Author Topic: brother mfc-j5910dw problems (solved)  (Read 3051 times)
Offline donwatson
  • Getting older
Re: brother mfc-j5910dw problems
« Reply #15 on: September 02, 2016, 05:47:45 pm »
Hi mark,
I get this
don@ldwatson ~ $ scanimage -L
device `brother4:bus1;dev1' is a Brother MFC-J5910DW USB scanner
don@ldwatson ~ $ sudo scanimage -L
[sudo] password for don:
don@ldwatson ~ $ sane-find-scanner
  # sane-find-scanner will now attempt to detect your scanner. If the
  # result is different from what you expected, first make sure your
  # scanner is powered up and properly connected to your computer.
  # No SCSI scanners found. If you expected something different, make sure that
  # you have loaded a kernel SCSI driver for your SCSI adapter.
could not open USB device 0x0bda/0x8723 at 002:004: Access denied (insufficient permissions)
could not open USB device 0x248a/0x8566 at 002:003: Access denied (insufficient permissions)
could not open USB device 0x04f9/0x0288 at 002:007: Access denied (insufficient permissions)
could not open USB device 0x093a/0x2510 at 002:006: Access denied (insufficient permissions)
could not open USB device 0x0a05/0x7211 at 002:005: Access denied (insufficient permissions)
could not open USB device 0x8087/0x0024 at 002:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 002:001: Access denied (insufficient permissions)
could not open USB device 0x8087/0x0024 at 001:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)
  # No USB scanners found. If you expected something different, make sure that
  # you have loaded a kernel driver for your USB host controller and have setup
  # the USB system correctly. See man sane-usb for details.
  # Not checking for parallel port scanners.
  # Most Scanners connected to the parallel port or other proprietary ports
  # can't be detected by this program.
  # You may want to run this program as root to find all devices. Once you
  # found the scanner devices, be sure to adjust access permissions as
  # necessary.
don@ldwatson ~ $ sudo sane-find-scanner
found USB scanner (vendor=0x04f9 [Brother], product=0x0288 [MFC-J5910DW]) at libusb:002:007
could not fetch string descriptor: Pipe error
  # Your USB scanner was (probably) detected. It may or may not be supported by
  # SANE. Try scanimage -L and read the backend's manpage.
EDIT don@ldwatson ~ $ scanimage -L
don@ldwatson ~ $
I ran the above and this is what I get.
« Last Edit: September 05, 2016, 09:17:53 am by donwatson »
Novatech build
Peppermint 7    64 bit     500 GB HD        496 GB Ext 4
Offline donwatson
  • Getting older
« Reply #16 on: September 12, 2016, 07:43:32 pm »
I have the printer printing in A4 size so I will leave this for the moment.
Novatech build
