Author Topic: prospective linux user  (Read 11381 times)
Offline Osmond
Re: prospective linux user
« Reply #150 on: December 15, 2016, 08:32:45 am »
Disk /dev/ram9: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram10: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram11: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram12: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram13: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram14: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram15: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/sda: 119.2 GiB, 128035676160 bytes, 250069680 sectors
Disklabel type: gpt
Disk identifier: A7916F7F-7415-4267-8630-3243538D5BFD
Device         Start       End   Sectors  Size Type
/dev/sda1       2048    534527    532480  260M EFI System
/dev/sda2     534528    567295     32768   16M Microsoft reserved
/dev/sda3     567296 161768242 161200947 76.9G Microsoft basic data
/dev/sda4  249047040 250068991   1021952  499M Windows recovery environment
/dev/sda5  161769472 232468479  70699008 33.7G Linux filesystem
/dev/sda6  232468480 249047039  16578560  7.9G Linux swap
Partition table entries are not in disk order.
robert@robert-UX301LAB ~ $
Offline Osmond
« Reply #151 on: December 18, 2016, 08:11:47 am »
Any more information on removing Windows 10?
Offline SeZo
« Reply #152 on: December 18, 2016, 11:20:18 am »
If you are 100% sure that you want to get rid of Windows (and you have all important data backed up) then I would suggest (as there is no easy way to remove Windows 10 and keep Peppermint) to start again with a fresh install of Peppermint. Only this time choose on the "Installation type" screen select the "Erase Disk and install Peppermint" option.
Offline Osmond
« Reply #153 on: January 03, 2017, 08:53:25 am »
Sorry for the delay in replying SeZo- domestic commitments. Thanks for your advice about Windows 10 removal. I think I'll stand fast for the time being.
I'm having trouble with Panel: stuck with panel 4 and cannot change it. How do I get back to the default settings?
« Reply #154 on: January 03, 2017, 11:54:25 am »
If you're using Peppermint 7 (WARNING - the script included in these instructions is ONLY for Peppermint 7, using it in ANY other distro or version may break your panel)...
To reset the panel back to defaults in Peppermint 7 - Open a terminal by hitting Ctrl+Alt+T
Now run these commands in sequence:
cd ~
wget --no-check-certificate https://dl.dropboxusercontent.com/u/31525164/reset-pm7-panel.tar.gz
tar xvf reset-pm7-panel.tar.gz
./reset-pm7-panel.sh
You will be presented with the logout dialog .. CHOOSE LOGOUT  <-- It s VERY IMPORTANT that you choose "Logout"
Then log back on.
Panel and whiskermenu should now be back to defaults.
« Last Edit: January 03, 2017, 12:01:09 pm by Mark Greaves (PCNetSpec) »
Offline Osmond
« Reply #155 on: January 05, 2017, 03:03:19 pm »
Thanks Mark. Not quite where I was before but I won't be meddling with Panel Settings again.
« Reply #156 on: January 05, 2017, 08:20:05 pm »
You you should be back to where you were before .. but probably a long time before (default, how the panel came out of the box) ;)
