Author Topic: Installing Peppermint on Asus Rog [ Solved]  (Read 2629 times)
Re: Installing Peppermint on Asus Rog
« Reply #15 on: August 16, 2016, 06:49:13 pm »
Can you post the output from:
inxi -F
xinput --list
Offline Hayder
  • Full Member
« Reply #16 on: August 16, 2016, 06:58:57 pm »
I can't cause the mouse not working
How to select from terminal?
« Reply #17 on: August 16, 2016, 07:27:49 pm »
Try running:
sudo apt-get install xserver-xorg-input-libinput
does the touchpad work now ?
Offline Hayder
  • Full Member
« Reply #18 on: August 16, 2016, 07:40:20 pm »
No
« Reply #19 on: August 16, 2016, 08:05:01 pm »
Try that on the installed version of Peppermint 6 .. as it may require a reboot before the changes are picked up (you can't do this on a Live session)
OR
Try the working boot parameters on the Ubuntu 16.10 live session
Offline Hayder
  • Full Member
« Reply #20 on: August 16, 2016, 09:10:03 pm »
ystem:    Host: peppermint Kernel: 4.4.0-24-generic x86_64 (64 bit)
           Desktop: N/A Distro: Peppermint Seven
Machine:   System: ASUSTeK (portable) product: GL552VX v: 1.0
           Mobo: ASUSTeK model: GL552VX v: 1.0
           Bios: American Megatrends v: GL552VX.204 date: 01/28/2016
CPU:       Quad core Intel Core i7-6700HQ (-HT-MCP-) cache: 6144 KB
           clock speeds: max: 3500 MHz 1: 1439 MHz 2: 1368 MHz 3: 1554 MHz
           4: 1424 MHz 5: 1421 MHz 6: 1460 MHz 7: 1530 MHz 8: 1486 MHz
Graphics:  Card-1: Intel Skylake Integrated Graphics
           Card-2: NVIDIA GM107M [GeForce GTX 950M]
           Display Server: X.Org 1.18.3 drivers: intel (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.02hz
           GLX Renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2)
           GLX Version: 3.0 Mesa 11.2.0
Audio:     Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.4.0-24-generic
Network:   Card-1: Intel Wireless 8260 driver: iwlwifi
           IF: wlp2s0 state: up mac: a4:34:d9:98:7f:0b
           Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169
           IF: enp3s0f1 state: down mac: 9c:5c:8e:2a:78:3d
Drives:    HDD Total Size: 1032.1GB (0.5% used)
           ID-1: /dev/sda model: HGST_HTS721010A9 size: 1000.2GB
           ID-2: USB /dev/sdb model: Wireless_Drive size: 31.9GB
Partition: ID-1: / size: 3.9G used: 38M (1%) fs: overlay dev: N/A
           ID-2: swap-1 size: 0.52GB used: 0.00GB (0%) fs: swap dev: /dev/zram0
           ID-3: swap-2 size: 0.52GB used: 0.00GB (0%) fs: swap dev: /dev/zram1
           ID-4: swap-3 size: 0.52GB used: 0.00GB (0%) fs: swap dev: /dev/zram2
           ID-5: swap-4 size: 0.52GB used: 0.00GB (0%) fs: swap dev: /dev/zram3
           ID-6: swap-5 size: 0.52GB used: 0.00GB (0%) fs: swap dev: /dev/zram4
           ID-7: swap-6 size: 0.52GB used: 0.00GB (0%) fs: swap dev: /dev/zram5
           ID-8: swap-7 size: 0.52GB used: 0.00GB (0%) fs: swap dev: /dev/zram6
           ID-9: swap-8 size: 0.52GB used: 0.00GB (0%) fs: swap dev: /dev/zram7
Sensors:   System Temperatures: cpu: 50.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 1500
Info:      Processes: 238 Uptime: 4 min Memory: 563.7/7876.3MB
           Client: Shell (bash) inxi: 2.2.35
Offline Hayder
  • Full Member
« Reply #21 on: August 16, 2016, 09:10:44 pm »
peppermint@peppermint ~ $ xinput --list
⎡ Virtual core pointer                       id=2   [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                 id=4   [slave  pointer  (2)]
⎜   ↳ Elan Touchpad                              id=11   [slave  pointer  (2)]
⎜   ↳  USB OPTICAL MOUSE                         id=14   [slave  pointer  (2)]
⎣ Virtual core keyboard                      id=3   [master keyboard (2)]
    ↳ Virtual core XTEST keyboard                id=5   [slave  keyboard (3)]
    ↳ Power Button                               id=6   [slave  keyboard (3)]
    ↳ Video Bus                                  id=7   [slave  keyboard (3)]
    ↳ Video Bus                                  id=8   [slave  keyboard (3)]
    ↳ Sleep Button                               id=9   [slave  keyboard (3)]
    ↳ USB2.0 HD UVC WebCam                       id=10   [slave  keyboard (3)]
    ↳ Asus WMI hotkeys                           id=12   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard               id=13   [slave  keyboard (3)]
« Reply #22 on: August 16, 2016, 10:54:43 pm »
Hmm .. it's showing the Elan touchpad .. are you sure you haven't simply disabled it with a key combo or something ?
Offline Hayder
  • Full Member
« Reply #23 on: August 16, 2016, 11:26:51 pm »
I was trying to enable it but no way ! Fn+ f7
Offline Hayder
  • Full Member
« Reply #24 on: August 16, 2016, 11:30:53 pm »
its working now ... i try F7 not fn + F7 and it is ok.
now how can i install the full version??
« Reply #25 on: August 17, 2016, 12:54:35 am »
Of Peppermint 7 ?
Boot using those parameter
Install Peppermint 7 (from the icon on the live desktop)
Once installed, and you need to reboot .. use those parameters again on the first boot from the hard drive.
When the system is booted, open a terminal and run:
sudo pluma /etc/default/grub
find the line that reads
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
and change it to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nouveau.modeset=0 tpm_tis.interrupts=0 acpi_osi=! acpi_backlight=native i915.preliminary_hw_support=1 idle=nomwait"
SAVE the file and exit pluma
back in the terminal run:
sudo update-grub
it should now boot without user intervention.
Then come back here and tell me you've got it booting and we'll install the nvidia drivers and remove part of those parameters.
Offline Hayder
  • Full Member
« Reply #26 on: August 17, 2016, 09:06:48 am »
Good morning Mark
It's ok now , the install completed and the mouse ok
« Reply #27 on: August 17, 2016, 10:39:41 am »
Great stuff :)
Offline Hayder
  • Full Member
« Reply #28 on: August 17, 2016, 07:32:52 pm »
Thank you very much for your help.
Thanks Mark
« Reply #29 on: August 17, 2016, 07:56:59 pm »
You're most welcome Hayder :)
If this is now solved, can you please remember to mark it so by editing the FIRST posting in this topic and changing:-
Subject: Installing Peppermint on Asus Rog (SOLVED)
Thanks in advance :)
