Author Topic: How do I get Chromium to work with Chrome's Flash Player in Ubuntu? [SOLVED]  (Read 2060 times)
Offline perknh
  • Soy un loco huevo que adora La Menta.
Hello Linux in the UK:
I discovered a clever little trick in Peppermint's forum that allows one to run Adobe Flash in Chromium Browser by using the builtin Flash of Google Chrome if Chrome is already installed in the distribution.  With a little help, I'd like to be able to do this for my Chromium browser in Ubuntu 16.04 also.  I have already installed Google Chrome.
Here's the link from Peppermint forum where PCNetSpec showed us how to do this in Peppermint 7.
 https://forum.peppermintos.com/index.php/topic,4475.msg46329.html#msg46329
I'm not certain what I need to change here in order to do the same in Ubuntu.
Any suggestions would be appreciated.  ;)
Thank you,
perknh
Here's the inxi -Fz for my computer if this is of any help at all:
(click to show/hide)
« Last Edit: November 29, 2016, 02:00:20 pm by perknh »
Re: How do I get Chromium to work with Chrome's Flash Player in Ubuntu?
« Reply #1 on: November 18, 2016, 01:24:15 am »
You shouldn't need to change anything perknh .. the instructions are exactly the same for Ubuntu/Mint/Peppermint/etc.
« Last Edit: November 18, 2016, 01:26:51 am by Mark Greaves (PCNetSpec) »
Offline perknh
« Reply #2 on: November 18, 2016, 11:23:44 am »
Hello PCNetSpec,
I'll try it.  I was anticipating that the gedit part of the process would throw me for a loop.  But I'll give it a whirl, and I'll report back with the results.
I had to change pluma to nano, use CTRL 0 and CTRL X, press ENTER, Log Out and In, and now I'm running the up-to-date version of Google Chrome's Flash within Chromium.
Thank you, PCNetSpec. Yes, it worked!  ;)
« Last Edit: November 18, 2016, 12:12:19 pm by perknh »
Sorry I forgot Ubuntu doesn't have pluma .. swapping all instances of "pluma" to "gedit" would have worked too. ;)
Offline perknh
« Reply #4 on: November 18, 2016, 05:04:20 pm »
Hey, no problem.  I learned the difference between pluma and nemo by installing Yandex through the terminal over in Peppermint.  Also, I don't remember having to log out and in with Peppermint, but Flash didn't show up here for me until I logged out, and then in, to Ubuntu.   Also, it's good to know that one can swap out pluma, or nemo, for gedit too.  That little trick will come in handy someday.  ;)
Thank you, PCNetSpec.  It's all good.  :)
« Last Edit: November 29, 2016, 04:34:12 am by perknh »
Offline perknh
« Reply #5 on: November 29, 2016, 04:19:39 am »
Hi PCNetSpec,
I ended up installing Unity again, and this time, when I ran the commands you showed me from Peppermint forum, I had a big surprise.  I can longer find libpepflashplayer.so.  Yes, there's a Pepperflash folder in Google Chrome, but when I open it, it's empty!  There no libpepflashplayer.so to be found.
Can we come up with another workaround, or is what I posted over at Peppermint from Google's Blog coming true now?  It's almost December; maybe support for Flash really is being "de-dmphasized" in Chrome. :o
Whatever the reason, I can't get Flash from Chrome to work for me any longer in Chromium.  Of course, I can download Adobe Flash from Adobe itself, but that's no fun having to agree to Adobe's licence agreement,
Thank you,
perknh
« Last Edit: November 29, 2016, 04:34:36 am by perknh »
« Reply #6 on: November 29, 2016, 01:25:42 pm »
You have to use chrome for a while before it downloads pepperflash (it's not always immediate).
Try using Chrome for a while, and accessing some pages that have flash content .. eventually libpepflashplayer.so should appear
Offline perknh
« Reply #7 on: November 29, 2016, 01:59:39 pm »
Oh!  I never knew that.  No, you're right, I haven't been using it.
I'll, again, marked the topic as solved.  ;)
« Last Edit: November 30, 2016, 07:34:35 pm by perknh »
