Author Topic: how to run mail command? [ Solved]  (Read 1559 times)
Offline Hayder
  • Full Member
« on: August 26, 2016, 06:14:11 pm »
Hello
I try to use mail command, but after i type mail in terminal the system suggest to install it by apt-get install mailutils
Ok its downloaded but need some configuration
http://imgur.com/a/3V8sn
i try  to configure it but i got this picture each time
« Last Edit: August 26, 2016, 08:30:44 pm by Hayder »
Offline nomko
  • Using Linux since Ubuntu version 7.04
    • Tips for Linux
Re: how to run mail command? [ Solved]
« Reply #1 on: September 02, 2016, 01:09:12 pm »
Hi,
I noticed you marked your thread as solved.
Could you inform us how you solved your problem?
thanks!
MSI GE70-2PE Hybrid laptop:
Quad core Intel Core i7-4710HQ*Kingston 16 GB RAM*Intel 4th Gen. Integr. GPU/NVidia GeForce GTX860M*Qualcomm Atheros Killer E2200/Intel Wireless 3160*128 GiB SSD*1 TB HDD*17.3" Full HD anti-glare LCD panel
Offline Hayder
  • Full Member
« Reply #2 on: September 02, 2016, 07:55:49 pm »
Hello
 I try to run mail then address but i fail, so
- install ssmtp
sudo apt-get install ssmtp
- then edit config  file
gksu gedit /etc/ssmtp/ssmtp.conf
- add your email preferences
root=username@gmail.com
mailhub=smtp.gmail.com:465
rewriteDomain=gmail.com
AuthUser=username
AuthPass=password
FromLineOverride=YES
UseTLS=YES
- then
email name@mail.com
I think this is the steps
