Measuring only 65.46mm by 102.04mm, the MarS Board is a low-cost highly-integrated controller board based on Freescale’s i.MX 6Dual ARM Cortex-A9 application processor which encompasses a dual-core platform running up to 1 GHz with 1 MB of L2 cache and 64-bit DDR3 or 2-ch., 32-bit LPDDR2 support. Integrated FlexCAN, MLB busses, PCI Express® and SATA-2 provide excellent connectivity, while integration of LVDS, MIPI display port, MIPI camera port and HDMI v1.4, the i.MX 6Dual provides a scalable solution for consumer, automotive and industrial applications.The MarS Board has 4GByte eMMC, 4*256MByte DDR3 SDRAM and 2MByte SPI Flash on board and features 4 USB Host and 1 USB OTG, 10M/100M/1Gbps Ethernet, TF card socket and three display ports on board (HDMI, RGB, LVDS). More other peripheral signals have been brought out from a pair of 2.54mm space 2*20-pin board-to-board female connectors such as UARTs, CAN, SPI, I2C, PWM, etc.The MarS Board is a ready-to-run platform with ported Linux 3.0.15 or Android 4.0.4. Additionally, Embest provides the demo for uC/OS-II V2.92.05 for user experience. It is an ideal core processing component for your end devices based on a single hardware design. This will greatly improve the efficiency and agility of design, shorten the circle of developing, and accelerate the products to come into the market.Embest also provides many add-on options for the MarS Board such as USB WiFi module (Wi-Pi), HDMI-to-VGA conversion module (Pi-View) and 4.3 inch or 7 inch TFT LCD including touch screen.These modules have further extended more functions for the MarS Board.
