Author Topic: Offline install of b43-fwcutter and firmware for Broadcom Wireless cards  (Read 106979 times)
0 Members and 4 Guests are viewing this topic.
Re: Offline install of b43-fwcutter and firmware for Broadcom Wireless cards
« Reply #15 on: October 27, 2012, 12:22:20 am »
Yup it's an LPPHY (low power card) .. normally you'd just need to install firmware-b43-lpphy-installer but with you having done an offline install of the firmware, I can't guarantee what will happen.
But let's try it anyway:
sudo apt-get install firmware-b43-lpphy-installer
then reboot to test.
What model of HP laptop is this ?
« Last Edit: October 27, 2012, 01:48:11 am by Mark Greaves (PCNetSpec) »
Offline tiansial
« Reply #16 on: October 28, 2012, 02:19:13 pm »
I just installed the b43-lpphy firmware, gonna report soon.
The notebook is an old HP 6720s.
« Reply #17 on: October 28, 2012, 02:37:58 pm »
Please let us know how it goes :)
If you ever decide you want to get the wired connection working .. according to this (old) bug report:
https://bugs.launchpad.net/ubuntu/+source/linux-source-2.6.22/+bug/151887
Updating the BIOS seems to fix the issue on your HP 6270s
As does the kernel boot parameter pci=noacpi
But this parameter may also have undesired consequences .. so the BIOS update is a better solution.
but temporarily using that kernel boot parameter may be handy for us to get your wireless fixed if the LPPHY firmware doesn't fix the issue.
Offline tiansial
Offline tiansial
« Reply #19 on: October 28, 2012, 03:04:59 pm »
I guess it needs to be specifically F04 version, but it seems a bad idea to downgrade bios :\
« Reply #20 on: October 28, 2012, 03:06:28 pm »
Ahh well .. not a problem if wireless keeps working ;) .. how's it going ?
Offline tiansial
« Reply #21 on: October 28, 2012, 03:09:19 pm »
So far so good!
Offline AveragGuy
« Reply #22 on: February 05, 2013, 09:44:13 am »
So that exercise results in a kernel panic when I attempt to activate the driver from Additional Drivers screen.  I also saw in the article that this would work for the 4318, but the description in the AD screen doesn't mention that part.
Offline mary
  • Gender: Female
  • The secret of happiness is freedom.
« Reply #23 on: February 05, 2013, 10:47:50 pm »
Hello to all!! I'm new here in the forum and I have the problem that when the center appears, the install button is disabled so I can't click it!! :( What can I do?? Please help me!!
« Reply #24 on: February 06, 2013, 12:33:37 am »
Can people please let us know which version and architecture of Ubuntu you are using .. eg. 12.04 32bit .. so I can re-test these instructions.
These instructions are quite old now, and I haven't tested them with recent versions.
« Last Edit: February 06, 2013, 12:36:52 am by Mark Greaves (PCNetSpec) »
Offline mary
  • Gender: Female
« Reply #25 on: February 06, 2013, 05:21:32 pm »
12.4 32bit!!! You found it!! :) haha
« Reply #26 on: February 06, 2013, 06:32:21 pm »
mary .. I take it you mean when you click on the b43-fwcutter.deb and patch.deb files, software centre opens but the install button is greyed out ?
If so .. here's another way to install those 2 packages .. create a folder on your desktop called b43 .. copy both the b43-fwcutter.deb and patch.deb files into it.
Now open a terminal (Ctrl+Alt+T), and run these commands in sequence:
cd ~/Desktop/b43
sudo dpkg -i *.deb
That will install those 2 packages .. then carry on with the original tutorial.
Offline mary
  • Gender: Female
« Reply #27 on: February 06, 2013, 06:43:18 pm »
I have only found the deb file and I didn't continue to the others because of the grayed install button of the center. Let me see if these things you just said work. And thank you soooo much for the direct answer!!!
Offline mary
  • Gender: Female
« Reply #28 on: February 06, 2013, 06:46:59 pm »
I mean the first deb file only, sorry. Let me see.
« Reply #29 on: February 06, 2013, 07:04:00 pm »
OK, new instructions for an offline install of b43-fwcutter and firmware for Broadcom Wireless cards in Ubuntu 12.04
(patch.deb is no longer necessary .. and there's new firmware linked below)
With the 12.04 LiveCD inserted ..
Create a new directory on your desktop called b43offline
Now navigate onto your Ubuntu 12.04 LiveCD, and go to pool > main > b > b43-fwcutter directory
Copy the b43-fwcutter_xxx-x_xxxx.deb file to the b43offline directory you just created on your desktop.
If you don't have a LiveCD .. you can download the b43-fwcutter_xxx-x_xxxx.deb file for your architecture from one of the mirrors at this link:
http://packages.ubuntu.com/precise/utils/b43-fwcutter
and place it in the b43offline directory you created on your desktop)
Once you have the b43-fwcutter_xxx-x_xxxx.deb file in the b43offline directory on your desktop .. open a terminal (Ctrl+Alt+T) and run:
cd ~/Desktop/b43offline
sudo dpkg -i b43-fwcutter*
On another PC with internet access .. download these 2 (firmware) files:-
http://mirror2.openwrt.org/sources/broadcom-wl-5.10.56.27.3_mipsel.tar.bz2
http://downloads.openwrt.org/sources/wl_apsta-3.130.20.0.o
and copy them both to the b43offline directory you created on the Ubuntu desktop.
Open a terminal, and run these commands in sequence:
tar -xjvf broadcom-wl-5.10.56.27.3_mipsel.tar.bz2
sudo b43-fwcutter -w /lib/firmware broadcom-wl-5.10.56.27.3/driver/wl_apsta/wl_prebuilt.o
sudo b43-fwcutter -w /lib/firmware wl_apsta-3.130.20.0.o
sudo chmod 755 /lib/firmware/b43
sudo chmod 755 /lib/firmware/b43legacy
sudo modprobe -r b43
(don't worry if that command fails .. just carry on below
sudo modprobe b43
Wireless adapters that use the b43 drivers should now spring to life
If that doesn't work .. try changing to the b43legacy driver with:
sudo modprobe b43legacy
Once it's working .. feel free to save/move/delete the b43offline directory from your desktop
(unmodified) Source:-
https://help.ubuntu.com/community/WifiDocs/Driver/bcm43xx
« Last Edit: March 25, 2013, 11:25:26 pm by Mark Greaves (PCNetSpec) »
