Author Topic: prospective linux user  (Read 13113 times)
0 Members and 3 Guests are viewing this topic.
Re: prospective linux user
« Reply #120 on: November 27, 2016, 03:53:34 pm »
okay now run:
sudo rfkill unblock all
sudo rfkill unblock 1
sudo rfkill unblock 2
then post the output from:
rfkill list
sudo iwlist scan
Offline Osmond
« Reply #121 on: November 27, 2016, 07:05:16 pm »
robert@robert-UX301LAB ~ $ rfkill list
0: hci0: Bluetooth
   Soft blocked: no
   Hard blocked: no
1: phy0: Wireless LAN
   Soft blocked: no
   Hard blocked: no
2: asus-wlan: Wireless LAN
   Soft blocked: no
   Hard blocked: no
3: asus-bluetooth: Bluetooth
   Soft blocked: no
   Hard blocked: no
robert@robert-UX301LAB ~ $ sudo iwlist scan
[sudo] password for robert:
wlp2s0    Interface doesn't support scanning : Network is down
enx9cebe8381a77  Interface doesn't support scanning.
« Reply #122 on: November 27, 2016, 07:07:49 pm »
what's the output from
iwconfig
After doing the above, and whilst still connected via an ethernet cable, run these commands in sequence
sudo apt-get upgrade
sudo apt-get dist-upgrade
once that has finished, REBOOT
Once rebooted, post the output from:
uname -a
sudo lshw -C network
« Last Edit: November 27, 2016, 07:15:17 pm by Mark Greaves (PCNetSpec) »
Offline Osmond
« Reply #123 on: November 27, 2016, 09:59:11 pm »
robert@robert-UX301LAB ~ $ iwconfig
wlp2s0    IEEE 802.11abgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
enx9cebe8381a77  no wireless extensions.
Offline Osmond
« Reply #124 on: November 27, 2016, 10:04:14 pm »
robert@robert-UX301LAB ~ $ uname -a
Linux robert-UX301LAB 4.4.0-24-generic #43-Ubuntu SMP Wed Jun 8 19:27:37 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
robert@robert-UX301LAB ~ $ sudo lshw -C network
  *-network DISABLED
       product: Wireless 7265
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlp2s0
       version: 59
       serial: 18:5e:0f:9d:77:a4
       width: 64 bits
       configuration: broadcast=yes driver=iwlwifi driverversion=4.4.0-24-generic firmware=16.242414.0 latency=0 link=no multicast=yes wireless=IEEE 802.11abgn
       resources: irq:49 memory:f7000000-f7001fff
  *-network
       physical id: 1
       logical name: enx9cebe8381a77
       serial: 9c:eb:e8:38:1a:77
       capacity: 1Gbit/s
       capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v1.08.2 duplex=full ip=192.168.1.4 link=yes multicast=yes port=MII speed=100Mbit/s
« Reply #125 on: November 28, 2016, 11:37:47 am »
run:
nmcli radio wifi on
nmcli dev wifi list
« Last Edit: November 28, 2016, 11:39:27 am by Mark Greaves (PCNetSpec) »
Offline Osmond
« Reply #126 on: November 28, 2016, 07:32:38 pm »
robert@robert-UX301LAB ~ $ nmcli dev wifi list
*  SSID        MODE   CHAN  RATE       SIGNAL  BARS  SECURITY
   ZyXEL_8E20  Infra  8     54 Mbit/s  80      ???_  WPA1 WPA2
« Reply #127 on: November 29, 2016, 01:21:41 pm »
is that your network (ZyXEL_8E20) ?
Can you connect to it ?
and if so, does it survive a reboot ?
Offline Osmond
« Reply #128 on: November 29, 2016, 02:52:33 pm »
Yes. No.
« Reply #129 on: November 29, 2016, 07:41:59 pm »
Okay, can you reboot (so it's NOT working) then post the output from:
rfkill list
nmcli dev
Offline Osmond
« Reply #130 on: November 29, 2016, 08:25:26 pm »
0: hci0: Bluetooth
   Soft blocked: no
   Hard blocked: no
   Soft blocked: no
   Hard blocked: no
   Soft blocked: no
   Hard blocked: no
   Soft blocked: no
   Hard blocked: no
DEVICE           TYPE      STATE         CONNECTION
enx9cebe8381a77  ethernet  connected     Wired connection 1
wlp2s0           wifi      disconnected  --
lo               loopback  unmanaged     --
« Reply #131 on: November 30, 2016, 03:12:17 pm »
Okay that looks like wireless is working, just that it's not connected.
Right-click on the networkmanager icon (by the clock) and select "Edit Connections"
If there is a WiFi connection listed called "ZyXEL_8E20", click on it to highlight it, then click the "Delete" button.
Click the "Close" button.
Now normal (left) click the networkmanager icon (by the clock) and in the list of networks click on "ZyXEL_8E20" .. you should be prompted for your wireless password .. enter it and click "Connect".
Offline Osmond
« Reply #132 on: November 30, 2016, 06:16:00 pm »
Wireless password? Is this a feature of the router ZyXEL_8E20? I have a wi-fi  key, WPS pin, IP address, User name, MAC address and Password all to  do with the router. Have tried wi-fi key and Pin to no effect
Offline SeZo
« Reply #133 on: November 30, 2016, 08:27:02 pm »
Can you log into the router and see what passphrase was set for the wireless?
I assume the security is WPA-WPA2.
If you have tried the correct passphrase and still would not connect, then (just to prove it is able to connect) disable the wireless security on the router. Once established that it can connect to the router without security, then put your router security back to what it was before.
Offline Osmond
« Reply #134 on: November 30, 2016, 09:50:33 pm »
I've found a "Homegroup" password. That didn't work. The security type of the router is WPA2-PSK. I don't know how to disable/enable the router security.
