Author Topic: Ralink RT2870 based USB Wireless N adapters (Ubuntu)  (Read 195476 times)
Re: Ralink RT2870 based USB Wireless N adapters (Ubuntu)
« Reply #30 on: May 17, 2011, 07:53:28 am »
:) Glad to be of service, and you're welcome.
Have fun with your shiny new Linux install, and gimme a shout if you need help in the future.
Offline Noobuntu
« Reply #31 on: May 17, 2011, 07:55:41 am »
Oh yes, I discovered many, many useful apps for circuit board design, and some neat first-person shooter games, and that was just what I could find in-between posts.  And I will indeed come back here if I need help in the future.
Offline Y0a0bon
« Reply #32 on: May 31, 2011, 04:50:20 pm »
Hey! First of all, thank you for your works, Mark! You do a great job!
You described in this post exactly the problem i have so thank you :)
Your pre-modified version works fine, no errors anymore whan compilating but my Wireless adaptaters isn't detected..? With the 10.04, it worked with the rt2870sta v2.2 but in 10.10 it does'nt work!:( I have a Belkin HWNU 300.
May you help me? Thank you!
« Reply #33 on: May 31, 2011, 05:05:28 pm »
[EDIT] For future readers - This posting is WRONG, see here:
http://linuxforums.org.uk/hardware-compatibility/ralink-rt2870-based-usb-wireless-n-adapters-(ubuntu)/msg52771/#msg52771
The RTL8192SU drivers *only* apply to the HWNUm-300... The HWNU-300 *does* use the RT2870STA driver.
There is a pre-modified version (with the HWNU-300 ID string added) linked to further down the page. (in post #39)
[END EDIT]
You are using the wrong drivers... the Belkin HWNU 300 and HWNUm-300 appear to use the RTL8192SU chipset.
The RTL8192SU drivers can be downloaded here:
http://www.realtek.com.tw/Downloads/downloadsView.aspx?Langid=1&PNid=21&PFid=48&Level=5&Conn=4&DownTypeID=3&GetDown=false&Downloads=true
Make sure you get the right ones... about half way down the page.
« Last Edit: May 31, 2011, 06:44:49 pm by Mark Greaves (PCNetSpec) »
Offline Y0a0bon
« Reply #34 on: May 31, 2011, 05:07:01 pm »
Oh O.o Thank you, wondering why it worked with the RT2870TSTA driver.. I will use this, thank you
EDIT: I've read about that in some forums and it appeared that only the HWNUm-300 worked with the RTL8192SU driver but you're probably right... But now my wireless adaptater works with your pre-modified driver! I just wrote in ./common/rt_dev_id.c  "{USB_DEVICE(0x06f8:0xe030)}, /*HWNU-300/*" to make my wireless adpatater recognized.
Thank you for your driver, if i have a problem i will try the RTL8182SU driver :)
Thank you!
« Last Edit: May 31, 2011, 05:23:58 pm by Y0a0bon »
« Reply #35 on: May 31, 2011, 05:10:18 pm »
Don't thank me YET... I'm only going by what I've spotted online :)
Is this a USB device ?
Can you send the output from:
sudo lshw -C network
lsusb
If it's NOT a USB device, can you also send the output from:
lspci -nn
« Last Edit: May 31, 2011, 05:23:32 pm by Mark Greaves (PCNetSpec) »
Offline Y0a0bon
« Reply #36 on: May 31, 2011, 05:26:59 pm »
Yes it's a USB adaptater :)
sebastien@sebastien-pc1:~$ sudo lshw -C network
[sudo] password for sebastien:
  *-network
       product: RTL-8139/8139C/8139C+
       physical id: f
       bus info: pci@0000:02:0f.0
       logical name: eth0
       version: 10
       serial: 00:0e:a6:39:81:f4
       capacity: 100MB/s
       width: 32 bits
       capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=64 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10MB/s
       resources: irq:19 ioport:b400(size=256) memory:feaef400-feaef4ff
  *-network
       physical id: 1
       logical name: ra0
       serial: 00:08:d3:44:aa:4f
       configuration: broadcast=yes driver=RALINK WLAN driverversion=2.4.0.0 ip=192.168.1.5 multicast=yes wireless=Ralink STA
sebastien@sebastien-pc1:~$ lsusb
Bus 005 Device 003: ID 058f:9360 Alcor Micro Corp. 8-in-1 Media Card Reader
Bus 005 Device 002: ID 03f0:040c Hewlett-Packard
Bus 003 Device 002: ID 058f:9254 Alcor Micro Corp. Hub
Bus 002 Device 003: ID 04f2:0111 Chicony Electronics Co., Ltd KU-9908 Keyboard
Bus 002 Device 002: ID 046d:c040 Logitech, Inc. Corded Tilt-Wheel Mouse
Bus 001 Device 008: ID 054c:0243 Sony Corp. MicroVault Flash Drive
Bus 001 Device 005: ID 06f8:e030 Guillemot Corp.
I thanked you because it works ;)
« Reply #37 on: May 31, 2011, 05:33:45 pm »
OK, it looks like RT2870STA ARE the correct drivers... give me a bit to add the vendor:device ID strings to the driver, and I'll send you a link.
FORGET the RTL8192SU drivers... they are the WRONG ones.
« Last Edit: May 31, 2011, 06:28:17 pm by Mark Greaves (PCNetSpec) »
Offline Y0a0bon
« Reply #38 on: May 31, 2011, 05:41:19 pm »
No look at the post #34
Thank you!
I already do that and it works, thank you for your help tought!;)
« Reply #39 on: May 31, 2011, 05:51:16 pm »
So it's working now ?
Well I've uploaded a driver with a modified rtusb_dev_id.c for your HWNU-300 here:
http://dl.dropbox.com/u/11876059/Y0a0bon_RT2870_Linux_STA_v2.4.0.1.tar.bz2
just in case.
« Last Edit: May 31, 2011, 06:17:48 pm by Mark Greaves (PCNetSpec) »
Offline Y0a0bon
« Reply #40 on: May 31, 2011, 06:01:48 pm »
Thank you :) Yes it's working, i did the same thing as you.
Can I quote you in the contributors of the wiki: http://doc.ubuntu-fr.org/| (the french community ubuntu documentation)?
« Reply #41 on: May 31, 2011, 06:03:00 pm »
Feel free :)
« Last Edit: May 31, 2011, 06:15:19 pm by Mark Greaves (PCNetSpec) »
Offline Y0a0bon
« Reply #42 on: June 01, 2011, 05:15:49 pm »
Great!:) And does your method work on 11.04?
« Reply #43 on: June 01, 2011, 05:39:18 pm »
The driver will compile/install in 11.04 (after modification), but I'm not sure if the blacklisting of rt2800usb is still necessary.
« Last Edit: June 01, 2011, 05:56:51 pm by Mark Greaves (PCNetSpec) »
Offline Y0a0bon
« Reply #44 on: June 01, 2011, 06:10:03 pm »
Ok, i will try with and without blacklisting rt2870usb, thank you :)
