Author Topic: Use the PrtSc key to save screenshots to the desktop in PeppermintOS Two  (Read 6050 times)
I don't know if you've noticed, but in Peppermint if you hit the PrtSc (Print Screen) key Peppermint takes a screenshot and saves it as a .png in your Home folder (but with an odd filename format).
PrtSc = Full Screenshot.
Alt+PrtSc = Interactively select a window or rectangle with the mouse.
I prefer my screenshots saved directly to my desktop by default .. if you're like me, here's how to do it ..
Not only will they save to your desktop, but they'll have the much more readable filename format - Screenshot_2012-04-27_01:58:18.png
FYI, Peppermint uses an application called "scrot" for taking screenshot, and the key bindings are contained in your
~/.config/openbox/peppermint-rc.xml
file.
OK, here goes :)
First backup your peppermint-rc.xml file:
cp -v ~/.config/openbox/peppermint-rc.xml ~/.config/openbox/peppermint-rc.xml.backup
Now open peppermint-rc.xml for editing:
gedit ~/.config/openbox/peppermint-rc.xml
Find the section that reads:-
<!-- Keybinding for PrintScreen Key --><keybind key="Print"><action name="Execute"><execute>scrot</execute></action></keybind><keybind key="A-Print"><action name="Execute"><execute>scrot -s</execute></action></keybind>
and change it to read:-
<!-- Keybinding for PrintScreen Key --><keybind key="Print"><action name="Execute"><execute>scrot "Screenshot_%Y-%m-%d_%H:%M:%S.png" -e "mv $f ~/Desktop/"</execute></action></keybind><keybind key="A-Print"><action name="Execute"><execute>scrot -s "Screenshot_%Y-%m-%d_%H:%M:%S.png" -e "mv $f ~/Desktop/"</execute></action></keybind>
SAVE the file.
Back in the terminal, run:
openbox --reconfigure
(to let openbox pick up the changes)
Done :)
Test both "prtSc" and "Alt+PrtSc" .. they should now save to the desktop not your home folder .. the screenshots will also be saved with a filename that makes more sense .. like Screenshot_2012-04-27_01:58:18.png
To UNDO -
Run:
mv -v ~/.config/openbox/peppermint-rc.xml ~/.config/openbox/peppermint-rc.xml.edited
mv -v ~/.config/openbox/peppermint-rc.xml.backup ~/.config/openbox/peppermint-rc.xml
You're now be back to the way things were.
« Last Edit: April 27, 2012, 04:40:17 pm by Mark Greaves (PCNetSpec) »
