Author Topic: [SOLVED] 2 Updates which will not update  (Read 2188 times)
Offline pooky2483
Re: 2 Updates which will not update
« Reply #15 on: December 10, 2016, 12:54:59 pm »
Thanks for fixing the problem Mark, what exactly was wrong, do you know?
Kubuntu 14.04LTS 64bit|KDE 4.14.13|QT 4.8.6|Linux 4.2.0-42-generic|M5A78L-M USB3|BIOS 2101|AMD PhenomII X4 965 3400+|P8H77-I Motherboard NIC|32.0GB PC3-10600 1333Mhz CL9 ( 9-9-9-24 ) DDR3
Re: [SOLVED] 2 Updates which will not update
« Reply #16 on: December 10, 2016, 01:01:05 pm »
Looks like there were some packages (or information about them) in your local package cache that were refusing to install for whatever reason .. clearing the package cache allowed them be re-downloaded and installed.
Offline pooky2483
« Reply #17 on: December 22, 2016, 03:53:48 pm »
Sorry Mark, it seems I was wrong, they are still failing to update!
« Reply #18 on: December 23, 2016, 10:32:43 am »
According to this
http://packages.ubuntu.com/search?suite=trusty&keywords=mencoder
and this
http://packages.ubuntu.com/search?suite=trusty&keywords=mplayer
the current versions for 14.04 (trusty) are
mencoder     2:1.1+dfsg1-0ubuntu3
mplayer     2:1.1+dfsg1-0ubuntu3
And yet you have a later version of mplayer (2:1.2+svn37881~trusty) .. my guess is you're getting this from a PPA that's now broken.
What's the output from:
for APT in `find /etc/apt/ -name \*.list`; do grep -o "^deb http://ppa.launchpad.net/[a-z0-9\-]\+/[a-z0-9\-]\+" $APT | while read ENTRY ; do USER=`echo $ENTRY | cut -d/ -f4` PPA=`echo $ENTRY | cut -d/ -f5` ; echo ppa:$USER/$PPA ; done ; done
Offline pooky2483
« Reply #19 on: December 29, 2016, 08:00:17 pm »
The result is;
ppa:jonathonf/vlc
ppa:kubuntu-ppa/backports
ppa:team-xbmc/ppa
Offline pooky2483
« Reply #20 on: December 29, 2016, 08:06:43 pm »
Mark, I think I've found the cause of the problem. THIS page is where I found I could install the newest version of VLC, but all it's caused is problems.
« Reply #21 on: December 29, 2016, 11:07:11 pm »
Yep, PPA's can be both a godsend and a nightmare .. nature of the beast I'm afraid.
You could purge that PPA, but it'll mean loosing that version of VLC (?)
Offline pooky2483
« Reply #22 on: December 30, 2016, 01:05:02 am »
That's a sacrifice I'm willing to take, if it means using a version which 14.04 classes as current stable then so be it.
How do I go about it, do I just remove the PPA and the system will revert to the current stable for 14.04?
« Reply #23 on: December 30, 2016, 11:03:55 am »
Make sure ppa-purge is installed:
then purge the ppa:jonathonf/vlc PPA:
sudo ppa-purge ppa:jonathonf/vlc
that should disable that PPA and revert anything installed from it back to the default versions
Offline pooky2483
« Reply #24 on: December 30, 2016, 01:06:44 pm »
Now THAT fixed it.
Thanks again Mark :-)
« Reply #25 on: December 30, 2016, 09:30:44 pm »
No worries mate :)
