Author Topic: Linux novice with acer one ZG5  (Read 6548 times)
Re: Linux novice with acer one ZG5
« Reply #30 on: May 31, 2012, 05:34:47 pm »
No problem .. check the PM I sent you about installing the Jupiter power management applet, specially if you use the AA1 on battery a lot :)
I really should add that to the tutorial ;)
« Last Edit: May 31, 2012, 05:57:36 pm by Mark Greaves (PCNetSpec) »
Offline 16fairfield
« Reply #31 on: May 31, 2012, 07:56:45 pm »
Mark
this is where it all started - the printer - how do i install ?  rastertosamsungspl   it is on my hard drive
Offline SeZo
« Reply #32 on: May 31, 2012, 08:12:20 pm »
Mark
Can I suggest to start a new topic as this could get out of hand.
Also please state what is your printers make and model. ;)
