Author Topic: brother mfc-j5910dw problems (solved)  (Read 2081 times)
Offline donwatson
  • Getting older
« on: August 20, 2016, 02:09:38 pm »
I have been gifted a Brother MFC-J5910DW all in one printer ( it seems to be able to do everything except make a cuppa).
I have downloaded the drivers from their website, linux-brprinter-installer-2.0.0-1.gz and mfcj5910dwlpr-3.0.0-1.i386.deb and mfcj5910dwcupswrapper-3.0.0-1.i386.deb.
The driver site says the drivers need installed via the terminal, how do I install these drivers? please.
take care
Don W
EDIT I have the following instructions
Step1. Download the tool.(linux-brprinter-installer-*.*.*-*.gz)
The tool will be downloaded into the default "Download" directory.
(The directory location varies depending on your Linux distribution.)
e.g. /home/(LoginName)/Download
Step2. Open a terminal window and go to the directory you downloaded the file to in the last step.
Step3. Enter this command to extract the downloaded file:
Command: gunzip linux-brprinter-installer-*.*.*-*.gz
Step4. Get superuser authorization with the "su" command or "sudo su" command.
Step5. Run the tool:
Command: bash linux-brprinter-installer-*.*.*-* Brother machine name
Step6. The driver installation will start. Follow the installation screen directions.
 When you see the message "Will you specify the DeviceURI ?",
 For USB Users: Choose N(No)
I have completed Step3 and am stuck at Step4. Is the next command
sudo bash linux-brprinter-installer-*.*.*-* Brother MFC-J5910DW ?
I am worried about putting in commands that may alter what I don't want altered.
« Last Edit: September 12, 2016, 07:44:15 pm by donwatson »
Novatech build
Peppermint 7    64 bit     500 GB HD        496 GB Ext 4
Offline SeZo
Re: brother mfc-j5910dw problems
« Reply #1 on: August 20, 2016, 03:19:48 pm »
That would be:
bash linux-brprinter-installer-*.*.*-* MFC-J5910DW
Offline donwatson
  • Getting older
« Reply #2 on: August 20, 2016, 04:22:59 pm »
Thanks SeZo,
I have run that command and I have installed the other 2 packages.
When I run dpkg -l | grep Brother I get
don@ldwatson ~ $ dpkg -l | grep Brother
ii  brscan-skey                                   0.2.4-1                                    amd64        Brother Linux scanner S-KEY tool
ii  brscan4                                       0.4.3-3                                    amd64        Brother Scanner Driver
ii  mfcj5910dwcupswrapper:i386                    3.0.0-1                                    i386         Brother CUPS Inkjet Printer Definitions
ii  mfcj5910dwlpr:i386                            3.0.0-1                                    i386         Brother lpr Inkjet Printer Definitions
don@ldwatson ~ $
So it looks as if I have completed it all successfully. I won't be able to try it out until Monday as my Grandson is here till then, but thanks for your help.
Novatech build
Offline donwatson
  • Getting older
« Reply #3 on: August 21, 2016, 09:58:08 am »
Had a quick try at using this printer but I can't get a response from it.
I notice when I open my Home folder I have a 'Network' icon and it says Network, when I click on that it shows 2 icons, 'LDWATSON' and 'Windows Network'. When I tunnel down the 'Windows Network' ends at the 'LDWATSON' icon and asks for a password to connect the 'print$'.
Any ideas ?
EDIT I have had a good go at trying out this printer and have downloaded the various manuals from the Brother site but without the installation disc I can't seem to get the computer to talk to the printer ?
« Last Edit: August 21, 2016, 07:26:36 pm by donwatson »
Novatech build
Offline donwatson
  • Getting older
« Reply #4 on: August 23, 2016, 02:49:35 pm »
The printer is working ok with Windoze. When I check the 'Printers' folder it says 'waiting for printer to become available'.
I think there was a bit when I installed the drivers and it asked if I wanted a test print, I said no, maybe I should have said yes ?
Novatech build
« Reply #5 on: August 23, 2016, 03:35:12 pm »
You wanna supply a link to the drivers page .. and the instructions you followed ?
