Author Topic: Mounting hard-drives from external sources. [Solved]  (Read 14664 times)
Offline BkS
  • BkS Media Founder
    • BkS Media
Re: Mounting hard-drives from external sources.
« Reply #60 on: January 26, 2013, 07:25:02 pm »
Bumpity bump.
I've got all my old stuff up and running, however I want to add a new drive.
So far what I have done is:
Identified drive as: /dev/sdd
Added to my fstab:
/dev/sdd /mnt/NAS-40GB   ext3    rw,errors=remount-ro     0       0
I've also created the directories:
/mnt/NAS-40GB
/mnt/NAS-40GB/share
That's as far as I've gotten. I am doing things correctly yes?
EDIT: I have also created a symlink that works perfectly.
« Last Edit: January 26, 2013, 07:46:43 pm by BkS »
« Reply #61 on: January 26, 2013, 07:48:34 pm »
What is /mnt/NAS-40GB/share  for ?
You can easily test it with
sudo mount -a
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #62 on: January 26, 2013, 07:56:04 pm »
The "share" directory is where the content will go. I have one in all my drives, as I dont want anything outside of a shared directory.
Everything seems to work fine according to mount -a.
Great success! ;D
« Reply #63 on: January 26, 2013, 07:59:48 pm »
Well shouldn't the "share" directory have been created AFTER the /mnt/NAS-40GB was mounted .. so it was created ON THE DRIVE ?
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #64 on: January 26, 2013, 08:06:36 pm »
It was created AFTER it was mounted. ;) I have learned a few things y'know.
« Reply #65 on: January 26, 2013, 08:51:06 pm »
OK .. don't get your snickers in a twit :P
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #66 on: January 26, 2013, 08:57:15 pm »
Haha, anyway on a more serious note, I've just connected the server to the network only to find it won't ping, HOWEVER, miniDLNA is working and I can access the movies, photos, etc? But the server itself won't show up on Nautilus or Window's explorer in order to browse the files.
Doesn't make sense...
« Reply #67 on: January 26, 2013, 09:13:55 pm »
What do you mean t won't ping .. you've tried pinging it's IP from another PC ?
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #68 on: January 26, 2013, 09:17:08 pm »
Yep, tried it from my laptop, my mums laptop, and my Nexus 7, and my phone... no replies. ???
I get:
Host Unreachable
« Last Edit: January 26, 2013, 09:21:38 pm by BkS »
« Reply #69 on: January 26, 2013, 09:21:30 pm »
Can you ping other PC's from the server ?
have you got any iptables rules set
sudo iptables -L
What's the output from
ifconfig
Have you tried another ethernet cable, and/or checked there's no dust blocking the connections in the ethernet socket.
« Last Edit: January 26, 2013, 09:27:07 pm by Mark Greaves (PCNetSpec) »
Offline SeZo
« Reply #70 on: January 26, 2013, 10:25:57 pm »
Is samba running? :-\
Have you modified the config for it?
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #71 on: January 26, 2013, 10:55:23 pm »
sudo iptables -L
Nothing is setup.
ifconfig
(click to show/hide)
Since I restarted the server, it seems to be responding to pings. Now the only problem is, Windows clients can't access the server, I think something may be wrong with samba, here's my smb.conf.
« Reply #72 on: January 27, 2013, 12:54:30 am »
Here's my peppermint smb.conf for comparison:-
So you might want to try:-
« Last Edit: January 27, 2013, 01:04:41 am by Mark Greaves (PCNetSpec) »
Offline BkS
  • BkS Media Founder
    • BkS Media
« Reply #73 on: January 27, 2013, 01:43:40 am »
Restarting samba seems to have solved the issue. Guess I forgot to refresh the configuration file?
The only problem I'm having is I can't write to the new shared folder which is in /mnt/NAS-40GB/share.
I've chmod 555 to /mnt/NAS-40GB and chmod 777 /mnt/NAS-40GB/share, but still no write access?
« Reply #74 on: January 27, 2013, 09:57:51 am »
Can you write to it locally:
touch /mnt/NAS-40GB/share/testfile
sudo touch /mnt/NAS-40GB/share/sudo-testfile
ls -a /mnt/NAS-40GB/share
