Author Topic: Offline install of b43-fwcutter and firmware for Broadcom Wireless cards  (Read 109378 times)
Offline Cross
Re: Offline install of b43-fwcutter and firmware for Broadcom Wireless cards
« Reply #90 on: November 13, 2014, 10:41:41 pm »
cross@ubuntu:~$ sudo lshw -C network
[sudo] password for cross:
  *-network
       product: RTL-8029(AS)
       physical id: 5
       bus info: pci@0000:00:05.0
       logical name: eth0
       version: 00
       serial: 00:1c:42:d6:4a:9c
       capacity: 1Gbit/s
       width: 32 bits
       capabilities: bus_master ethernet physical logical fibre 1000bt-fd
       configuration: autonegotiation=off broadcast=yes driver=prl_eth driverversion=1.1 duplex=full ip=10.211.55.9 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:23 ioport:8200(size=32) memory:ee000000-ee0fffff
cross@ubuntu:~$ lspci -vnn | grep -i net
00:05.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL-8029(AS) [10ec:8029]
« Reply #91 on: November 13, 2014, 11:09:12 pm »
The OS isn't finding the wireless adapter at all.
Just because it's an internal adapter does NOT mean it's not a USB adapter .. so have you added a USB controller to the VM, and if so is the wireless adapter listed if you click thee UWSB icon on the parallels status bar ?
Offline dfiggley
YES, YES, YES!!! You're a genius!
In this brave new world, I understood nothing of what you said but followed it to the letter and..... PRESTO!!
Many thanks.
You're most welcome, glad it helped .. and welcome to the forum :)
« Last Edit: March 11, 2016, 12:36:44 am by Mark Greaves (PCNetSpec) »
For an "Offline" install of b43-fwcutter and firmware in Ubuntu 14.04 (or any distro based on it).
(ie. without an working internet connection on the Ubuntu PC)
Supported models include:
BCM4301, BCM4306 (revision 2), BCM4306 (revision 3), 4309, BCM4311, BCM4312, BCM4318, BCM4320, BCM4322, BCM4331, BCM43224, and BCM43225
Create a new directory on your desktop called b43offline
Now navigate onto your Ubuntu 14.04 LiveCD, and go to pool > main > b > b43-fwcutter directory
Copy the b43-fwcutter_xxx-x_xxxx.deb file to the b43offline directory you just created on your desktop.
If you don't have a LiveCD .. you can download the b43-fwcutter_xxx-x_xxxx.deb file for your architecture from one of these links:-
For 32bit Ubuntu 14.04
http://cz.archive.ubuntu.com/ubuntu/pool/main/b/b43-fwcutter/b43-fwcutter_018-2_i386.deb
For 64bit Ubuntu 14.04
http://cz.archive.ubuntu.com/ubuntu/pool/main/b/b43-fwcutter/b43-fwcutter_018-2_amd64.deb
Once you have the b43-fwcutter_xxx-x_xxxx.deb file in the b43offline directory on your desktop .. open a terminal (Ctrl+Alt+T) and run:
cd ~/Desktop/b43offline
then:
sudo dpkg -i b43-fwcutter*
Now on another PC with internet access .. download these 2 (firmware) files:-
http://downloads.openwrt.org/sources/wl_apsta-3.130.20.0.o
http://www.lwfinger.com/b43-firmware/broadcom-wl-5.100.138.tar.bz2
and copy them both to the b43offline directory you created on the Ubuntu desktop.
Once you have those 2 files in the b43offline directory on your desktop .. open a terminal (Ctrl+Alt+T) and run these commands in sequence:
then:
tar xjvf broadcom-wl-5.100.138.tar.bz2
then:
sudo b43-fwcutter -w /lib/firmware broadcom-wl-5.100.138/linux/wl_apsta.o
then:
sudo b43-fwcutter -w /lib/firmware wl_apsta-3.130.20.0.o
then:
sudo chmod 755 /lib/firmware/b43
then:
sudo chmod 755 /lib/firmware/b43legacy
then:
sudo modprobe -r b43
(don't worry if that command fails .. just carry on below)
then:
sudo modprobe b43
Wireless adapters that use the b43 drivers should now spring to life.
If that doesn't work .. try changing to the b43legacy driver with:
then:
sudo modprobe b43legacy
Once it's working .. feel free to save/move/delete the b43offline directory from your desktop
I'll try remember to update these instructions for 16.04 when it's released.
« Last Edit: March 11, 2016, 12:33:11 am by Mark Greaves (PCNetSpec) »
Offline d1d0
Hy, I've just recently installed Elementary OS Freya on my old Dell Inspiron 1525 Laptop wth Broadcam 4312 card and I do not have Internet at all!
I have already downloaded the files from an internet-connected computer and tried to install them but the command "b43-fwcutter" is still not found. What would be your recommendations?
What else should I try?
Which architecture, 32bit or 64bit ?
If unsure, please post the output from:
uname -a
and can you also post the output from
ls ~/Desktop/b43offline
« Last Edit: April 15, 2016, 09:05:14 pm by Mark Greaves (PCNetSpec) »
