Author Topic: Brother MFC-J5910DW wireless printer problems  (Read 563 times)
Offline donwatson
  • Getting older
« on: December 13, 2016, 08:05:15 pm »
I am back with this problem with this printer.
I can not get the wireless connection to work. I had a topic here in September but I was able to use the Windoze computer to print out my sketches. I have now lost the Windoze computer and would like to establish a wireless connection with my Novatech computer running Pep 7.
Can you help ? where do I start ?
take care
Don W
Novatech build
Peppermint 7    64 bit     500 GB HD        496 GB Ext 4
Offline Emegra
  • Devilishly Handsome
Re: Brother MFC-J5910DW wireless printer problems
« Reply #1 on: December 15, 2016, 06:17:45 pm »
Have a look here
]http://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=mfcj5910dw_all&faqid=faq00002037_013]
Once you get it connected to your wlan it should just be a question of installing the printer in the normal manner
Good luck
« Last Edit: December 16, 2016, 07:35:57 pm by Emegra »
If you can keep your head while all around are losing theirs, then you're not quite grasping the situation
Offline donwatson
  • Getting older
« Reply #2 on: December 15, 2016, 08:32:07 pm »
Thanks Graeme,
I will go through this in the morning after my visit to the doc.
take care
Don W
PS I have this printer connected wirelessly with the Windows computer and it works ok. These instructions look much the same as when I connected the Windows computer. Hope fully it should all go well.
« Last Edit: December 15, 2016, 08:40:59 pm by donwatson »
Novatech build
Offline Emegra
« Reply #3 on: December 15, 2016, 08:49:52 pm »
If you have this printer connected with your Windows PC you shouldn't need to do it again it should already be registered to your network
all you should need to do now is install the printer
Menu>System Tools>Printers
When the printer dialogue box opens click + Add on next screen click Network Printers and your printer should be listed select your printer then just follow the instructions
Good luck
« Last Edit: December 15, 2016, 08:53:08 pm by Emegra »
Offline donwatson
  • Getting older
« Reply #4 on: December 15, 2016, 09:49:34 pm »
Thanks Graeme,
Carried out your latest suggestion and the printer has printed a test page.
Went upstairs and printed out a page from Writer and it worked well. Looks as if it is a success.
Thanks again
take care
Don W
« Last Edit: December 15, 2016, 09:53:10 pm by donwatson »
Novatech build
Offline Emegra
« Reply #5 on: December 15, 2016, 10:03:48 pm »
You're welcome don
Glad you got it working :)
« Reply #6 on: December 21, 2016, 12:56:25 am »
Nice one Graeme :)
