Author Topic: Finally got around to networking the house  (Read 27865 times)
Offline galaxytdm
  • Ubuntu 11.04
  • Sr. Member
  • Something Something dark side
« on: November 05, 2011, 09:01:41 pm »
Finally got around to networking the house.
Laptop (Linux)
Desktop (Linux)
Phone (Android)
TV (Samsung running Linux kernel)
Sky+
Xbox 360 (Windows based  )
All hooked up to the interweb and to each other.
Only thing is I'm worried they might start conspiring against me.
If you need help ask a professional, then act upon their advice.
Anything less and you're just wasting peoples time.
Re: Finally got around to networking the house
« Reply #1 on: November 05, 2011, 09:12:06 pm »
HAHAHA .. Linux won't conspire against you, can't talk for the Xbox though ;)
Have you got one (or all) of the Linux boxes acting as a streaming media server for Xbox 360 yet ?
Offline galaxytdm
  • Ubuntu 11.04
  • Sr. Member
« Reply #2 on: November 05, 2011, 09:17:28 pm »
Will have both but haven't tried either yet. Been to busy setting up Live account and streaming media from the phone to the tv.
Why do you ask? am I going to have fun setting up.
« Reply #3 on: November 05, 2011, 09:35:53 pm »
Not in the least .. it's VERY easy .. just wondered if you had done it and/or knew how :)
Install ushare on the Linux box, then follow this guide:
http://nexus172.wordpress.com/2009/04/26/how-to-stream-video-to-your-xbox360-using-ubuntu-ushare/
Any problems, gimme a shout :)
Just in case it helps .. here's my /etc/ushare.conf file (obviously you'd need to set different ports and USHARE_NAME on each Linux box)
# /etc/ushare.conf
# Edit this file with 'dpkg-reconfigure ushare'
# Configuration file for uShare
# uShare UPnP Friendly Name (default is 'uShare').
USHARE_NAME=Marks-PC
# Interface to listen to (default is eth0).
# Ex : USHARE_IFACE=eth1
USHARE_IFACE=eth0
# Port to listen to (default is random from IANA Dynamic Ports range)
# Ex : USHARE_PORT=49200
USHARE_PORT=49201
# Port to listen for Telnet connections
# Ex : USHARE_TELNET_PORT=1337
USHARE_TELNET_PORT=1338
# Directories to be shared (space or CSV list).ushare -x
# Ex: USHARE_DIR=/dir1,/dir2
USHARE_DIR=/home/mark/Music,/home/mark/Videos
# Use to override what happens when iconv fails to parse a file name.
# The default uShare behaviour is to not add the entry in the media list
# This option overrides that behaviour and adds the non-iconv'ed string intoushare -x
# the media list, with the assumption that the renderer will be able to
# handle it. Devices like Noxon 2 have no problem with strings being passed
# as is. (Umlauts for all!)
# Options are TRUE/YES/1 for override and anything else for default behaviour
USHARE_OVERRIDE_ICONV_ERR=yes
# Enable Web interface (yes/no)
USHARE_ENABLE_WEB=no
# Enable Telnet control interface (yes/no)
USHARE_ENABLE_TELNET=no
# Use XboX 360 compatibility mode (yes/no)
USHARE_ENABLE_XBOX=yes
# Use DLNA profile (yes/no)ushare -x
# This is needed for PlayStation3 to work (among other devices)
USHARE_ENABLE_DLNA=no
Once you've edited the /etc/ushare.conf file .. SAVE it, then run:
sudo /etc/init.d/ushare stop
ushare -x
to restart it with the new settings.
Then just fire up your Xbox and look in Videos or Music and whatever you put it the USHARE_NAME= feild will be listed :)
From now on, ushare should start at bootup.
« Last Edit: November 05, 2011, 09:44:30 pm by Mark Greaves (PCNetSpec) »
Offline galaxytdm
  • Ubuntu 11.04
  • Sr. Member
« Reply #4 on: November 06, 2011, 12:10:30 am »
Damn, you'd think I could do this by now wouldn't you, but no, I even managed to Bu**er this up.
I installed and ran set up, changed the name to Laptop, Ushare_iface to wlan0 and added a directory to share.
Run "sudo /etc/init.d/ushare stop" then ushare -x and got
/etc/ushare.conf: 6: Laptop: not found
and something about wlan0 not working, so in my wisdom I thought I would uninstall it and re install and start again but then I got this
celticbiker@celticbiker-laptop:~$ sudo apt-get install ushare
Reading package lists... Done
Building dependency tree
  linux-headers-2.6.35-22 linux-headers-2.6.35-22-generic
Use 'apt-get autoremove' to remove them.
  ushare
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
Need to get 0B/51.6kB of archives.
After this operation, 238kB of additional disk space will be used.
Preconfiguring packages ...
ushare failed to preconfigure with exit status 127.
Selecting previously deselected package ushare.
(Reading database ... 160522 files and directories currently installed.)
Unpacking ushare (from .../ushare_1.1a-0ubuntu5_i386.deb) ...
Processing triggers for man-db ...
Processing triggers for ureadahead ...
