
http://cdimage.ubuntu.com/daily-live/current/yakkety-desktop-amd64.iso
« Last Edit: August 16, 2016, 05:40:58 pm by Mark Greaves (PCNetSpec) »
Offline Hayder
  • Full Member
« Reply #8 on: August 16, 2016, 05:41:56 pm »
Let me download it and try?
Also as I notice the only version that is worked is booted from CD not usb!
Is there problem with transfer iso into usb ? I'm using Rufus ?
Offline Hayder
  • Full Member
« Reply #9 on: August 16, 2016, 05:52:47 pm »
It's also stop working....
« Reply #10 on: August 16, 2016, 06:05:42 pm »
it **might** be a problem with Rufus .. try something else such as
https://sourceforge.net/projects/win32diskimager/
or maybe
https://www.etcher.io/
Have you tried a different USB port ?
« Reply #11 on: August 16, 2016, 06:13:22 pm »
Try this ...
quiet splash ---
quiet splash nouveau.modeset=0 tpm_tis.interrupts=0 acpi_osi=! acpi_backlight=native i915.preliminary_hw_support=1 idle=nomwait
the above is all one line, eg.
Did it boot ?
Source:
https://rog.asus.com/forum/showthread.php?81702-Linux-installation-in-ASUS-ROG-GL552VW-DH71/page2
« Last Edit: August 16, 2016, 06:16:00 pm by Mark Greaves (PCNetSpec) »
Offline Hayder
  • Full Member
« Reply #12 on: August 16, 2016, 06:26:55 pm »
It's worked...
But no touchpad
« Reply #13 on: August 16, 2016, 06:36:52 pm »
Peppermint 7 worked ?
Offline Hayder
  • Full Member
« Reply #14 on: August 16, 2016, 06:42:27 pm »
Yes
