Author Topic: Getting sound and video[fixed thank you]  (Read 1977 times)
Offline theporter2000
  • Full Member
« on: June 07, 2011, 08:25:13 pm »
I belive there is 3 different sources
  • Web or real player
  • CD's/DvD's
  • .[can't remember this one or] is it utube ?
Ive got dvd and some web vision but no sound
I have tryed before with 2 different head set's and there all coded I've just tryed a web tutorial no sound
« Last Edit: June 11, 2011, 12:28:16 am by theporter2000 »
I have Ubuntu 12.04. LTS,  Nautilus 3.4.2, Google Chrome 21.0.1180.57 and Firefox 13.0.1,
TTFN
theporter2000
Re: Getting sound and video
« Reply #1 on: June 07, 2011, 11:46:23 pm »
Are you saying sound doesn't work at all ?
Have you clicked the little speaker icon by the clock and selected "Unmute" ?
If that doesnt' work, send the output from:
sudo lshw -C multimedia
and remind me which distro/version you are running... I can't remember what everyone is using ?
  • Full Member
« Reply #2 on: June 08, 2011, 12:53:27 am »
gordon@gordon-desktop:~$ sudo lshw -C multimedia
[sudo] password for gordon:
  *-multimedia
       description: Audio device
       product: 82801H (ICH8 Family) HD Audio Controller
       vendor: Intel Corporation
       physical id: 1b
       bus info: pci@0000:00:1b.0
       version: 02
       width: 64 bits
       configuration: driver=HDA Intel latency=0
       resources: irq:47 memory:50420000-50423fff
I'm using ubuntu 10.10 think I' got all the video now but no sound
I be back late wednesday now ?
TTFN
theporter2000
« Reply #3 on: June 08, 2011, 01:08:52 am »
Jeez... will you EVER answer all my questions ?
WHAT LINUX DISTRO ARE YOU USING, AND WHAT VERSION ?
ARE YOU SAYING SOUND DOESN'T WORK AT ALL ?
ARE YOU SURE THE SOUND ISN'T JUST MUTED ?
  • Full Member
« Reply #4 on: June 08, 2011, 01:23:10 am »
is this sigfificant
(firefox-bin:2637): Pango-WARNING **: shaping failure, expect ugly output. shape-engine='BasicEngineFc', font='文泉驛正黑 Medium 14.6669921875', text='日本語'
 it only appears when I launch a help through firefox
absolutely no sound
I'd allready tryed the muted button all apps appear to have only one button it's on full - unmutting ?
Distro I thought I had ubuntu 10.10 is that not what you mean't ?
« Last Edit: June 08, 2011, 01:25:45 am by theporter2000 »
TTFN
theporter2000
« Reply #5 on: June 08, 2011, 03:43:19 am »
I don't mean unmuting in an application... I mean in the OS.
Do like I said... Click the little speaker icon by the clock and selected "Unmute" (if its muted).
That's exactly what I mean... but you can't expect me to remember what distro/version YOU have if it isn't mentioned somewhere in the current thread... also, how am I supposed to know whether you have changed disrto or upgraded, remember Ubuntu 11.04 has recently been released.
When you start a new thread... it's a good idea to mention your distro/version again.
OK back to the problem.
No the (firefox-bin:2637): Pango-WARNING has nothing to do with the sound issue, that's firefox bitching about some font(s)... we'll come back to that later if necessary.
Post the output from:
cat /proc/asound/card0/codec#* | grep Codec
  • Full Member
« Reply #6 on: June 08, 2011, 09:44:05 pm »
I made sure it is unmuted OS afraid its what I know, but still no sound on any app ?
If I remember right you helped me do something before and said that is all the codec's you will ever need ?
gordon@gordon-desktop:~$ cat /proc/asound/card0/codec#* | grep Codec
Codec: SigmaTel STAC9227
TTFN
theporter2000
« Reply #7 on: June 08, 2011, 11:54:29 pm »
Different type of codec... that is the hardware codec chip on the soundcard, not the software audio/video codecs.
