Author Topic: Ubuntu 10.04  (Read 1145 times)
Offline Proudhon
Ubuntu 10.04
« on: October 05, 2016, 07:31:57 am »
Mark Greaves installed Ubuntu  LTS for me a few years ago - Hi Mark hope you are well.
I`ve not used it for a while but have now that I do have found it`s out of date and very limited in it`s scope
Can I upgrade and if so how?
Thanks
Offline arochester
Re: Ubuntu 10.04
« Reply #1 on: October 05, 2016, 11:43:45 am »
If you have 10.04 you may need to do a new install.
...But you could try upgrading to the next LTS (12.04)  -it might work. https://www.liberiangeek.net/2012/03/upgrade-from-ubuntu-10-04-to-ubuntu-12-04/
Offline Proudhon
Re: Ubuntu 10.04
« Reply #2 on: October 05, 2016, 03:58:45 pm »
Thanks but liberian doesn`t work. So how do igo about getting an upgrade?
Re: Ubuntu 10.04
« Reply #3 on: October 05, 2016, 04:16:25 pm »
Open a terminal (Ctrl+Alt+T) and run:
sudo do-release-upgrade
does it offer an upgrade ?
« Last Edit: October 05, 2016, 04:19:52 pm by Mark Greaves (PCNetSpec) »
Offline Proudhon
Re: Ubuntu 10.04
« Reply #4 on: October 05, 2016, 09:23:30 pm »
No!
Re: Ubuntu 10.04
« Reply #5 on: October 05, 2016, 11:39:12 pm »
I doubt if you have any other option than a reinstall then .. you left it too long and 10.04 is totally unsupported now.
Offline Proudhon
Re: Ubuntu 10.04
« Reply #6 on: October 06, 2016, 11:58:51 am »
OK - so what do you suggest I install - and how do I go about it?
Re: Ubuntu 10.04
« Reply #7 on: October 06, 2016, 06:06:27 pm »
Can you remember how you installed Ubuntu ?
Is Ubuntu the ONLY OS on this machine ?
Do you know if this PC can boot from a USB stick ? .. or only a CD/DVD ?
How about Peppermint 7 or Ubuntu 16.04 or Linux Mint 18 ?
(disclosure - I'm on the Peppermint team, so read into that what you will)
« Last Edit: October 06, 2016, 06:08:10 pm by Mark Greaves (PCNetSpec) »