Offline donwatson
  • Getting older
« Reply #6 on: August 23, 2016, 07:55:55 pm »
I got the 3 files from the Brother site http://support.brother.com/g/b/manualtop.aspx?c=sg&lang=en&prod=mfcj5910dw_all
They were  linux-brprinter-installer-2.0.0-1.gz and mfcj5910dwlpr-3.0.0-1.i386.deb and mfcj5910dwcupswrapper-3.0.0-1.i386.deb.
I thought these would be ok. ?
Novatech build
« Reply #7 on: August 27, 2016, 10:31:31 pm »
Okay, it looks like you're running a 64bit distro but you've downloaded ALL 32bit drivers
The scanner drivers are available in 64bit
but the printer driver is 32bit only but it can still be used in 64bit Linux as long as you have lib32stdc++ installed
What's the output from:
uname -a
dpkg -l | grep lib32stdc
Link for future reference:
http://support.brother.com/g/b/downloadlist.aspx?c=us&lang=en&prod=mfcj5910dw_all&os=128
Offline donwatson
  • Getting older
« Reply #8 on: August 28, 2016, 12:21:48 pm »
Is this what you are looking for
don@ldwatson ~ $ uname -a
Linux ldwatson 4.4.0-34-generic #53-Ubuntu SMP Wed Jul 27 16:06:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
don@ldwatson ~ $ dpkg -l | grep lib32stdc
ii  lib32stdc++6                                  5.4.0-6ubuntu1~16.04.2                     amd64        GNU Standard C++ Library v3 (32 bit Version)
don@ldwatson ~ $
Novatech build
Offline donwatson
  • Getting older
« Reply #9 on: August 31, 2016, 02:20:15 pm »
I have tried a new install of the drivers
Linux ldwatson 4.4.0-36-generic #55-Ubuntu SMP Thu Aug 11 18:01:55 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
don@ldwatson ~ $
So far I have ran the Test page successfully, printed a colour picture and printed a drawing from DraftSight.
I only get a black llne in DraftSight, no colours, so I reckon there is a problem with the DraftSight configuration.
I will try the scanner later to check if it is working but it all looks good at the moment.
I will mark this solved before the weekend.
take care
Don W
Novatech build
« Reply #10 on: August 31, 2016, 02:23:54 pm »
Great news because I couldn't see anything wrong and was just assuming the drivers no longer worked with recent distros.
Offline donwatson
  • Getting older
« Reply #11 on: August 31, 2016, 04:06:35 pm »
I can't scan from the printer and send it to the computer.
I printed an A4 page from DraftSight to the printer. I then put the print in the scanner, opened 'Simple Scan' and it says 'Failed to Scan' Unable to connect to scanner. Any ideas where I have gone wrong ?
take care
Don W
EDIT This is the result of 'localhost:631/printers'
Showing 3 of 3 printers.
▼ Queue Name ▼   Description   Location   Make and Model   Status
EPSON-Epson-Stylus-SX130   EPSON Epson Stylus SX130   ldwatson   Epson Stylus SX115 - CUPS+Gutenprint v5.2.11   Idle
HP-Photosmart-7800-series   HP Photosmart 7800 series   ldwatson   HP PhotoSmart 7550 - CUPS+Gutenprint v5.2.11   Idle
MFCJ5910DW   MFCJ5910DW      Brother MFC-J5910DW CUPS   Idle
« Last Edit: August 31, 2016, 04:38:45 pm by donwatson »
Novatech build
« Reply #12 on: September 01, 2016, 01:19:56 pm »
scanimage -L
sudo scanimage -L
sane-find-scanner
sudo sane-find-scanner
Offline donwatson
  • Getting older
« Reply #13 on: September 01, 2016, 07:47:49 pm »
Does this help
don@ldwatson ~ $ scanimage -L
The program 'scanimage' is currently not installed. You can install it by typing:
sudo apt install sane-utils
don@ldwatson ~ $ sudo scanimage -L
[sudo] password for don:
sudo: scanimage: command not found
don@ldwatson ~ $ sane-find-scanner
The program 'sane-find-scanner' is currently not installed. You can install it by typing:
don@ldwatson ~ $ sudo sane-find-scanner
sudo: sane-find-scanner: command not found
don@ldwatson ~ $
Novatech build
« Reply #14 on: September 02, 2016, 02:29:24 pm »
run
sudo apt-get install sane-utils
then try those commands again
