Author Topic: Is it safe to update kernel? [Solved}  (Read 1709 times)
0 Members and 3 Guests are viewing this topic.
Offline Hayder
  • Full Member
« on: August 23, 2016, 12:46:14 am »
Hello
Is it ok to update my kernel to 4.7.1? How?
Thanks
« Last Edit: August 23, 2016, 03:31:13 pm by Hayder »
Re: Is it safe to update kernel?
« Reply #1 on: August 23, 2016, 12:55:10 am »
In which distro / version / architecture ?
Offline Hayder
  • Full Member
« Reply #2 on: August 23, 2016, 11:38:58 am »
In peppermint 7
System:    Host: hayder-GL552VX Kernel: 4.4.0-34-generic x86_64 (64 bit)
           Desktop: N/A Distro: Peppermint Seven
Machine:   System: ASUSTeK (portable) product: GL552VX v: 1.0
           Mobo: ASUSTeK model: GL552VX v: 1.0
           Bios: American Megatrends v: GL552VX.204 date: 01/28/2016
CPU:       Quad core Intel Core i7-6700HQ (-HT-MCP-) cache: 6144 KB
           clock speeds: max: 3500 MHz 1: 921 MHz 2: 922 MHz 3: 983 MHz
           4: 946 MHz 5: 909 MHz 6: 996 MHz 7: 910 MHz 8: 900 MHz
Graphics:  Card-1: Intel Skylake Integrated Graphics
           Card-2: NVIDIA GM107M [GeForce GTX 950M]
           Display Server: X.Org 1.18.3 drivers: intel (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.02hz
           GLX Renderer: Mesa DRI Intel HD Graphics 530 (Skylake GT2)
           GLX Version: 3.0 Mesa 11.2.0
Audio:     Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.4.0-34-generic
Network:   Card-1: Intel Wireless 8260 driver: iwlwifi
           IF: wlp2s0 state: up mac: a4:34:d9:98:7f:0b
           Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
« Last Edit: August 23, 2016, 11:49:31 am by Hayder »
« Reply #3 on: August 23, 2016, 02:46:04 pm »
do you want 4.7.1 in particular or 4.7.2 ?
Offline Hayder
  • Full Member
« Reply #4 on: August 23, 2016, 02:46:58 pm »
newest is better  8)
« Reply #5 on: August 23, 2016, 03:04:15 pm »
Okay, open a terminal and run these commands in sequence:
mkdir ~/Desktop/kernel-4.7.2
cd ~/Desktop/kernel-4.7.2
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.7.2/linux-headers-4.7.2-040702-generic_4.7.2-040702.201608201334_amd64.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.7.2/linux-headers-4.7.2-040702_4.7.2-040702.201608201334_all.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.7.2/linux-image-4.7.2-040702-generic_4.7.2-040702.201608201334_amd64.deb
sudo dpkg -i *.deb
then REBOOT
Once rebooted, check which kernel you're using with
uname -a
Offline Hayder
  • Full Member
« Reply #6 on: August 23, 2016, 03:19:06 pm »
ok it works....
but why you dont put it in peppermint 7 installation iso ? or the kernel is updated quickly?
thanks for your kindly help
« Reply #7 on: August 23, 2016, 03:20:49 pm »
a) because the 4.7 kernel series wasn't available when Peppermint 7 was released.
b) because the 4.4 kernel series is the officially supported long-term-support kernel upstream .. so it makes no sense for us to use anything else or we couldn't call Peppermint 7 a "long term support" release (because it wouldn't be).
c) there's no 100% guarantee it'll work with all third party drivers and the xorg version frm xenial
d) keeping everyone on the LTS kernel makes support more consistent.
e) the vast majority of users will not benefit from the 4.7 kernel in any way (cutting their support length for no good reason) .. in fact at this point using it in xenial it's MUCH more likely to cause problems than solve them as xenial/16.04 was built (and tested) around the 4.4 LTS kernel.
« Last Edit: August 23, 2016, 03:32:48 pm by Mark Greaves (PCNetSpec) »