Open a terminal, and enter:
sudo sh -c 'echo options snd-hda-intel model=ref probe_mask=1 >> /etc/modprobe.d/alsa-base.conf'
Reboot, and see if sound works.
If it doesn't,,, tell me a bit more about the soundcard.
Is this a laptop ? .. if so what make/model ?
how many jack plug sockets are there on the card ?
Also send the output from
aplay -l
« Last Edit: June 09, 2011, 12:01:05 am by Mark Greaves (PCNetSpec) »
  • Full Member
« Reply #8 on: June 09, 2011, 12:36:16 am »
No change, no it's not a lap top, it has three sockets for the jacks built-in to the motherboard
gordon@gordon-sdesktop:~$ sudo sh -c 'echo options snd-hda-intel model=ref probe_mask=1 >> /etc/modprobe.d/alsa-base.conf'
gordon@gordon-desktop:~$ aplay -l
aplay: device_list:235: no soundcards found...
« Last Edit: June 09, 2011, 12:42:19 am by theporter2000 »
TTFN
theporter2000
« Reply #9 on: June 09, 2011, 01:33:10 am »
OK, run:
sudo gedit /etc/modprobe.d/alsa-base.conf
find the last line that reads:
and change it to:
options snd-hda-intel model=3stack
SAVE the file and exit gedit.
REBOOT... and see if your soundcard works.
If not, send the output from
asound -l
« Last Edit: June 09, 2011, 01:39:27 am by Mark Greaves (PCNetSpec) »
  • Full Member
« Reply #10 on: June 09, 2011, 06:59:52 pm »
is this a typo ?
gordon@gordon-desktop:~$ asound -l
No command 'asound' found, did you mean:
 Command 'csound' from package 'csound' (universe)
asound: command not found
gordon@gordon-desktop:~$ csound -l
The program 'csound' is currently not installed.  You can install it by typing:
sudo apt-get install csound
TTFN
theporter2000
« Reply #11 on: June 09, 2011, 07:05:25 pm »
yes... my mistake:
aplay -l
sudo lshw -C Multimedia
  • Full Member
« Reply #12 on: June 09, 2011, 07:15:56 pm »
the output is ?
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: STAC92xx Analog [STAC92xx Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
gordon@gordon-desktop:~$ sudo lshw -C Multimedia
  *-multimedia
       physical id: 1b
       version: 02
       width: 64 bits
TTFN
theporter2000
« Reply #13 on: June 10, 2011, 12:48:03 pm »
OK, run:
and change it to:
aplay -l
lsmod | grep snd
You might also want to play with the settings in alsamixer, and see if anything is muted.
aslamixer
« Last Edit: June 10, 2011, 04:57:40 pm by Mark Greaves (PCNetSpec) »
  • Full Member
« Reply #14 on: June 10, 2011, 06:18:36 pm »
is  it normal to have the device listed twice ?
  Subdevices: 1/1
card 0: Intel [HDA Intel], device 1: STAC92xx Digital [STAC92xx Digital]
  Subdevices: 1/1
gordon@gordon-desktop:~$ lsmod | grep snd
snd_hda_codec_ idt      54919  1
snd_hda_intel          22235  0
snd_hda_codec          87552  2 snd_hda_codec_ idt,snd_hda_intel
snd_hwdep               5040  1 snd_hda_codec
snd_pcm                71475  2 snd_hda_intel,snd_hda_codec
snd_seq_midi            4588  0
snd_rawmidi            17783  1 snd_seq_midi
snd_seq_midi_e vent      6047  1 snd_seq_midi
snd_seq                47174  2 snd_seq_midi,snd_seq_midi_event
snd_timer              19067  2 snd_pcm,snd_seq
snd_seq_device          5744  3 snd_seq_midi,snd_rawmidi,snd_seq
snd                    49038  9 snd_hda_codec_ idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
soundcore                880  1 snd
snd_page_alloc          7120  2 snd_hda_intel,snd_pcm
TTFN
theporter2000
