Author Topic: How to merge two partitions ? [Solved}  (Read 938 times)
Offline Hayder
  • Full Member
« on: August 17, 2016, 11:19:17 pm »
Hello
After installing peppermint , and it's ok, I split Windows partition to add more space to Linux peppermint , how can I add the unallocated partition to peppermint partition?
« Last Edit: August 18, 2016, 08:44:28 pm by Hayder »
Re: How to merge two partitions ?
« Reply #1 on: August 18, 2016, 12:22:54 am »
Can you explain that a little clearer ?
I take it you mean you SHUNK the Windows partition leaving unpartitioned space on the drive ?
Any chance you can fire up gparted, take a screenshot showing your partition layout, host the screenshot online somewhere such as
http://imgur.com
then post a link to it, so we can take a looksee.
« Last Edit: August 18, 2016, 12:24:53 am by Mark Greaves (PCNetSpec) »
Offline Hayder
  • Full Member
« Reply #2 on: August 18, 2016, 01:01:47 am »
Hello Mark
http://imgur.com/a/2Vbqe
I have partition called Linux , its free, and want to add it to peppermint partiton
« Reply #3 on: August 18, 2016, 11:19:26 am »
Okay, boot to a Peppermint LiveCD/LiveUSB (as you can't resize/move the Linux partition if it's mounted) and fire up GParted
Delete the partition labelled "linux" leaving just empty space.
MOVE (not resize) the sda5 partition to the left so it now starts immediately after the sda4 partition and the unprtitioned space is now to the right of it.
THEN resize sda5 (from the right) into the unpartitioned space.
did that make sense to you ?
BTW, if the system ends up unbootable DON'T panic and start reinstalling .. it just means GRUB need reinstalling or fstab adjusting .. we'll get to that if it becomes necessary.
Offline Hayder
  • Full Member
« Reply #4 on: August 18, 2016, 12:58:52 pm »
it's OK dear , all done
but why the power bottomn is not active??
http://imgur.com/a/U68QP
so i must press physical power to get the menu for shutdown and restart?
Offline Hayder
  • Full Member
« Reply #5 on: August 18, 2016, 06:22:51 pm »
also backlit keyboard dosent work
« Reply #6 on: August 18, 2016, 07:01:21 pm »
is this a fresh install, or did you keep a /home partition from another distro or version ?
(this should already be done by default, so something's wrong)
Right-click the menu button (bottom left of screen) and select "Properties"
on the "Commands" tab set
All Settings: peppermint-settings-panel
Lock Screen: xflock4
Switch Users: lxsession switch-users
Log Out: peppermint-logout
Edit Profile: users-admin
All of those should also be ticked
DO NOT tick and use the "Edit Application" item .. there is no 100% safe menueditor for LXDE, using one will mess up your menu
The "Favourites" menu should also be populated, so as I said something went wrong .. most likely a reused /home partition ?
Offline Hayder
  • Full Member
« Reply #7 on: August 18, 2016, 08:12:43 pm »
its fresh install , i shrink Windows volume between pepermint and windows
now the power bottomn is OK , just the keyboard lights is missing
« Reply #8 on: August 18, 2016, 08:25:36 pm »
Is there not a keyboard shortcut for turning on/of the keyboard baclight ?
does this command turn it on:
echo 3 > /sys/class/leds/asus::kbd_backlight/brightness
Offline Hayder
  • Full Member
Re: How to merge two partitions ? [Solved}
« Reply #9 on: August 18, 2016, 08:45:06 pm »
it works, thank you very much
