Author Topic: problem with flashybrid...NEED HELP  (Read 1881 times)
Offline Dimitris7
« on: May 14, 2012, 04:25:25 pm »
hi,
i'm trying to install the flashybrid but when i enter the apt-get install flashybrid command the machine returns me this :
[email protected]:/home/user# apt-get install flashybrid
Reading package lists... Done
Building dependency tree
flashybrid is already the newest version.
1 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Setting up flashybrid (0.15+nmu2) ...
dpkg: error processing flashybrid (--configure):
subprocess post-installation script returned error exit status 1
flashybrid
E: Sub-process /usr/bin/dpkg returned an error code (1)
please help me....
Re: problem with flashybrid...NEED HELP
« Reply #1 on: May 14, 2012, 05:41:15 pm »
You cannot install from the command line whilst your packakage manager(s) or Update Manger are open .. so make sure they are closed .. then try again.
Although .. it also seems to be telling you the flashbrid package is already installed, and the latest version.