Setting up ushare (1.1a-0ubuntu5) ...
dpkg: error processing ushare (--configure):
 subprocess installed post-installation script returned error exit status 127
 ushare
E: Sub-process /usr/bin/dpkg returned an error code (1)
celticbiker@celticbiker-laptop:~$ sudo dpkg-reconfigure ushare
/usr/sbin/dpkg-reconfigure: ushare is broken or not fully installed.
and I can't seem to edit the config file directly.
« Last Edit: November 06, 2011, 12:21:41 am by galaxytdm »
« Reply #5 on: November 06, 2011, 12:18:59 am »
ok, run:
when that's done, run:
gedit /etc/ushare.conf
and post its contents here.
Offline galaxytdm
  • Ubuntu 11.04
  • Sr. Member
« Reply #6 on: November 06, 2011, 12:22:18 am »
See above post now edited
« Reply #7 on: November 06, 2011, 12:27:17 am »
try this:
sudo apt-get remove --purge ushare
then if that works
and let me know if there were any errors
Offline galaxytdm
  • Ubuntu 11.04
  • Sr. Member
« Reply #8 on: November 06, 2011, 12:39:06 am »
Seemed to install ok that time.
[codecelticbiker@celticbiker-laptop:~$ sudo apt-get remove --purge ushare
The following packages will be REMOVED
  ushare*
0 upgraded, 0 newly installed, 1 to remove and 2 not upgraded.
1 not fully installed or removed.
After this operation, 238kB disk space will be freed.
Do you want to continue [Y/n]? y
(Reading database ... 160536 files and directories currently installed.)
Removing ushare ...
 * Stopping uShare UPnP A/V & DLNA Media Server: ushare                  [ OK ]
Purging configuration files for ushare ...
  ushare
(Reading database ... 160521 files and directories currently installed.)
 * Starting uShare UPnP A/V & DLNA Media Server: ushare ]
I'll try again now.
While you're here though, how do I know which interface to use
USHARE_IFACE=eth0
and which ports to listen to
USHARE_PORT=49201
# Ex : USHARE_TELNET_ PORT=1337
USHARE_TELNET_ PORT=1338
« Reply #9 on: November 06, 2011, 12:45:50 am »
USHARE_IFACE=
should be the network interface that you use to connect to your router:
Seeing that you named ushare "Laptop", I'm guessing wireless ? .. in which case it *probably* should be:
USHARE_IFACE= wlan0
do you connect wirelessly or wired ?
and what is the output from:
ifconfig
The ports should be OK as long as they aren't being used by something else (which I doubt)
but obviously, youd want to raise/lower them by +1 (or whatever) for each Linux box you run ushare on .. if you get my meaning
[edit]
you could brobably leave the
field blank if you are setting the
USHARE_ENABLE_ TELNET=no
if you wish.
« Last Edit: November 06, 2011, 12:52:24 am by Mark Greaves (PCNetSpec) »
Offline galaxytdm
  • Ubuntu 11.04
  • Sr. Member
« Reply #10 on: November 06, 2011, 01:11:31 am »
celticbiker@celticbiker-laptop:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr 00:15:c5:43:37:d6
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:17
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:112 errors:0 dropped:0 overruns:0 frame:0
          TX packets:112 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:18340 (18.3 KB)  TX bytes:18340 (18.3 KB)
wlan0     Link encap:Ethernet  HWaddr 00:18:de:0d:4e:ba
          inet addr:192.168.0.6  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::218:deff:fe0d:4eba/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:27851 errors:0 dropped:0 overruns:0 frame:0
          TX packets:26097 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:26654896 (26.6 MB)  TX bytes:5966737 (5.9 MB)
« Reply #11 on: November 06, 2011, 01:14:42 am »
Yup that line should read:
USHARE_IFACE=wlan0
for clarity, that's a zero on the end ;)
Offline galaxytdm
  • Ubuntu 11.04
  • Sr. Member
« Reply #12 on: November 06, 2011, 01:22:02 am »
Changed it from eth0 to wlan0 and this happens
celticbiker@celticbiker-laptop:~$ sudo /etc/init.d/ushare stop
celticbiker@celticbiker-laptop:~$ ushare -x
Interface wlan0 is down.
Recheck uShare's configuration and try again !
uShare (version 1.1a), a lightweight UPnP A/V and DLNA Media Server.
Benjamin Zores (C) 2005-2007, for GeeXboX Team.
See http://ushare.geexbox.org/ for updates.
Initializing UPnP subsystem ...
Starting in XboX 360 compliant profile ...
UPnP MediaServer listening on 192.168.0.6:49153
Sending UPnP advertisement for device ...
Listening for control point connections ...
Building Metadata List ...
Looking for files in content directory : /home/celticbiker/Pictures
Found 142 files and subdirectories.
« Reply #13 on: November 06, 2011, 01:27:56 am »
run this:
and post the contents
I take it wireless is working ?
Offline galaxytdm
  • Ubuntu 11.04
  • Sr. Member
« Reply #14 on: November 06, 2011, 01:40:22 am »
# /etc/ushare.conf
USHARE_NAME=Celticbiker
USHARE_IFACE=wlan0
USHARE_PORT=49201
USHARE_TELNET_PORT=
USHARE_DIR=/home/celticbiker/Pictures
Yup, running this laptop and the desktop on wireless.
