Author Topic: Installing VLC 2.1.0 for Ubuntu Natty Narwhal or lower.  (Read 8704 times)
Offline BkS
  • BkS Media Founder
    • BkS Media
« on: March 31, 2012, 11:29:36 pm »
Many people running versions of Ubuntu Natty Narwhal or lower, or even people with distros based on Natty Narwhal (e.g. Peppermint 2) will find that they can't get the latest VLC 2.1.0 update from the site. Good news is, there's a PPA for those who happen to be on "old" versions of Ubuntu or distros based on them.
A simple tutorial, nothing fancy. Quick, easy & painless.
Terminal commands:
sudo apt-add-repository ppa:videolan/master-daily
sudo apt-get update && sudo apt-get install vlc
For a new features list see here:
http://www.addictivetips.com/windows-tips/whats-new-in-vlc-2-0-we-review-the-new-features-improvements/
Offline pooky2483
Re: Installing VLC 2.1.0 for Ubuntu Natty Narwhal or lower.
« Reply #1 on: July 10, 2012, 12:15:13 pm »
Can I update my version of VLC? I am running version 1.1.12 on 11.10 Oneiric Ocelot
The PPA I'm using is;
http://ppa.launchpad.net/n-muench/vlc/ubuntu oneiric main
http://ppa.launchpad.net/n-muench/vlc/ubuntu oneiric main (Source Code)
is this correct?
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #2 on: July 10, 2012, 06:02:03 pm »
Yeah the PPA will work for Oneiric. Although I'm positive 2.1.0 is in the repo's. Be sure to check first. :)
Offline pooky2483
« Reply #3 on: July 12, 2012, 12:11:22 pm »
Nope, checked the Ubuntu Software Centre and its still 1.1.12.2 and in my Synaptic Package Manager it's the same latest version as I've got installed.
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #4 on: July 12, 2012, 12:36:52 pm »
Did you use the PPA update? If you did, open VLC then goto Help > About VLC
That will tell you the version you have INSTALLED.
Offline pooky2483
« Reply #5 on: July 12, 2012, 04:37:18 pm »
Check first post with screenshot of said info.
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #6 on: July 13, 2012, 09:53:09 pm »
Here try this:
sudo add-apt-repository ppa:videolan/stable-daily
« Last Edit: July 13, 2012, 10:29:32 pm by BkS »
Offline pooky2483
« Reply #7 on: July 14, 2012, 12:45:40 pm »
It worked a treat, thanks Bks
