Author Topic: Peerblock on Windows, whats Ubuntu's equivalent?  (Read 45274 times)
Offline pooky2483
« on: October 28, 2011, 11:41:19 pm »
I have got just Vuze and would like to know the equivalent blocking software that I used on Windows when I used Vuze then.
Pete
Kubuntu 14.04LTS 64bit|KDE 4.14.13|QT 4.8.6|Linux 4.2.0-42-generic|M5A78L-M USB3|BIOS 2101|AMD PhenomII X4 965 3400+|P8H77-I Motherboard NIC|32.0GB PC3-10600 1333Mhz CL9 ( 9-9-9-24 ) DDR3
Re: Peerblock on Windows, whats Ubuntu's equivalent?
« Reply #1 on: October 28, 2011, 11:46:13 pm »
What do you mean by "blocking software" .. I don't use Vuze, I use Transmission .. does Vuze not have somewhere to add a blocklist, as Transmission does ?
« Last Edit: October 28, 2011, 11:48:02 pm by Mark Greaves (PCNetSpec) »
« Reply #2 on: October 29, 2011, 12:11:51 am »
Hmm .. apparently there is a PeerGuardian for Linux .. but it is not available in the default software repositories .. so you have 2 options
1) Download it as source code form here:
http://sourceforge.net/projects/peerguardian/
then compile and install it .. not the easiest route, as you will have to resolve any dependencies yourself.
2) Add this PPA to your sources:
https://launchpad.net/~jre-phoenix/+archive/ppa
then install the pgl package from within one of your package managers.
If you need assistance .. just ask :)
« Last Edit: October 29, 2011, 12:32:15 am by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #3 on: October 29, 2011, 10:20:51 am »
Think I'll give it a miss for now as I have no idea how to sort out number 1 and with number 2, does that make it permanent or can it be activated when needed.
Thanks anyways, Pete
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #4 on: October 29, 2011, 12:46:18 pm »
Step 2 isn't very hard, simply open terminal and enter:
sudo add-apt-repository ppa:jre-phoenix/ppa
after you go back to $ prompt, enter:
« Reply #5 on: October 29, 2011, 03:17:26 pm »
and:
sudo apt-get install pgl
Option 2 would allow you to easily install/uninstall it at will, from within your package manager(s)
Don't know about "activate" .. I've never used it.
« Last Edit: October 29, 2011, 03:23:31 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #6 on: October 29, 2011, 04:37:45 pm »
I mean when starting and stopping a program.
Peerguardian blocked ALL or allowed selected traffic onto your PC. but itt allowed Vuze to function properly, allowing it's traffic.
« Reply #7 on: October 29, 2011, 06:20:23 pm »
Sorry, can't comment on Peerblock ATM, as I said I don't use it .. try it out and see :)
Offline pooky2483
« Reply #8 on: November 01, 2011, 02:31:14 am »
and:
I've done the other commands from earlier posts and downloaded pgl-2.1.3.tar.gz. But now I'm stuck as it can't execute the command above!
I changed the directory to Downloads too and it comes up with 'E: Unable to locate package pgl'
I've tried renaming it from pgl-2.1.3.tar.gz to pgl.tar.gz to see if it's the name but it still didnt work, do I need to unpack the file manually into a folder named 'pgl'?
And, can I ask another question?
Why when you write things that go in the terminal window have they got 'Code: [Select]' then the code in some sort of coloured banner? What's that all about?
« Reply #9 on: November 01, 2011, 03:02:59 am »
My appologies .. that command should be:
sudo apt-get install pgl-gui
Get rid of the pgl-2.1.3.tar.gz file you downloaded, that will be the source code .. you don't want to be attempting to compile and install from source unless/until you know what you're doing ;)
BTW, a .tar.gz file is an archive in the same way as a .zip or .rar is .. you would normally right-click it and select Extract here then read any included text files such as README or INSTALL etc. before doing anything else .. but as I said, don't mess with source code compile/installs unless you know what you're doing as dependencies will NOT be resolved for you and you *could* make a mess of your system.
« Last Edit: November 01, 2011, 03:11:45 am by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #10 on: November 01, 2011, 05:47:05 pm »
Followed your instructions and installed it but get this error when running it...
It tells me to check it's log file, I've looked in the location but theres nothing there!
« Reply #11 on: November 01, 2011, 06:51:56 pm »
Heh .. "" doesn't exactly give you a lot to work with :)
Does the application work or not ? .. as I said I don't use it.
I use Transmission for torrents, and add this URL:
http://www.bluetack.co.uk/config/level1.gz
for it to acquire its blocklist updates
In Transmission Edit > Preferences > Privacy > Enable Blocklist (then the above URL) .. then click Update.
The errors appear to be generated because PeerGuardian isn't set to start (eg. set the iptables rules) when you start pgl-gui .. you probably told it not to during the setup.
It's actually nothing to worry about .. according to the logs it gets the updates, then attempts to restart, which fails because it isn't already running.
Just dismiss the error messages, and click the Start button.
On my system starting PeerGuardian killed ALL incoming and outgoing network traffic leaving me without the ability to network at all .. rebooting solved this (as it obviously stopped PeerGuardian from running), I have no doubt it's because I have no idea how to use the application.
« Last Edit: November 01, 2011, 08:32:29 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #12 on: November 02, 2011, 07:55:24 pm »
Ok, seems like Transmition has won, lol.
What's the correct way to remove Vuze and Peerblock.
« Reply #13 on: November 02, 2011, 08:02:47 pm »
run these commands:-
To uninstall the 2 packages run:
sudo apt-get remove vuze pgl-gui
then, to clear any dependencies run:
sudo apt-get autoremove
Or you could fire up Synaptic or the Ubuntu Software Centre, and uninstall them from there.
« Last Edit: November 02, 2011, 08:08:39 pm by Mark Greaves (PCNetSpec) »
Offline pooky2483
« Reply #14 on: November 03, 2011, 12:51:53 am »
Thanks, done it the first way.
I'm still learning and wanted to be sure.
